POV-Ray : Newsgroups : povray.newusers : Circular Helix Server Time
18 Nov 2026 00:59:37 EST (-0500)
  Circular Helix (Message 1 to 20 of 20)
Subject: Circular Helix
Date: 27 Oct 2004 05:28:14
Message: <417f6a2e$1@news.povray.org>
Ok, last question and I'll stop bugging everybody with my n00bness :)
I'm using POV purely because of the ability to script and render a scene;
I'm writing a front end to accomplish the task.
Initially I had expected to export objects to a POV mesh but this particular
scene is particularly complex - hitting over 200MB so far, and I'm not quite
half-way through.
Can POV nativly build a helix that wraps around itself, to form a closed
loop? Imagine a helix following the path of a curve.
All I need to specify is circle diameter, helix thickness and number of
twists (as well as the usual colour/texture etc).
I expect this way to be a lot quicker, if it is supported...
Thanks again for everybody's help so far!
David
Subject: Re: Circular Helix
Date: 27 Oct 2004 11:00:00
Message: <web.417fb7a44c4748cbff5df6e40@news.povray.org>
There is an isosurface called the Helical Torus that does
what you're looking for. Some info on the parameters
are available at this (very excellent!) resource provided
by Mike Williams:
http://www.econym.demon.co.uk/isotut/nfunc2.htm#ht
Here are a couple of helical tori you can use as starting
points. I used the following parameter values for thin rope
trim around a window:
 f_helical_torus(x,y,z, 100, 60, 2,
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
These parameters were for a thick rope around the base of
a pillar:
 f_helical_torus(x,y,z, 6.0, 8, 2,
         0.5, 1,
         0.5,
         0.25, 1, 1.0, 0)
Isosurfaces are not usually considered a newusers feature
as they can be confusing, but once you get used to them
they are much more powerful than normal csg objects.
Also, if you need a mesh, I believe there are macros on
Mike's website that convert isosurfaces to meshes, but
I've not used them.
For non-circular curves, you can draw a normal
isosurface rope (f_helix1) along the path of a spline.
-Mark Slone
Date: 27 Oct 2004 12:05:47
Message: <417fc75b$1@news.povray.org>
"Renderdog" <slo### [at] hiwaaynet> wrote in message
news:web.417fb7a44c4748cbff5df6e40@news.povray.org...
> by Mike Williams:
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> a pillar:
>          0.5, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> I've not used them.
> -Mark Slone
Ah, thanks for the tip. Looks good - but I'm afraid I don't understand POV
enough yet to debug this:
Parse Error: Expected 'object or directive', function identifier found
instead
So, I'm assuming either my syntax is all wrong (I literally copy/pasted) or
I should have some #include files.
Sorry about this, I'll be off everybody's back soon :)
David
Date: 27 Oct 2004 12:30:00
Message: <web.417fcc974c4748cb4428009b0@news.povray.org>
> instead
An isosurface requires more than just the function, you'll
have to read the documentation to make use of the helix
functions in an isosurface.
Here's a little more to go on, but you'll probably have
difficulty with it until you play with the simpler isosurfaces
first.
#local RopeHoop = function {
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
isosurface {
 function { RopeHoop(x,y,z) }
 max_gradient 3.0
 contained_by { box { <0, 0, 0>, <110, 10, 75> } }
 scale 0.04
 rotate -90*x
Date: 27 Oct 2004 13:38:26
Message: <417fdd12$1@news.povray.org>
news:web.417fcc974c4748cb4428009b0@news.povray.org...
POV
> > instead
or
> first.
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> isosurface {
>  max_gradient 3.0
>  scale 0.04
>  rotate -90*x
Thanks a lot for the tip - nearly all sorted now. This is the code so far:
global_settings {
    radiosity {}
    location <0, 0, -5>
    look_at 0
background { color rgb <1, 1, 1> }
global_settings { ambient_light color rgb <0, 0, 0> }
#include "functions.inc"
#declare RopeHoop = function {
         f_helical_torus(x,y,z, 5, 7, 2,
         1.0, 1,
         0.5,
         0.25, 1, 1.0, 0)
isosurface {
 max_gradient 1
 contained_by { box { <0, 0, 0>, <200, 200, 200> } }
 scale 0.1
 rotate 90*x
  pigment { color rgbf <1, 0, 0, 0> }
  finish  { ambient 1 diffuse 1 }
Only real problem right now is that it only renders 1/4 of the scene (but I
have a feeling it is more likely to be building 1/4 of the model). I've
tried playing with a couple of settings but nothing is making enough of a
difference to hit me in the face with a clue...!
I'm also trying to view this from top down.
Thanks a lot,
David
Date: 27 Oct 2004 15:40:01
Message: <web.417ff8e44c4748cb250c7b0b0@news.povray.org>
The f_helical_torus is centered about <0,0,0>, so you might try
   contained_by { box { <-200, -200, -200>, <200, 200, 200> } }
to show the entire object.
f_helical_torus is a hoop about the Y axis, so to view the entire
hoop from above (camera at +Y) you might remove the
   rotate 90*x
which I used to rotate it to face the Z axis.
Finally, the
   scale 0.1
is there because I couldn't get the ratio of the rope to the hoop's
radius what I wanted without scaling the entire object.
Date: 27 Oct 2004 15:43:42
Message: <lYiq5FAKl$fBFwSo@econym.demon.co.uk>
That's because your "contained_by" box has a corner at the origin, but
the helical torus is centred at the origin. So all the bits on the
negative sides are outside the container.
Try
 contained_by { box { -8,8 } }
 max_gradient 3
Mike Williams
Gentleman of Leisure
Date: 27 Oct 2004 15:50:38
Message: <o46pxLAor$fBFwRF@econym.demon.co.uk>
>by Mike Williams:
I actually had no idea that the helical torus could be used to create a
circular helix. When I was developing that tutorial I experimented with
lots of different values but never happened to stumble on a set that
worked that way.
Mike Williams
Date: 27 Oct 2004 15:53:37
Message: <417ffcc1$1@news.povray.org>
I'm not sure if you want it. Tray with this code:
#declare RopeHoop = function { f_helical_torus(x,y,z, 5, 7, 2, 1.0, 1, 0.5,
0.25, 1, 1.0, 0) }
isosurface {
max_gradient 7
contained_by { sphere { .4, 50*2 } }
translate x*10
scale 1
rotate 0*x
Oleguer
"David Robinson" <tdf### [at] ezrscom> escribió en el mensaje
news:417fdd12$1@news.povray.org...
> POV
> > > instead
copy/pasted)
> or
> > first.
> >          1.0, 1,
> >          0.5,
> >          0.25, 1, 1.0, 0)
> > isosurface {
> >  max_gradient 3.0
> >  scale 0.04
> >  rotate -90*x
> global_settings {
>     radiosity {}
> camera {
>     location <0, 0, -5>
>     look_at 0
>          1.0, 1,
>          0.5,
>          0.25, 1, 1.0, 0)
> isosurface {
>  max_gradient 1
>  scale 0.1
>  rotate 90*x
>  texture {
I
> Thanks a lot,
> David
Date: 27 Oct 2004 16:01:52
Message: <417ffeb0@news.povray.org>
news:web.417ff8e44c4748cb250c7b0b0@news.povray.org...
(but I
a
>    rotate 90*x
> Finally, the
>    scale 0.1
Ok, I'm starting to understand it now. Thanks for everything so far :)
However, I think the Torus aspect is not quite what I had in mind, now that
I can see it in its entirety. I have attached an image to show an example if
it helps. It shows two intertwined helixes.
Hopefully this is achievable? There are going to be a number of these in the
scene, each one larger than this (and with more twists each time) - as I
say, if I export a mesh from a different program, things get unmanageable
very quickly.
Thanks again,
David
Download 'double spun helix.jpg' (36 KB)
Preview of image 'double spun helix.jpg'
Date: 27 Oct 2004 16:10:00
Message: <web.418000114c4748cb250c7b0b0@news.povray.org>
> 0.25, 1, 1.0, 0) }
> isosurface {
> max_gradient 7
> translate x*10
> scale 1
> rotate 0*x
> texture {
Yes, the contained_by a sphere makes more sense with this
object, I'd used the box to chop off parts for my window frame.
Date: 27 Oct 2004 16:20:01
Message: <web.418002674c4748cb250c7b0b0@news.povray.org>
> worked that way.
It took a lot of trial and error. Of course, I now have no memory
of what all the variables do, but I do have this commented code,
(for the first variable in each line). Not sure if they mean anything.
1.0, 1,      //  scale's the windings outward 0 = tube?
0.5,          //  negative minor radius
0.25, 1, 1.0, 0)   //  Inverse scales windings along circumference
Mike, I'd like to thank you for your incredible isosurface tutorial,
http://www.econym.demon.co.uk/isotut/index.htm
It's an amazing resource I've used many times. I live in fear for
the day it disappears!
Thanks,
Mark
Date: 27 Oct 2004 16:21:01
Message: <4180032d$1@news.povray.org>
contained_by { box { <-7.6, -2.6, -7.6>, <7.6, 2.6, 7.6> } }
is enough; larger containers will unneccessarily increase the render time.
   Sputnik
Date: 27 Oct 2004 19:20:00
Message: <web.41802c0b4c4748cbfa11e690@news.povray.org>
Possibly. Let us know what you find.
Date: 27 Oct 2004 19:50:00
Message: <web.418033384c4748cbfa11e690@news.povray.org>
After playing with the parameters a bit, I doubt the
helical_torus will give you exactly what you're looking for.
I don't know for sure, though; there are a lot of combinations.
You will probably be better off using two sphere_sweeps,
though they can be a little temperamental. The math for
the paths shouldn't be too difficult.
Date: 27 Oct 2004 22:22:33
Message: <jD80eBAMfFgBFwLy@econym.demon.co.uk>
Here's an alternative way of getting a circular helix that's a bit
easier to manage than f_helical_torus. What you do is first create an
ordinary f_helix1, then translate it off to one side and transform it
into cylindrical polar co-ordinates. This gives you access to the
f_helix1 control parameters which are better understood than the
f_helical_torus parameters.
I did the translation (x => x-R3) as a separate step from the
co-ordinate change (x => f_r(x,z,y) , y => f_th(x,z,y)) to keep things
simple.
The use of (x,z,y) rather than (x,y,z) is due to the fact that f_th is
defined as atan2(x,z), whereas I wanted atan2(x,y).
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location  <0,0, -20> look_at 0 angle 20}
light_source { <-100,200,-300> colour rgb 1 }
background { rgb 0 }
#declare R1=0.1;     // helix minor radius
#declare R2=0.3;     // helix major radius
#declare R3=2.0;     // torus major radius
#declare Strands=2;  // DNA = double strand
#declare Turns=8.5;  // number of helix turns in the loop
                     // Turns*Strands should be an integer
                     // to avoid a discontinuity
#declare DNA=function { f_helix1 (x-R3, y, z, Strands,
                        Turns, R1, R2, 1, 1, 0) }
isosurface {
   function{DNA(f_r(x,z,y) ,f_th(x,z,y),z)}
        max_gradient 1.3
        contained_by {sphere {0, 3} }
        pigment {rgb 1}
For real DNA, the two strands aren't 180 degrees out of phase like this.
I'm not sure what the exact phase difference is, but here's a version
with the strands 120 degrees out of phase. If you know what the phase
difference should be, you can plug that number in where I've written
"120".
I've also changed the "shape parameter" from 1.0 to 0.6 in this version
to compensate for the fact that the change of co-ordinates had caused
the cross section to become elliptical instead of circular. This will
probably need to be adjusted whenever you change things like R3 and
Turns.
#version 3.6;
#declare R1=0.15;    // helix minor radius
#declare Strands=1;  // DNA = double strand
#declare Turns=8;    // number of helix turns in the loop
                        Turns, R1, R2, 0.6, 1, 0) }
#declare Strand=
isosurface {
        max_gradient 1.3
        pigment {rgb 1}
object{Strand}
object{Strand rotate z*120/Turns}
Mike Williams
Date: 28 Oct 2004 00:25:00
Message: <web.4180737b4c4748cbd4971d0a0@news.povray.org>
Magic!
Date: 28 Oct 2004 11:44:24
Message: <418113d8$1@news.povray.org>
Hello Mike,
Can you explain again how did you do this translation?
isosurface {
What's f_r and what's f_th?
Thanks,
Oleguer
"Mike Williams" <nos### [at] econymdemoncouk> escribió en el mensaje
news:jD8### [at] econymdemoncouk...
> simple.
> #version 3.6;
> isosurface {
>         max_gradient 1.3
>         pigment {rgb 1}
> "120".
> Turns.
> #version 3.6;
> #declare Strand=
> isosurface {
>         max_gradient 1.3
>         pigment {rgb 1}
> object{Strand}
> Mike Williams
Date: 28 Oct 2004 15:08:29
Message: <NDqQ$LAVOUgBFw+H@econym.demon.co.uk>
Wasn't it Oleguer Vilella who wrote:
>Hello Mike,
>isosurface {
If you're not familiar with polar coordinates, I don't think I can teach
the concept in a newsgroup posting.
If you are familiar with polar coordinates, then f_r(), f_th() and
f_ph() are standard functions (in functions.inc) which give you the
polar coordinates R, Theta and Phi. On a globe, they would be altitude,
longitude and latitude.
By transforming a function from Cartesian (ordinary xyz) coordinates to
polar coordinates we can bend the space that contains the function so
that the grid lines of the space are wrapped round into circles.
There are spherical polar coordinates (R Theta Phi) and cylindrical
polar coordinates (R Theta z) and it's the second of these that I used
for this scene.
Mike Williams
Date: 28 Oct 2004 16:20:27
Message: <4181548b$1@news.povray.org>
Ah ok, it's a function from "functions.inc". All understood now.
Many thanks,
Oleguer
news:NDqQ$LAVOUgBFw+H### [at] econymdemoncouk...
> >Hello Mike,
> >isosurface {
> for this scene.
> Mike Williams
