POV-Ray : Newsgroups : povray.newusers : Rotating Server Time
18 Oct 2026 00:53:26 EDT (-0400)
  Rotating (Message 1 to 4 of 4)
Subject: Rotating
Date: 9 Dec 2004 18:14:36
Message: <41b8dc5c$1@news.povray.org>
I have an unusual and long question about rotating.  I'm working on
making some 3D models of some proteins for work.  Some of these proteins
have portions which move relative to other parts of the protein.  I want
to be able to move these parts relative to each other.  At this point I
am achieving this by drawing each "half" of the protein as a separate
object, rotating/translating the moving part, and then "unioning" them
together.
The problem with this process is that when I rotate the objects rotate
around their centres, rather then around the point where they join.  At
this point this isn't a huge problem, but in the future I am planning on
animating these things, and it would be quite difficult to do so using
the current model.  What I was wondering is if there was a way to set-up
an object such that the "centre of rotation" was at a specified place,
rather then where the computer assigns it.
Thanx
Bryan
Subject: Re: Rotating
Date: 9 Dec 2004 19:14:31
Message: <41b8ea67@news.povray.org>
translate -CenterOfRotation
rotate Whatever
translate CenterOfRotation
Date: 10 Dec 2004 08:07:28
Message: <41b99f90$1@news.povray.org>
> together.
> Thanx
> Bryan
There are macros in the transforms.inc file that allow this kind of stuff
Rotate_Around_Trans(Rotation, Point) seems like it would do what you want.
The following may help, but I make no guarantees. From here on out
consider what I'm saying as simply rambling.
Generally if I want to "articulate" something, I build the end that will
be doing the rotation at the origin, pass its rotations into a macro
that creates the object with an articulation point, then translate it to
where it is. When modelling in POVRay, I tend to use very localised
coordinate systems.
An example of what I mean by localised coordinate systems.
Suppose I wanted a table that sat on a floor with a glass on the table:
1) Define the glass so its bottom is at the origin.
2) Define the table so its top is at origin.
3) Define a union of the table and the glass. Translate so the feet are
at origin
4) Define the floor so it is at origin.
There are a few caveats:
1)  I assume its easy to see how far you need to translate the
table-glass union. The legs of the table end at a specifc -Y value (RHCS)
2) I did not mention that the translation of the glass should be down by
a very very tiny amount (or up, depending on how many surfaces you want
to be considered by IOR at the bottom of the glass)
3) It may be too difficult to know where to start/end on a protien
structure, which I'm making a wild guess that it is not entirely
hand-modelled, but coming from a molecular-level modelling program?
~Mike
Date: 10 Dec 2004 09:32:36
Message: <41b9b384$1@news.povray.org>
Mike Raiford wrote:
<snip>>
I'll have to check that out, it sounds exactly like what I need.
<snip>
My models come from a variety of sources, and exactly what they look
like depends on what I am trying to show.  Some are exact models of the
protein crystalline structure - these I import directly from protein
modelling programs, using a utility I picked up off the net (protein
models are essentially a series of interconnected spheres, so they're
perfect for POV-Ray).  These I rarely want to animate, as the complex
structures just make things confusing for the audience.  The other type
of model I use are "idealized" models, where I make a shape which
approximates the 3D shape of the protein in POV-ray.  These are the ones
I usually want to "bend" as these models are used to demonstrate changes
in protein structure.
Thanx for the idea's
Bryan
