POV-Ray : Newsgroups : povray.newusers : SOR, Lathe and Rounded Corners/Edges Server Time
18 Nov 2026 00:47:33 EST (-0500)
  SOR, Lathe and Rounded Corners/Edges (Message 1 to 3 of 3)
Subject: SOR, Lathe and Rounded Corners/Edges
Date: 7 Dec 2004 19:42:38
Message: <41b64dfe$1@news.povray.org>
	I wanted to create an object (bottle, in this case) that has rotational
symmetry about an axis. So an SOR or Lathe seemed like good choices.
	Consider a bottle. It's base is flat, but the edges of the base are
rounded and then go up vertically. As I wanted the roundness, I chose
not to use linear interpolation, and tried some of the other types.
	Getting it rounded was not much of a problem, but then I could not get
the "line" to go up vertically. To give you an idea as to what I mean, I
wanted the base to be of radius about 1. So I picked my base points at
(0,0), (0.95,0).
	Then I had a few points to curve it upwards. Let's say I ended up at
(1,0.05). Now I just want to go vertically up to about (1,4). How do I
do it? If I just put one point, it curves. I thought I could put a
number of intermediate points (1,1), (1,1.5), and so on, but that didn't
achieve the desired effect.
	In the end, I used a superellipsoid, with some CSG (better solution).
However, for future reference, is there any way I can get a vertically
edge using anything other than linear interpolation?
	In general, are there any tricks to dealing with rounded edges or
corners? A while ago I was trying to make a cube, but with rounded edges
and corners. The edges can be done with CSG, but it was somewhat of a
pain and the corners didn't work out...
Thanks,
Aim Low, Reach Your Goals, Avoid Disappointment.
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>m.n### [at] ieeeorg<<<<<<
                                    anl
Subject: Re: SOR, Lathe and Rounded Corners/Edges
Date: 7 Dec 2004 20:33:40
Message: <41b659f4$1@news.povray.org>
"Mueen Nawaz" <m.n### [at] ieeeorg> wrote in message
news:41b64dfe$1@news.povray.org...
> rounded and then go up vertically. Getting it rounded was not much of a
> problem, but then I could not get the "line" to go up vertically.
Try a bezier_spline, as in:
lathe {
  bezier_spline // four points per segment
  8,
  <0, 0>, <0.95, 0>, <1, 0.05>, <1, 0.1>
  <1, 0.1>, <1, 2>, <1, 3>, <1, 4>
Date: 8 Dec 2004 02:34:12
Message: <m8bdr05o7pc0g5liih8jv1evg0q6pj2nco@4ax.com>
> corners?
Do a cross section of the glass using spline and then "rotate" it as:
mesh using Ingo's macros ( http://members.home.nl/seedseven/#lathe ) or
isosurface using IsoCSG (
http://www-public.tu-bs.de/~y0013390/pov/ic/docu02.html#Shaped_Torus )
Both are pretty well documented. In case of isosurface you need to make a
function over one component of given spline.
ABX
