POV-Ray : Newsgroups : povray.newusers : Scene on a hill Server Time
17 Oct 2026 18:33:55 EDT (-0400)
  Scene on a hill (Message 1 to 4 of 4)
Subject: Scene on a hill
Date: 26 Dec 2005 03:32:30
Message: <43afaa9e@news.povray.org>
What object should I use to model a hill?
I have contours for this hill, and want to create a 3D view with some
proposed buildings on it.  There needs to be some earthworks to make a
platform, so the hill object will need to have a platform cut into it.
Any tips would be most appreciated.
TIA
Peter
Subject: Re: Scene on a hill
Date: 26 Dec 2005 03:58:43
Message: <43afb0c3@news.povray.org>
"Peter" <nos### [at] yahooconz> schreef in bericht
news:43afaa9e@news.povray.org...
> TIA
> Peter
Height field most probably, or isosurface. However, you will have to process
your contours to coloured bands (light for higher parts; dark for lower
parts). You can do this in any painting program. Make sure you
smooth/blur/blend the limits between colours. Then you can use this image in
a height_field, but also with an isosurface, as a pigment function.
Earthworks/platform can also be made on the image in a paint program.
However, if you have a height field generator like Leveller for instance,
that would even be easier to make.
You can place objects with the trace() function of POV;
Hope this helps,
Date: 26 Dec 2005 09:14:42
Message: <43affad2$1@news.povray.org>
"Peter" <nos### [at] yahooconz> wrote in message
> TIA
> Peter
Hi Peter,
It depends on the format you've got the contours in.
If it's as an image file, then I think the method Thomas described would be
the way to go.
If you mean that you have a series of coordinates representing the contours,
then you'd probably be best using them to build a mesh object.
Chris B.
Date: 29 Dec 2005 03:26:57
Message: <43b39dd1@news.povray.org>
"Chris B" <c_b### [at] btconnectcomnospam> schreef in bericht
news:43affad2$1@news.povray.org...
be
> the way to go.
contours,
Ah yes, that is right. Another possible option would then be to make a
greyscale image using Surfer for instance, but that is another matter...
