POV-Ray : Newsgroups : povray.newusers : An error message Server Time
18 Oct 2026 01:53:03 EDT (-0400)
  An error message (Message 1 to 12 of 12)
Subject: An error message
Date: 11 Oct 2004 15:11:31
Message: <416adae3$1@news.povray.org>
What is "StretchDiBits() failed! Windows error!" ?
Anyone know what does it mean? It appears with a big resolution render.
Best regards,
Oleguer
Subject: Re: An error message
Date: 11 Oct 2004 15:22:53
Message: <416add8d@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:416adae3$1@news.povray.org...
I *think* this error only occurs when you render an image larger than the
current screen resolution, and then only under certain circs.
Try rendering with the render-window turned off.
Date: 11 Oct 2004 15:31:12
Message: <416adf80$1@news.povray.org>
In article <416adae3$1@news.povray.org> , "Oleguer Vilella"
The preview image is too big for Windows to show you a preview. Turn off the
preview (using the -d option).
    Thorsten
e-mail: tho### [at] trfde
Date: 11 Oct 2004 16:48:50
Message: <416af1b2$1@news.povray.org>
Yes if I turn off the preview all is OK.
Is it a Windows problem or a screen resolution problem?
"Thorsten Froehlich" <tho### [at] trfde> escribió en el mensaje
news:416adf80$1@news.povray.org...
the
>     Thorsten
Date: 11 Oct 2004 16:54:31
Message: <416af307$1@news.povray.org>
In article <416af1b2$1@news.povray.org> , "Oleguer Vilella"
A Windows limitation.
    Thorsten
Date: 11 Oct 2004 17:00:18
Message: <416af462@news.povray.org>
Ah, Ok, maybe with Linux I don't have this problem. Have you ever trayed
with Linux?
news:416af307$1@news.povray.org...
>     Thorsten
Date: 11 Oct 2004 17:20:18
Message: <416af912@news.povray.org>
In article <416af462@news.povray.org> , "Oleguer Vilella"
> with Linux?
It does not make sense to get a preview for a 6400*4800 render. All it will
do is consume a real lot of memory and slow down rendering.
As I already pointed out, there is no problem, it is simply a limitation of
the *preview* window of the Windows version.  The preview does in absolutely
no way affect the output of the image.  In order to view the output image,
you can open it in just about any image viewing program.
    Thorsten
Date: 11 Oct 2004 23:02:04
Message: <416b492c$1@news.povray.org>
Oleguer Vilella nous apporta ses lumieres ainsi en ce 2004-10-11 15:10... :
>Best regards,
>Oleguer
An error thrown by windows when it fails to successfully resize
something. It may cause a memory/resources leak. Are you using an old
version of WindowBlinds (V2.x or 3.x)? If so, set it to only skin the
titlebar of POV Ray.
Date: 12 Oct 2004 02:45:45
Message: <416b7d99@news.povray.org>
Well, I'm using Windows Millenium, it's old.
If I close the preview window all is correct, I realized this on summer.
Thanks,
Oleguer
"Alain" <aze### [at] qwertygov> escribió en el mensaje
news:416b492c$1@news.povray.org...
> >Best regards,
> >Oleguer
> Alain
Date: 12 Oct 2004 13:47:14
Message: <MPG.1bd5c6464bd8beae989be5@news.povray.org>
In article <416af912@news.povray.org>, tho### [at] trfde says...
> > with Linux?
Sounds like a "What are scroll bars?" problem. lol Seriously though, I
use the preview window to see what I am doing, so I don't have to load
the image into a separate program to check it, which takes even more
memory and wastes the time needed to load the image besides (which on
that big of a file..). Lets just say I would be glad I have a relatively
fast computer. lol Having it bomb on a big image would be very annoying.
Thankfully I have never generated one that big, but it is an annoying
limitation never the less.
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
Date: 12 Oct 2004 16:18:40
Message: <416c3c20@news.povray.org>
Well, I doubt you'll render such a huge image just for testing
something, in most cases the render will take quite some time. And
viewing an image which is 4 times the size of the screen in the preview
window is not a good idea, either, because the preview windows has no
scrollbars (well it had none the last time I used winpov). So what's the
problem with the preview window now working for huge images?
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 12 Oct 2004 16:50:11
Message: <416c4383@news.povray.org>
No problems, only with the images whic are very big if I maximize it.
Thanks to all the people,
Oleguer
"Florian Brucker" <tor### [at] torfboldcom> escribió en el mensaje
news:416c3c20@news.povray.org...
> Florian
