POV-Ray : Newsgroups : povray.newusers : Problem with Photon's Server Time
18 Nov 2026 00:01:31 EST (-0500)
  Problem with Photon's (Message 1 to 4 of 4)
Subject: Problem with Photon's
Date: 25 Apr 2005 09:37:38
Message: <426cf2a2@news.povray.org>
I've designed an old oil lamp, but am hjaving problems assigning photons
to the globe.  Basically, if photon's are off the base of the lamp
causes a shadow to form beneath the lamp (as it should), but if rendered
with photons on this shadow is lost, as is the projection of
yellow-orange light onto the ground.  I suspect that photons are getting
assiged to both the metal and glass parts of the lamp.  Is this what
happened, and if so how do I fix it?
I've attached the code below.  If you render it as-is you should get an
image with 2 lamps - the one on the left has photon's on, the one on the
right has photon's off.  If you only render the one with photons on
you'll see that id doesn't cast any shadows, or illuminate the ground,
whereas both of these happen with photons off.
Thanx
Bryan
Oil Lamp
Makes an oil lamp, with glass globe and copper base
Flame is made up of emiting media plus a point light
Using this object:
   Photon's must be on to get refractive characteristics of glass
Calling the lamp (macro):
   Oil_Lamp (Photons_On)
     Photons_On = on/off statement allowing an #if statmement to be
                  used to turn photons on or off.
//--------------------------Include Files------------------------------
#include "metals.inc"
#include "glass.inc"
#macro Oil_Lamp (Photons_On)
#declare Globe = lathe {
     cubic_spline
     8,
     <0.5,-1>, <0.45,0>, <0.45,0.5>, <1.25,1>, <1.25,1.5>, <0.75,3>,
<0.45,5>, <0.45, 5.5>
     hollow on
       pigment { Col_Glass_Old }
       finish { F_Glass3 }
             }// end texture
     #if (Photons_On = on)
     photons{
       target
       reflection off
       refraction on
             }//end photons
           }//end lathe
#declare LampBase = union {
   cylinder {
     <0,0,0>, <0,0.25,0>, 1.25
       pigment { P_Brass3 }
       finish { F_MetalC }
             }//end finish
    }// end bottom cylinder
    difference {
      sphere {
        <0,1.2,0>, 1.66
          finish { F_MetalC }
                }//end texture
         scale y*0.6
         interior { I_Glass }
            }//end sphere
       box {
         <-5,0.6,5>, <5,3,-5>
           finish { F_MetalC }
       sphere {
        <0,1.4,0>, 1.63
          finish { F_MetalB }
                }//end texture
         scale y*0.6
               }//end sphere*/
    }//end difference
   union {
     cone {
       <0,0,0>, 0.5, <0,2.5,0>, 1.25
          finish { F_MetalC }
                }//end texture
        }//end cone
     sphere {
       <0,5,0>, 1.2
       scale y*0.5
          finish { F_MetalC }
                }//end texture
        }//end sphere
     torus {
       1.2, 0.1
          finish { F_MetalC }
                }//end texture
        translate y*2.5
        }//end torus
     cone {
       <0,3,0>, 0.25, <0,3.5,0>, 0.5
          finish { F_MetalC }
                }//end texture
        }//end cone
     torus {
       0.5, 0.05
          finish { F_MetalC }
                }//end texture
        translate y*3.5
        }//end torus
     cone {
       <0,3.5,0>, 0.5, <0,3.9,0>, 0.1
          finish { F_MetalC }
                }//end texture
        }//end cone
        }//end union
}//end lamp base union
#declare Flame = union {
       difference{
	sphere{0, 0.5}
	sphere{<0, -0.3, 0>, 0.35}
	hollow
	pigment { rgbt 1}
	interior
	  { media
	    { emission rgbf <3, 1.85, 0.1, 0.2>
	      density {
	        cylindrical
	        color_map{
                   [0.3 rgb 1]
                   [1 rgb <0.2, 0.2, 4>]
                          }//end color map
	       turbulence 0.15
	               } //end density
	             } //end media
	           } //end interior
	scale<.7, 2.5, .7>
    }//end flame difference
    light_source {
      <0,-0.53,0>
      color rgb <3,1.85,0.1>
    }//end flmae union
#declare WholeLamp = union {
   object { Globe translate y*3.5 }
   object { LampBase }
   object { Flame translate y*4.5}
object {WholeLamp}
#end //end oil lamp macro
//------------------------Sample Scene---------------------------------
global_settings {
    photons {
      count 20000
      autostop 0
      jitter .4
//Setup Camera
   location <0,5,-30>
   look_at <0,4,0.01>
   angle 30
//Setup Environment
plane {
   <0,1,0>, 0
    pigment { color Grey }
object {
   Oil_Lamp (on)
   translate x*-3
   } //end lamp
object {
   Oil_Lamp (off)
   translate x*3
   } //end lamp
Subject: Re: Problem with Photon's
Date: 25 Apr 2005 19:36:01
Message: <426d7ee1$1@news.povray.org>
Bryan Heit nous apporta ses lumieres en ce 2005-04-25 09:37:
> Thanx
> Bryan
> Oil Lamp
> Using this object:
>     cubic_spline
>     8,
>     hollow on
>     texture {
>       finish { F_Glass3 }
>             }// end texture
>     photons{
>       target
>       reflection off
>       refraction on
>             }//end photons
>     #end
>           }//end lathe
I think that the problem in in the lathe you used. Even if you used the hollow option,
it's
effectively "solid", in that it don't have any open space inside of it.
Try using a difference of your lathe with itself scaled <0.9,1.01,0.9>(smaller
diameter, very
slightly taller to remove coincident surfaces). You can also make the lathe come back
to make the
inside empty.
Another thing, if all elements of a CSG object share the same texture and finish, it's
preferable to
assing your texture once to the whole object, not to each of it's elements. It makes
smaller, easier
to read and maintain code, it also save memory when rendering, possibly gaining some
little speed.
You can always use some textures for individual elements if you want to have some that
have a
different texture.
Date: 25 Apr 2005 20:08:52
Message: <426d8694@news.povray.org>
>      cubic_spline
>      8,
>      hollow on
  Do you understand what 'hollow' is for?
Date: 25 Apr 2005 20:34:48
Message: <426d8ca8@news.povray.org>
> hollow option, it's effectively "solid", in that it don't have any open
> space inside of it.
> <0.9,1.01,0.9>(smaller diameter, very slightly taller to remove
> coincident surfaces). You can also make the lathe come back to make the
> inside empty.
This has made the globe look much nicer.  Even better, I can switch  to
a quadratic spline to speed things up.  Unfortunately, it does not solve
the problem of the lamp projecting light onto the ground, or casting
it's own shadow.
> and finish, it's preferable to assing your texture once to the whole
> object, not to each of it's elements. It makes smaller, easier to read
> some little speed. You can always use some textures for individual
> elements if you want to have some that have a different texture.
I usually do this, but as you can probably tell from my code I
guestimagted the shape of the lamp, and haven't had a chance to clean up
the code yet.
> Alain
