Hi all,
I will post an object on povray.binaries.images
I'm traying to make this object using POV-Ray. I was traying doing it like
an helix with some different functions, the problem is that I don't know how
can I do the extensions.
A code to do this kind of helix can be this:
#declare R1=0.1; //Menor radio de la hélice.
#declare R2=0.3; //Mayor radio de la hélice.
#declare R3=2.; //Mayor radio del toro.
#declare Strands=2; //Doble hélice.
#declare Turns=8.5*Strands; //Número de vueltas de la hélice. Turns*Strand
devería crear discontinuidad.
#declare DNA=function { f_helix1 (x-R3, y, z, Strands, Turns, R1, R2, 1, 1,
0) }
isosurface {
function { DNA (f_r(x, z, y), f_th (x, z, y), z) }
max_gradient 1.3
contained_by { sphere { 0, 3 } }
scale 1.5
translate x*5
rotate x*25
pigment { rgb 1 }
Am I wrong?
I was also thinking about splines, but I think that easiest way to do it is
using a function.
Thanks in advance,
Oleguer
"Oleguer Vilella" <ole### [at] infonegocio com> wrote in message
news:42064b7a@news.povray.org...
Well, the way I see it, is if you don't want a gap in the coil, (as in
your image), then you could *fake* it with stacked/angled torii, and then
use sphere_sweeps for the ends? (I have no experience of sphere_sweeps
though...)
Looks interesting. Celtic?
~Steve~
> Oleguer
Well, I want to make an object like the object that I've posted.
A torii to make this kind of helix? A torii is a torus?
A sphere_sweep is like a spline. I've still never trayed.
What do you with Celtic?
Thanks,
Oleguer
"St." <dot### [at] dot com> escribió en el mensaje news:420666d2@news.povray.org...
> though...)
> ~Steve~
>> Oleguer
On Sun, 6 Feb 2005 20:12:53 +0100, "Oleguer Vilella"
A race of people that live in North West Spain, South West France,
Ireland, Scotland and Wales.
Regards
Ah, all right. Understood now.
That's a kind of protein.
Oleguer
"Stephen McAvoy" <mca### [at] aol com> escribió en el mensaje
news:rh0d0113nhkkei9t0jdlc35qhk0rqrssko@4ax.com...
> Regards
> Stephen
"Stephen McAvoy" <mca### [at] aol com> a écrit dans le message de
North West of France my friend :) south west is Basque
> Regards
> Stephen
BTW it is a population, an ethnic group, it was an antic civilization if you
want but there is only one human race: human :)
Marc
BTW is an ethnic group? Well I've known new things about population. All is
interesting.
Any ideas about my question?
Thanks,
Oleguer
"Marc Jacquier" <jac### [at] wanadoo fr> escribió en el mensaje
news:4206852a@news.povray.org...
>> Regards
>> Stephen
> you
> Marc
On Sun, 6 Feb 2005 22:00:04 +0100, "Marc Jacquier"
Opps! I put all my kelts in one Basque-et :-)
Regards
On Sun, 6 Feb 2005 21:46:02 +0100, "Oleguer Vilella"
Here is a macro given to me by Frank Sputnik some time ago. It is set
up for Moray so I have included the camera and lights. (Moray uses an
alternative coordinate system)
To increase the gap make SpringHeight > 2;
camera { // Camera Camera01
location < -11.670, -2.337, 3.715>
sky < 0.00000, 0.00000, 1.00000> // Use right
handed-system
up < 0.0, 0.0, 1.0> // Where Z is up
right < 1.35783, 0.0, 0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray)
aspect ratio
angle 39.60000 // Vertical 29.700
look_at < -0.009, -2.008, -0.258>
light_source { // Light001
<0.0, 0.0, 0.0>
color rgb <1.000, 1.000, 1.000>
photons {
translate <-14.750343, -4.685895, 19.073553>
// Spring
#declare SpringHeight = 2;
#declare SpringMajorRadius = 1;
#declare SpringMinorRadius = .1;
#declare SpringRevolutions = 10;
#declare SpringSegments = 1000;
union
#declare Ind = 0;
#while(Ind <= SpringSegments)
#declare Pos2 =
vrotate(<SpringMajorRadius, SpringHeight*Ind/SpringSegments, 0>,
y*360*SpringRevolutions*Ind/SpringSegments);
#if(Ind > 0)
cylinder { Pos1, Pos2, SpringMinorRadius }
sphere { Pos2, SpringMinorRadius }
#declare Pos1 = Pos2;
#declare Ind = Ind+1;
pigment { rgb 1 } finish { specular .5 }
translate -y*4
Regards
"Oleguer Vilella" <ole### [at] infonegocio com> a écrit dans le message de
news:42069084@news.povray.org...
is
> interesting.
Sorry for that off topic drift and I had no answer to your question.
Marc
Wasn't it Oleguer Vilella who wrote:
>Hi all,
I usually suggest isosurfaces for just about everything, but in this
case a sphere_sweep is probably easier. Here's some code to get you
started.
The UNIT is one helical strand with an extension. The path follows a
helix shape until N=P2, then starts to do other things. Four copies of
the UNIT are used to create a double strand helix with extensions at
each end.
I start the sphere_sweep at N-1, to make it much easier to join the four
UNITs correctly. Since the sphere_sweep starts at the second point, it's
tricky to get them to match in the middle if the second point is N=1;
Try different values of A, B, C, D, E and F.
You could also turn the UNIT into a macro, and produce four units with
different parameter settings, so that you get differently shaped
extensions.
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location <0,0,-10> look_at <0,0,0> angle 35}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#declare Points=30; // total number of control points
#declare P2=22; // control point where extension starts
#declare R1=0.1; // minor radius
#declare R2=0.3; // major radius
#declare A=25.0; // controls turniness
#declare B=1.5; // controls height
#declare C=0.4; // controls sideways spread of the extensions
#declare D=2.0; // controls the stretch of the extensions
#declare E=0.2; // controls waviness of extensions
#declare F=1.5; // controls frequency of wave extensions
#declare UNIT=
sphere_sweep {
cubic_spline
Points,
#declare N=-1;
#while (N<Points-1)
#if (N<P2)
#declare X=R2*sin(A*N/Points);
#declare Y=B*N/Points;
#declare Z=R2*cos(A*N/Points);
#else
#declare X=R2*(1+(N-P2)*C)*sin(A*N/Points);
#declare Y=B*N/Points + sin(F*A*(N-P2)/Points)*E
+ B*D*(N-P2)/Points;
#declare Z=R2*(1+(N-P2)*C)*cos(A*N/Points);
<X,Y,Z>,R1
#declare N=N+1;
pigment {rgb 1}
no_shadow
object {UNIT}
object {UNIT rotate y*180}
object {UNIT rotate z*180}
object {UNIT rotate z*180 rotate y*180}
No problem. All comments are wellcome.
news:42071fcf$1@news.povray.org...
> is
>> interesting.
> Marc
Thanks Stephen and Mike and the other people.
Now I'm going to study your codes and I will tray them.
I will post questions later.
Thanks a lot,
Oleguer
"Mike Williams" <nos### [at] econym demon co uk> escribió en el mensaje
news:raOiKCA+H0B### [at] econym demon co uk...
>>Hi all,
>>how
> started.
> each end.
> extensions.
> #version 3.6;
> background {rgb 1}
> #declare UNIT=
> sphere_sweep {
> cubic_spline
> Points,
> #declare N=-1;
> #while (N<Points-1)
> #if (N<P2)
> #else
> #end
> <X,Y,Z>,R1
> #declare N=N+1;
> #end
> pigment {rgb 1}
> no_shadow
> object {UNIT}
