POV-Ray : Newsgroups : povray.newusers : Turn an arrow Server Time
17 Nov 2026 23:29:35 EST (-0500)
  Turn an arrow (Message 1 to 10 of 10)
Subject: Turn an arrow
Date: 22 Jul 2005 06:09:36
Message: <42e0c5e0@news.povray.org>
Hi all,
I've done this arrow:
union {
cone { <0,0,0>,2,<3,0,0>,0  }
cylinder  { <-5,0,0>,<0,0,0>,1 }
pigment { color  Gray*1.2   }
scale <3, 1.6, 1>
scale 0.5
rotate <0, 0, -90>
Now I was thinking how can I turn the cylinder like a bridge.
I thought that using a spline would work, but I'm not sure if it's the
easiest way, because I think should be another easier way to turn the
cylinder 90º for exemple.
Using this:
#local yPos = Ampl*sin(xFreq*xCnt/xNr*2*pi)*cos(zFreq*zCnt/zNr*2*pi);
and then declaring:
#declare Amplitude = 30;
to make the arch.
Any ideas?
Thanks in advance,
Oleguer
Subject: Re: Turn an arrow
Date: 22 Jul 2005 07:12:33
Message: <42e0d4a1$1@news.povray.org>
Will a segment of a torus do? You can intersect a torus with two planes to
get a small piece of it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 22 Jul 2005 07:27:08
Message: <42e0d80c@news.povray.org>
Yeah, good idea Slime! I haven't thought it.
But, should be a way to turn the cylinder like a half torus and I don't know
how can I do it.
Best regards,
Oleguer
"Slime" <fak### [at] emailaddress> escribió en el mensaje
news:42e0d4a1$1@news.povray.org...
> - Slime
Date: 23 Jul 2005 18:01:44
Message: <42e2be48$1@news.povray.org>
Investiga con matrix keyword, tal vez no sea exactamente lo que buscas, pero
es lo que más se aproxima.
http://enphilistor.users4.50megs.com/matrix.htm
light_source{0,1}#macro C(r,p)cylinder{x*-2,x*2,.9 pigment { rgb
p} /* B Gimeno estoeslarealidad */ rotate p*90 } #end difference
{box {-1,1} C(z /* http://usuarios.lycos.es/game2413 */,x)C(x,y)
C(z,z) pigment{rgb 2} rotate 45 translate z*4} // www.povray.org
Date: 23 Jul 2005 18:52:28
Message: <42e2ca2c$1@news.povray.org>
know
> how can I do it.
I'm not quite sure what you're asking if my reply didn't answer it.
Let's say you had a cylinder, along the Y axis from <0,0,0> to <0,H,0> with
radius R. You want to curl the cylinder by X degrees towards the x-axis. You
could do it like this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
intersection {
    torus {
        // we want X/360 * circumference of torus to equal H
        #declare MajorRad = H*360/(X*2*pi);
        MajorRad,
        // minor radius = cylinder's radius
        R
    #if (X < 180)
        intersection {
    #else
        union {
        // cut off the bottom
        plane {
            -z,0
        // cut off the other end
        plane {
            z,0
            rotate X*y
    translate MajorRad*x
    rotate -90*x
    pigment {rgb 1}
    rotate 90*x
It sounds like you want X = 180 if you want "half a torus." Watch what
happens as you bring X from 0 to 90, 180 and even up to 360.
 - Slime
Date: 24 Jul 2005 01:58:48
Message: <42e32e18@news.povray.org>
  Matrix transformations can only perform linear transformations. They
can't bend a cylinder into a torus segment.
Hanki elämä, hanki Linux.
Date: 30 Jul 2005 14:52:35
Message: <42ebcc73@news.povray.org>
Hi all,
Yeah, you've used a torus to do it.
Sorry for the late reply, I was outside of Lleida.
Thanks,
Oleguer
news:42e2ca2c$1@news.povray.org...
> know
>> how can I do it.
> with
> You
> #declare H = 2;
> #declare X = 90;
> #declare R = .2;
> intersection {
>    torus {
>        MajorRad,
>        R
>    #if (X < 180)
>        intersection {
>    #else
>        union {
>    #end
>        plane {
>            -z,0
>        plane {
>            z,0
>            rotate X*y
>    rotate -90*x
>    pigment {rgb 1}
>    rotate 90*x
> - Slime
Date: 30 Jul 2005 14:55:11
Message: <42ebcd0f@news.povray.org>
Hi Bruno,
Thanks for the page. I will read it, it looks interesting.
Oleguer
"B. Gimeno" <NO_### [at] lycoses> escribió en el mensaje
news:42e2be48$1@news.povray.org...
> pero
Date: 1 Aug 2005 05:25:48
Message: <42edea9c@news.povray.org>
Hi Slime and all,
Using your code like this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
#declare Fletxa = object {
intersection {
torus {
MajorRad,
R }
#if (X < 180)
intersection {
#else
union {
plane { -z, 0 }
plane { z, 0
rotate X*y } }
rotate -90*x
pigment { rgb 1 }
rotate 90*x
translate <0, 0, 0> + Direction
#declare Punta = object {
cone { <0,0,0>,0.5,<1.5,0,0>,0
pigment { rgb 1 } }
scale 0.5
translate <0, 6, 0> + Direction
union {
object { Fletxa }
object { Punta rotate <0, 90, 0> } }
How can I calculate the position of the cone the place it exactly on the end
of the torus?
Oleguer
"Oleguer Vilella" <ole### [at] infonegociocom> escribió en el mensaje
news:42ebcc73@news.povray.org...
> Hi all,
> Thanks,
> Oleguer
>> know
>>> how can I do it.
>> with
>> You
>> #declare H = 2;
>> #declare X = 90;
>> #declare R = .2;
>> intersection {
>>    torus {
>>        MajorRad,
>>        R
>>    #if (X < 180)
>>        intersection {
>>    #else
>>        union {
>>    #end
>>        plane {
>>            -z,0
>>        plane {
>>            z,0
>>            rotate X*y
>>    rotate -90*x
>>    pigment {rgb 1}
>>    rotate 90*x
>> - Slime
Date: 1 Aug 2005 06:00:55
Message: <42edf2d7@news.povray.org>
If I do this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
intersection {
torus {
MajorRad,
R }
#if (X < 180)
intersection {
#else
union {
plane { -z, 0 }
plane { z, 0
rotate X*y } }
rotate -90*x
pigment { rgb 1 }
rotate 90*x
translate <1.06, -0.7, 0> + Direction*3
rotate <180, 0, 0>
pigment { rgb 1 } }
scale 0.5
translate <1.5, 3, 0> + Direction*3
rotate <0, 180, 180>
union {
object { Fletxa }
object { Punta }
translate <6, 0, 0> + Direction }
When I translate all the union, the cylinder isn't moving following the
torus. Why? They are into an union, so, the translate vector should move all
the object. Isn't it?
Oleguer
news:42edea9c@news.povray.org...
> Hi Slime and all,
> #declare H = 2;
> #declare X = 90;
> #declare R = .2;
> intersection {
> torus {
> MajorRad,
> R }
> #if (X < 180)
> intersection {
> #else
> union {
> #end
> plane { -z, 0 }
> plane { z, 0
> rotate X*y } }
> rotate -90*x
> pigment { rgb 1 }
> rotate 90*x
> pigment { rgb 1 } }
> scale 0.5
> union {
> object { Fletxa }
> end of the torus?
> Regards,
> Oleguer
>> Hi all,
>> Thanks,
>> Oleguer
>>> know
>>>> how can I do it.
>>> with
>>> You
>>> #declare H = 2;
>>> #declare X = 90;
>>> #declare R = .2;
>>> intersection {
>>>    torus {
>>>        MajorRad,
>>>        R
>>>    #if (X < 180)
>>>        intersection {
>>>    #else
>>>        union {
>>>    #end
>>>        plane {
>>>            -z,0
>>>        plane {
>>>            z,0
>>>            rotate X*y
>>>    rotate -90*x
>>>    pigment {rgb 1}
>>>    rotate 90*x
>>> - Slime
