Hi all,
I've done this arrow:
union {
cone { <0,0,0>,2,<3,0,0>,0 }
cylinder { <-5,0,0>,<0,0,0>,1 }
pigment { color Gray*1.2 }
scale <3, 1.6, 1>
scale 0.5
rotate <0, 0, -90>
Now I was thinking how can I turn the cylinder like a bridge.
I thought that using a spline would work, but I'm not sure if it's the
easiest way, because I think should be another easier way to turn the
cylinder 90º for exemple.
Using this:
#local yPos = Ampl*sin(xFreq*xCnt/xNr*2*pi)*cos(zFreq*zCnt/zNr*2*pi);
and then declaring:
#declare Amplitude = 30;
to make the arch.
Any ideas?
Thanks in advance,
Oleguer
Will a segment of a torus do? You can intersect a torus with two planes to
get a small piece of it.
- Slime
[ http://www.slimeland.com/ ]
Yeah, good idea Slime! I haven't thought it.
But, should be a way to turn the cylinder like a half torus and I don't know
how can I do it.
Best regards,
Oleguer
"Slime" <fak### [at] email address> escribió en el mensaje
news:42e0d4a1$1@news.povray.org...
> - Slime
Investiga con matrix keyword, tal vez no sea exactamente lo que buscas, pero
es lo que más se aproxima.
http://enphilistor.users4.50megs.com/matrix.htm
light_source{0,1}#macro C(r,p)cylinder{x*-2,x*2,.9 pigment { rgb
p} /* B Gimeno estoeslarealidad */ rotate p*90 } #end difference
{box {-1,1} C(z /* http://usuarios.lycos.es/game2413 */,x)C(x,y)
C(z,z) pigment{rgb 2} rotate 45 translate z*4} // www.povray.org
know
> how can I do it.
I'm not quite sure what you're asking if my reply didn't answer it.
Let's say you had a cylinder, along the Y axis from <0,0,0> to <0,H,0> with
radius R. You want to curl the cylinder by X degrees towards the x-axis. You
could do it like this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
intersection {
torus {
// we want X/360 * circumference of torus to equal H
#declare MajorRad = H*360/(X*2*pi);
MajorRad,
// minor radius = cylinder's radius
R
#if (X < 180)
intersection {
#else
union {
// cut off the bottom
plane {
-z,0
// cut off the other end
plane {
z,0
rotate X*y
translate MajorRad*x
rotate -90*x
pigment {rgb 1}
rotate 90*x
It sounds like you want X = 180 if you want "half a torus." Watch what
happens as you bring X from 0 to 90, 180 and even up to 360.
- Slime
Matrix transformations can only perform linear transformations. They
can't bend a cylinder into a torus segment.
Hanki elämä, hanki Linux.
Hi all,
Yeah, you've used a torus to do it.
Sorry for the late reply, I was outside of Lleida.
Thanks,
Oleguer
news:42e2ca2c$1@news.povray.org...
> know
>> how can I do it.
> with
> You
> #declare H = 2;
> #declare X = 90;
> #declare R = .2;
> intersection {
> torus {
> MajorRad,
> R
> #if (X < 180)
> intersection {
> #else
> union {
> #end
> plane {
> -z,0
> plane {
> z,0
> rotate X*y
> rotate -90*x
> pigment {rgb 1}
> rotate 90*x
> - Slime
Hi Bruno,
Thanks for the page. I will read it, it looks interesting.
Oleguer
"B. Gimeno" <NO_### [at] lycos es> escribió en el mensaje
news:42e2be48$1@news.povray.org...
> pero
Hi Slime and all,
Using your code like this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
#declare Fletxa = object {
intersection {
torus {
MajorRad,
R }
#if (X < 180)
intersection {
#else
union {
plane { -z, 0 }
plane { z, 0
rotate X*y } }
rotate -90*x
pigment { rgb 1 }
rotate 90*x
translate <0, 0, 0> + Direction
#declare Punta = object {
cone { <0,0,0>,0.5,<1.5,0,0>,0
pigment { rgb 1 } }
scale 0.5
translate <0, 6, 0> + Direction
union {
object { Fletxa }
object { Punta rotate <0, 90, 0> } }
How can I calculate the position of the cone the place it exactly on the end
of the torus?
Oleguer
"Oleguer Vilella" <ole### [at] infonegocio com> escribió en el mensaje
news:42ebcc73@news.povray.org...
> Hi all,
> Thanks,
> Oleguer
>> know
>>> how can I do it.
>> with
>> You
>> #declare H = 2;
>> #declare X = 90;
>> #declare R = .2;
>> intersection {
>> torus {
>> MajorRad,
>> R
>> #if (X < 180)
>> intersection {
>> #else
>> union {
>> #end
>> plane {
>> -z,0
>> plane {
>> z,0
>> rotate X*y
>> rotate -90*x
>> pigment {rgb 1}
>> rotate 90*x
>> - Slime
If I do this:
#declare H = 2;
#declare X = 90;
#declare R = .2;
intersection {
torus {
MajorRad,
R }
#if (X < 180)
intersection {
#else
union {
plane { -z, 0 }
plane { z, 0
rotate X*y } }
rotate -90*x
pigment { rgb 1 }
rotate 90*x
translate <1.06, -0.7, 0> + Direction*3
rotate <180, 0, 0>
pigment { rgb 1 } }
scale 0.5
translate <1.5, 3, 0> + Direction*3
rotate <0, 180, 180>
union {
object { Fletxa }
object { Punta }
translate <6, 0, 0> + Direction }
When I translate all the union, the cylinder isn't moving following the
torus. Why? They are into an union, so, the translate vector should move all
the object. Isn't it?
Oleguer
news:42edea9c@news.povray.org...
> Hi Slime and all,
> #declare H = 2;
> #declare X = 90;
> #declare R = .2;
> intersection {
> torus {
> MajorRad,
> R }
> #if (X < 180)
> intersection {
> #else
> union {
> #end
> plane { -z, 0 }
> plane { z, 0
> rotate X*y } }
> rotate -90*x
> pigment { rgb 1 }
> rotate 90*x
> pigment { rgb 1 } }
> scale 0.5
> union {
> object { Fletxa }
> end of the torus?
> Regards,
> Oleguer
>> Hi all,
>> Thanks,
>> Oleguer
>>> know
>>>> how can I do it.
>>> with
>>> You
>>> #declare H = 2;
>>> #declare X = 90;
>>> #declare R = .2;
>>> intersection {
>>> torus {
>>> MajorRad,
>>> R
>>> #if (X < 180)
>>> intersection {
>>> #else
>>> union {
>>> #end
>>> plane {
>>> -z,0
>>> plane {
>>> z,0
>>> rotate X*y
>>> rotate -90*x
>>> pigment {rgb 1}
>>> rotate 90*x
>>> - Slime
