POV-Ray : Newsgroups : povray.newusers : Colour conversion - HTML to RGB Server Time
18 Oct 2026 01:53:57 EDT (-0400)
  Colour conversion - HTML to RGB (Message 1 to 9 of 9)
Subject: Colour conversion - HTML to RGB
Date: 1 Nov 2004 11:15:34
Message: <41866126$1@news.povray.org>
I've done a bit of digging around and I can't seem to come up with anything.
What I'm trying to do is use HTML colours instead of RGB values. This is
really for ease of programming, to save me having to split and recalculate
the HTML values into RGB. I don't mind doing it, but is there an option to
supply POV with HTML values? Or will it need a conversion script somewhere?
Thanks,
David
Subject: Re: Colour conversion - HTML to RGB
Date: 1 Nov 2004 13:00:40
Message: <418679c8$1@news.povray.org>
You should search this newsgroup (povray.newusers) for the topic "RGB<->HEX"
which was posted on 9/9/2004 8:33 PM.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 1 Nov 2004 13:01:08
Message: <JZmaKAAflnhBFwnw@econym.demon.co.uk>
If you mean HTML codes like "FF0088", then it's possible to write a
macro. It's not particularly pretty because you've got to perform
arithmetic on the contents of strings.
#macro HTMLRGB(H)
 #local C=0;
 #while (strlen(H)>0)
   #local A=substr(H,1,1);
   #local H=substr(H,2,strlen(H)-1);
   #if (strcmp(A,"0")=0) #local C=C*16; #end
   #if (strcmp(A,"1")=0) #local C=C*16+1; #end
   #if (strcmp(A,"2")=0) #local C=C*16+2; #end
   #if (strcmp(A,"3")=0) #local C=C*16+3; #end
   #if (strcmp(A,"4")=0) #local C=C*16+4; #end
   #if (strcmp(A,"5")=0) #local C=C*16+5; #end
   #if (strcmp(A,"6")=0) #local C=C*16+6; #end
   #if (strcmp(A,"7")=0) #local C=C*16+7; #end
   #if (strcmp(A,"8")=0) #local C=C*16+8; #end
   #if (strcmp(A,"9")=0) #local C=C*16+9; #end
   #if (strcmp(A,"A")=0 | strcmp(A,"a")=0) #local C=C*16+10; #end
   #if (strcmp(A,"B")=0 | strcmp(A,"b")=0) #local C=C*16+11; #end
   #if (strcmp(A,"C")=0 | strcmp(A,"c")=0) #local C=C*16+12; #end
   #if (strcmp(A,"D")=0 | strcmp(A,"d")=0) #local C=C*16+13; #end
   #if (strcmp(A,"E")=0 | strcmp(A,"e")=0) #local C=C*16+14; #end
   #if (strcmp(A,"F")=0 | strcmp(A,"f")=0) #local C=C*16+15; #end
 #local R=int(C/256/256);
 #local G=mod(int(C/256),256);
 #local B=mod(C,256);
 rgb <R,G,B>/255
Use it like
    pigment {HTMLRGB("FF0088")}
Mike Williams
Gentleman of Leisure
Date: 1 Nov 2004 15:16:45
Message: <418699ac@news.povray.org>
Mike Williams <nos### [at] econymdemoncouk> wrote:
>  #local C=0;
>  #end
>  rgb <R,G,B>/255
> #end
  Code repetition is one of the biggest sins in programming.
  How about this (it has the advantage to support both uppercase and
lowercase hexadecimal numbers, ie. "c2Ab0F" is ok):
#macro HTMLRGB(H)
  #local value = 0;
  #local len = strlen(H);
  #local index = 1;
  #while(index <= len)
    #local char = asc(substr(H, index, 1)) - 48;
    #if(char > 9) #local char = char - 7; #end
    #if(char > 15) #local char = char - 32; #end
    #local value = value*16 + char;
    #local index = index + 1;
  <int(value/65536), mod(int(value/256), 256), mod(value,256)>
Date: 1 Nov 2004 16:02:31
Message: <90mHBAAdRqhBFwzj@econym.demon.co.uk>
Looks good, and only needs a couple of tiny fixes for it to give the
correct results.
Mike Williams
Date: 1 Nov 2004 17:32:21
Message: <4186b975@news.povray.org>
> correct results.
  Like what?
  I know it gives garbage if you give it something else than a hex number,
but I assumed the input is always ok.
Date: 2 Nov 2004 11:30:44
Message: <4187b634$1@news.povray.org>
news:4186b975@news.povray.org...
> > correct results.
>   Like what?
Just this:
rgbf<int(value/65536), mod(int(value/256), 256), mod(value,256)>
Thanks a lot though, great script, works beautifully :)
David
[learning something new every day]
Date: 3 Nov 2004 09:51:05
Message: <4188f059$1@news.povray.org>
"David Robinson" <tdf### [at] ezrscom> wrote in message
news:4187b634$1@news.povray.org...
> > > correct results.
> >   Like what?
number,
> Just this:
No wait, I got that wrong. After running a few values through, a lot of
colours seem to come out as white, so it must be a maths thing...?
David
Date: 3 Nov 2004 13:52:52
Message: <41892904@news.povray.org>
  That's because there really was a bug in my code. I forgot a /255.
The last line should be:
<int(value/65536), mod(int(value/256), 256), mod(value,256)>/255
