Why if I do this some objects move down?
The code is:
=============The camera==============
#include "shapes.inc"
#include "stones.inc"
#include "textures.inc"
#include "woods.inc"
#include "metals.inc"
#include "golds.inc"
#include "glass.inc"
#include "glass_old.inc"
global_settings { assumed_gamma 2 }
background { color White }
camera { location <-10, 8, -19> look_at <0, 5, 0> }
light_source { <0, 33, 0> color White spotlight point_at <0, 0, 0> radius 50
falloff 20 tightness 0 }
light_source { <0, 19, 0> color rgb <0.5, 0.5, 0.5> }
light_source { <40, 25, 0> color rgb <1, 1, 1>
spotlight
point_at <0, 5, 0>
radius 20
falloff 20 }
============The object================
//Inici del relotge.
//Per fer el marc.
#declare Reloj =
union {
merge {
box {<-5,0,-55>,<0,95,55>}
cylinder{<-5,95,0>,<0,95,0>,55}
texture { T_Wood15 } finish { specular .51 ambient 1 diffuse .96 }
scale 0.1 no_shadow}
//Per fer l'esfera.
difference {
cylinder{<-10,95,0>,<20,95,0>,40}
cylinder{<-11,95,0>,< 6,95,0>,36}
texture { T_Gold_1D } finish { specular 2 ambient 1 diffuse .07
reflection 0.1 phong 0.3 phong_size 30 }
scale 0.1}
no_shadow
//Per fer els punts dels quarts.
#declare Puntos = union {
sphere { <0, 0, 0>, 0.1 pigment { color White } finish { ambient 1 }
translate <2.1, 9.7, -4> }
sphere { <0, 0, 0>, .1 pigment { color White } finish { ambient 1 }
translate <-5.4, 9.35, -4> }
translate <-2.2, 12.6, -4> }
translate <-2.2, 6, -4> }
no_shadow
//Agulles del relotge.
#declare Agulles = union {
box { <-1, 0, -3.5> <-0.8, .2, 3.5> pigment { color Black } finish { ambient
1 } translate <0, 9.5, -4> rotate <0, 0, 0> no_shadow }
box { <-1, 0, -1> <-0.8, .2, 0.5> pigment { color Black } finish { ambient
1 } translate <1.12, -0.5, -10> rotate <60, 30, 0> no_shadow }
//Cilindre que unix les agulles.
#declare Cilindre =
cylinder { <0, 0.9, -0.5> <0, 1, 1> 0.035 texture { T_Gold_1D } finish {
specular 2 ambient 1 diffuse .07 reflection 0.1 phong 0.3 phong_size 30 }
rotate y*25 rotate x*-2 translate <-3.18, 8.25, -6>
//Declarant les diverses parts.
#declare Todo_Reloj = union {
object { Reloj rotate y*115 translate <0, 0, 0> }
object { Puntos }
object { Agulles }
object { Cilindre }
//Declarant tot junt.
object { Todo_Reloj no_shadow }
If I put this on the last line "object { Todo_Reloj scale 0.5 no_shadow }",
some objects change their position. Why??
Can anyone help me?
Thanks in advance,
Oleguer
Because you are scaling 'Todo_Reloj' to half size.
Every size and distance inside 'Todo_Reloj' will be halved.
So, what if have to do? scale all the objects a part to make it slower? Is
it a good idea?
Oleguer
"Warp" <war### [at] tag povray org> escribió en el mensaje
news:4147579e@news.povray.org...
no_shadow }",
x]
Warp -
Instead of placing everything in a union{} at the end and naming it
Todo_Reloj, why not place the different objects by themselves and only scale
what needs to be scaled? Something similiar to this:
object { Reloj rotate y*115 translate <0, 0, 0> no_shadow scale 0.5}
object { Puntos no_shadow}
object { Agulles no_shadow}
object { Cilindre no_shadow}
That way, only Reloj will be scaled and the rest left untouched.
Or, leave the #declare Todo_Reloj = union{---} around all the objects, but
just scale the one needing to be scaled.
Tim
"Tim Nikias v2.0"
If I do this:
object { Reloj rotate y*115 translate <0, 0, 0> scale 0.5 }
object { Puntos }
object { Agulles }
object { Cilindre }
I thinks that is your idea, I can not see the other object on the correct
place. If I do this:
object { Reloj rotate y*115 scale 0.5 }
object { Puntos scale 0.5 }
object { Agulles scale 0.5 }
object { Cilindre scale 0.5 }
Some of the objects appear also moved.
I'm thinking....
Thanks,
Oleguer
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> escribió en el
mensaje news:41480a78$1@news.povray.org...
scale
> Regards,
> Tim
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
> If I do this:
> object { Puntos }
> object { Agulles }
> object { Cilindre }
Well, in your first example, you only scale Reloj, in your second example,
you scale all objects, which is just like you did before. Maybe you should
consult the Documentaion, Section 2.2.7 for some more information on
transformations.
The idea is simple: "translate" moves an object, "rotate" rotates an object
about the origin and the given axis', and "scale" scales/sizes an object in
relation to the origin (<0,0,0>). So, if an object is placed at <5,0,0> and
you scale it by .5, not only will the object's dimensions (e.g. its radius)
be sized down to half its original size, but the distance to the origin will
be sized down as well, thus placing the object at <2.5,0,0>.
Then, when you declare and union{} objects, they all get "glued" together,
so when you transform a union, all objects inside the union will get
transformed.
Now, if you want to scale an object's size, but not it's position, what do
you have to do? Let's say you've got a sphere at <5,0,0> and want to squish
it some along the x-axis, making it more disc-shaped. First, you'd have to
translate the sphere back to the origin, then you scale it, and then you
translate it back.
sphere{<5,0,0>,1
translate <-5,0,0>
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
Now, for a sphere this is kinda pointless, as you could have placed it at
the origin from the beginning and thus save translating it back to the
origin:
sphere{<0,0,0>,1
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
But that's the basic idea of how to transform objects. I don't know what
exactly you're after, but if you only want to scale certain parts of an
object, then only scale those, not the entire object.
Tim
"Tim Nikias v2.0"
"Oleguer Vilella" <ole### [at] infonegocio com> wrote in message
news:41481108$1@news.povray.org...
> I'm thinking....
When you scale an object, the only point of the object that won't move is the
point that rests at <0,0,0> (assuming that you're scaling all axis).
To understand what is happening, try the following scene using different values
for myScale. Note that we divide the radius of the spheres by the value of
myScale. This means that the scale size doesn't affect the radius of the
spheres, only their positions.
location <0.0, 0.0, -10.0>
look_at <0.0, 0.0, 0.0>
light_source {
<0, 0, 0> // light's position (translated below)
color rgb <1, 1, 1> // light's color
translate <-30, 30, -30>
#declare myScale = 1;
sphere{
0,0.25/myScale
scale myScale
pigment{rgb<1,0,0>}
sphere{
1,0.25/myScale
scale myScale
pigment{rgb<0,1,0>}
Hello Tim,
I want to make all the object smaler. I understood your firts exemple and I
trayed it, but I don't understand your second exemple. You says:
sphere{<0,0,0>,1
scale <.25,1,1>
translate <5,0,0>
pigment{rgb 1}}
With the scale <.25, 1, 1>, how do you calculate the translate <5, 0, 0>?
If I put scale 5, how can I know the translate vector?
"for a sphere this is kinda pointless, as you could have placed it at the
origin from the beginning and thus save translating it back to the origin:"
Can you tray to explain me it again, please?
Thank you very much,
Oleguer
mensaje news:41481895@news.povray.org...
> > If I do this:
> > object { Puntos }
> > object { Agulles }
> > object { Cilindre }
correct
> transformations.
object
in
and
radius)
will
> transformed.
squish
> translate it back.
> sphere{<5,0,0>,1
> translate <-5,0,0>
> scale <.25,1,1>
> translate <5,0,0>
> pigment{rgb 1}}
> origin:
> sphere{<0,0,0>,1
> scale <.25,1,1>
> translate <5,0,0>
> pigment{rgb 1}}
> Regards,
> Tim
> "Tim Nikias v2.0"
That's actually pretty simple: first, Povray scales the object, afterwards
it translates it to <5,0,0>. Since the sphere is already located at the
origin, the position of the sphere won't change when scaling it. Thus, it
will be squashed a little, but still be positioned at <0,0,0>. So, if I want
to place the sphere at <5,0,0>, I just have to translate it there.
origin:"
The same as above: positions of objects only change when they are not
centered at the origin, since scaling would not only scale the object, but
also its distance to the origin.
The sphere requires a center vector and a radius. If the center vector is
<0,0,0>, the sphere is sitting right on the origin, and scaling it will only
affect the size.
But, if you place the center of the sphere somewhere else, scaling would
also affect the position/center of the sphere. Hence, we need to move it to
the origin first, scale it, and move it back, if we want to retain its
position, but not its size.
Tim
"Tim Nikias v2.0"
Well, Tim, just a minute... I think that I'm doing it right now.
mensaje news:41484a80@news.povray.org...
0>?
want
the
> origin:"
only
> affect the size.
to
> Regards,
> Tim
> "Tim Nikias v2.0"
Hi again Tim,
I think thats right... I have changed some numbers and when I calculated the
picture, appears all on the correct position.
That's the code:
sphere { <-0.3, -0.7, 0>, 0.1 pigment { color White } finish { ambient 1 }
sphere { <-0.35, 0.15, 0>, .1 pigment { color White } finish { ambient 1 }
no_shadow
1 } translate <-0.22, 8.2, -4> rotate <9, 0, 0> no_shadow }
translate y*0.5
#declare Cilindre =
specular 2 ambient 1 diffuse .07 reflection 0 phong 0.3 phong_size 30 }
rotate y*25 rotate x*-2 translate <-3.18, 8.8, -6>
object { Puntos translate 0.5 scale 0.5 translate 0 }
object { Agulles translate 0.5 scale 0.5 translate 0 }
object { Cilindre translate 0.5 scale 0.5 translate y*0 }
no_shadow
object { Todo_Reloj no_shadow translate y*0 }
Now I have to adjust the "Cilindre", but it's easy and quick.
Do you think that's right?
Best regards,
Oleguer
Thank you very much, Tom, for gives me your document, it's very interesting
and it helped me to understood my problem.
Oleguer
"Tom Melly" <tom### [at] tomandlu co uk> escribió en el mensaje
news:414818d7$1@news.povray.org...
> > I'm thinking....
the
values
> camera {
> light_source {
> sphere{
> 0,0.25/myScale
> scale myScale
> pigment{rgb<1,0,0>}
> sphere{
> 1,0.25/myScale
> scale myScale
> pigment{rgb<0,1,0>}
I've just used your scene and took a look at it. Have you tried moving the
camera?
If, for example, you place the camera at <-20,8,0> you'll notice a few
problems your clock has.
It seems to me like you are building the clock to work from a specific
angle, instead, you should try building the clock as it would be in real
world. Maybe by measuring a real clock, you can see how high certain objects
are, and how thick, etc. Another thing you should try to do is keep the code
clean and easy to understand. For example, the white dots you use to
represent 12, 3, 6 and 9 o'clock are translated multiple times before they
are at their final location.
Just take your first white sphere. It is centered at <-0.3,-0.7,0> and you
translate it by <2.1,9.7,-4>. Then, later, you reference the object and then
apply "translate 0.5 scale 0.5" to it. It would be much easier to simply
create the sphere at <0,0,0>, then position it where you want it using a
single "translate", e.g. like this:
sphere{<0,0,0>,0.1 pigment{color White}finish{ambient 1}
translate <1.8,9,-4>
Or, much easier, like this:
sphere{<1.8,9,-4>,0.1 pigment{color White}finish{ambient 1}}
A question that comes to mind when looking at the object and your questions
is if you properly understand the cartesian coordinate system used by
POV-Ray? This is not meant to taunt you, but a proper understanding of it
would be very useful when working with POV-Ray. Did you take a few Advanced
Geometry classes at school or college, by any chance? You'd get a good idea
of the coordinate system that way.
"Tim Nikias v2.0"
Yes, you have the reason, that's very confused. Now I'm simplifing them,
because is very confused. I don't like this kind of numbers, some of them
are very big and they are multiplied a lot of times, I must reduce them.
Oleguer
mensaje news:4148590f$1@news.povray.org...
> camera?
objects
code
then
questions
Advanced
idea
> "Tim Nikias v2.0"
