POV-Ray : Newsgroups : povray.newusers : How can I do an arrow? Server Time
18 Oct 2026 04:34:44 EDT (-0400)
  How can I do an arrow? (Message 1 to 18 of 18)
Subject: How can I do an arrow?
Date: 5 Aug 2004 15:19:26
Message: <4112883e@news.povray.org>
Can you teach me to do an arrow? I don´t know how can I do it.
Thank you very much,
Oleguer
Subject: Re: How can I do an arrow?
Date: 5 Aug 2004 16:39:24
Message: <41129afc$1@news.povray.org>
> Can you teach me to do an arrow? I donīt know how can I do it.
It would really help if you would give some more information about what
you're trying to achieve. Do you want an arrow as a 3D-object,
2D-object, on a texture, how should it look, etc.
Now I can only guess, so here's one (propably the simplest) way to
create a 3D arrow:
union {
	cylinder { <-5,0,0>,<0,0,0>,1 }
	cone { <0,0,0>,2,<3,0,0>,0 }
	pigment { rgb<1,0,0> }
HTH,
Florian
Date: 5 Aug 2004 16:47:51
Message: <41129cf7$1@news.povray.org>
"Oleguer Vilella" <ole### [at] infonegociocom> wrote in message
news:4112883e@news.povray.org...
Hi Oleguer. Well, it's simple really. :) Or can be, anyway, if you only want
a simple arrow. For example:
union {
    cone {0,1,y,0}
    cylinder {-y,0,0.5}
    pigment {rgb 1}
    scale <1,2,1> // size change, longer
    rotate <0,0,90> // point in another direction (left)
Hint: you might want the point tip to be at <0,0,0> so when moving it around
it will be easier to place pointing exactly to a particular spot. Or... with
the other end at <0,0,0>. Either way can be accomplished by adding a
translate -y or +y before scale.
So, there's one way to do it.
Bob H.
Date: 5 Aug 2004 16:51:31
Message: <41129dd3$1@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:41129afc$1@news.povray.org...
Good point (no pun intended, but take it anyhow. haha!), since an arrow
could also be done using a font in the text object, too. Many ways of going
about it. I chose to explain a simple CSG way, like you did.
> create a 3D arrow:
> union {
Date: 6 Aug 2004 02:31:19
Message: <411325b7@news.povray.org>
Yeah, that's it Florian and Hughes, that's the object that I need it. Now I
know how can I do it and I'll do my own arrow. Thank you very much for your
help. Have a nice day.
Best regards,
Oleguer
"Hughes, B." <bob### [at] charternet> escribió en el mensaje
news:41129cf7$1@news.povray.org...
want
> union {
>     cone {0,1,y,0}
>     cylinder {-y,0,0.5}
>     pigment {rgb 1}
around
with
> Bob H.
Date: 6 Aug 2004 04:23:54
Message: <4113401a$1@news.povray.org>
news:411325b7@news.povray.org...
I
Happy to have helped.
Bob H.
Date: 6 Aug 2004 09:04:26
Message: <411381da@news.povray.org>
Hello,
The code is
#include "textures.inc"
  background { White
  camera {location <170, -11, -100>look_at  <180, -15, -16>}
  light_source { <170, -30, -100> color White}
union {
pigment { rgb<0,1.1,0> }
scale <0.9, 1.6, 1>
translate <120, 40, 26>
rotate <-0, 0, -26>
no_shadow
To the arrow. I have trayed to rotate it to an other direction. I want to
put the cone looking on the other side of the screen, but I couldn't. When I
modified the "rotate" vector, all the arrow desapear. What's the problem??
Oleguer
"Oleguer Vilella" <ole### [at] infonegociocom> escribió en el mensaje
> Oleguer
Date: 6 Aug 2004 09:40:56
Message: <41138a68@news.povray.org>
news:411381da@news.povray.org...
> union {
> scale <0.9, 1.6, 1>
> rotate <-0, 0, -26>
> no_shadow
I
Hi again, Oleguer.
Probably because of the translate before rotate, which will tend to move it
a lot more than just turning it around.
You need to watch the order of transformations you use. And also, I think
you might not be thinking of degrees of rotate, i.e. 180 = half circle, and
instead units (your translate 26 then rotate -26) but I'd only be guessing
what you're really trying. So maybe you do realize rotate is in degrees by
default and that is coincidental numbers. Anyway...
That aside, when building an object, try to keep it at or near the origin
(<0,0,0>) and scale it first, secondly do rotate (or rotate first then
scale, depending on the situation), lastly translate. That way you are able
to turn the objects based on the origin and move around from there. Helps to
keep it in one place until the final move. Of course, the better you get at
it the easier it is to know how to use other locations and move things
around. But for simplicities sake, this scale>rotate>translate method works
well as long as your object is created at <0,0,0> for some part of it.
For example:
union {
scale <0.9, 1.6, 1>
rotate 180*y // face left
translate <220, -15, -16> // to right of look_at point
no_shadow
Not sure if this is anything like you wanted to do but it's on the other
side now and pointing toward the middle. You'll catch on to the idea if you
order your transformations correctly. In fact, you might discover that
rotate itself has order, so if you must turn it around the y axis and then x
you need to use two rotates, since a single one can't be reordered from
x,y,z. E.g. rotate <0,180,0> rotate <180,0,0>.
Bob H.
Date: 6 Aug 2004 11:56:06
Message: <4113aa16@news.povray.org>
I put your code with my camera, and I couldn't see it. My camera is
background { White}
camera { location <0, 1, -100> look_at <1, 1, 1> }
I've copied your code and your arrow just desepear. Thank you very much for
the information about the order of the words, I didn't know it, I'll do it
like you. Do you think that's camera problem??
news:41138a68@news.povray.org...
> > union {
> > scale <0.9, 1.6, 1>
> > rotate <-0, 0, -26>
> > no_shadow
to
When
> I
problem??
> Hi again, Oleguer.
it
and
able
to
at
works
> For example:
> union {
> scale <0.9, 1.6, 1>
> no_shadow
you
x
> Bob H.
Date: 6 Aug 2004 12:07:04
Message: <4113aca8$1@news.povray.org>
news:4113aa16@news.povray.org...
> background { White}
for
Yes. In your other message you had used:
The camera location and look_at point is way off now, by 170 to 180, so if
you change the arrows translate to <0,0,0> you'll see it centered again.
Bob H.
Date: 6 Aug 2004 14:07:40
Message: <4113c8ec$1@news.povray.org>
Yes, Ok, that's right!!!!!!!! I'm Spanish, how is my English? I'm studying
English, I've passed the PET examen. I like Pov-Ray, and I'm doing the
PKCpathway because there is a microbioly congress in my city in September.
Thank very much for your help.
Best regards,
Oleguer
news:4113aca8$1@news.povray.org...
> > background { White}
> for
it
> Bob H.
Date: 6 Aug 2004 19:07:10
Message: <41140f1e$1@news.povray.org>
news:4113c8ec$1@news.povray.org...
You are doing okay then. Spelling is bad if you were already
English-speaking but that's true of many people in America. Ha-ha.
Grammatically fair, though, considering... So, actually, you are very
understandable as a non-native English writer. Hope you do good speaking it,
too. I only tried Spanish when I was 10 years old and couldn't speak it
anymore.
Bob H.
Date: 7 Aug 2004 02:53:41
Message: <41147c75@news.povray.org>
Ok Bob. Can you tell me where are you from?, I'm from Lleida, a small city
placed about 120Km from Barcelona (the capital of Catalonia).
Are you a physical or a mathematical? I like both of them. If I would have
an other problem I will ask you.
Thank you very much for your help
Best regards,
Oleguer.
news:41140f1e$1@news.povray.org...
September.
it,
> anymore.
> Bob H.
Date: 7 Aug 2004 03:37:25
Message: <411486b5@news.povray.org>
news:41147c75@news.povray.org...
Glad to help when I can. I live near Huntsville, Alabama, USA, where the
Marshall Space Flight Center is. They do a lot of aerospace stuff. Although,
I am neither a scientist nor mathematician. A bit out of my league. I just
like that kind of thing. Lleida looks like a good place (seen on www), near
a river valley (like here) with "old world" buildings. Our stuff only dates
back to 1815 A.D. or so.
Bob H.
Date: 7 Aug 2004 06:02:23
Message: <4114a8af$1@news.povray.org>
Ok. I have never been to Alabama, but I think it's a good place. I know some
people who have visited Alabama and they speaks very good of these place. If
you want you can visit my web site, is in Spanish, but I think that you can
understant a lot of things. My URL is: http://www.infonegocio.com/oleguervm
I'm not a good page web dessigner, I haven't got a lot of ideas. On the main
page I will see my photograf.
I'm an estudent and I like Pov-Ray.
I'm traying to situate the arrows, when I finish I will do the proteins. If
I have some problem about it I will notify you.
I wait your replay.
Best regards,
Oleguer
news:411486b5@news.povray.org...
city
have
Although,
near
dates
> Bob H.
Date: 9 Aug 2004 05:39:19
Message: <41174647$1@news.povray.org>
news:4114a8af$1@news.povray.org...
some
Has its good points, some bad, too. Everyplace does.
> If you want you can visit my web site, is in Spanish, but I think that you
can
main
Better web page than mine. :-) Interesting that you show astronomy, weather,
electronics stuff there, seems many people using POV-Ray have a tendancy
toward similar interests.
Good thing, I couldn't stop using POV-Ray since 1994 myself.
Just remember, I'm not the only one with answers around here. Lucky thing,
that, or people needing discussions or answers might get misdirected.
heh-heh!
Bob H.
Date: 9 Aug 2004 07:34:40
Message: <41176150@news.povray.org>
Hi again  Bob,
I have an other question. The question is: I'm finishing the picture and I
did the background a part of the picture. I want put the picture down and in
the middle, the picture only can hold some space, because I'll put other
things over the picture and on the left and right of it.
The background is a cloudy scene. How can I include the background in the
picture? and, how can I situate the picture?
Thanks.
Best regards,
Oleguer Vilella
news:41174647$1@news.povray.org...
> some
place.
you
> can
> main
weather,
> heh-heh!
> Bob H.
Date: 9 Aug 2004 19:38:27
Message: <41180af3$1@news.povray.org>
news:41176150@news.povray.org...
in
Hiya Oleguer.
I guess you want transparency of that picture so a cloud background shows
through it in part or all. Or maybe I'm guessing more than you are thinking
of doing, since you might only be asking about placing an image file within
a scene using clouds in the background so as to frame it in (around it).
Sometimes it is not easy to understand what a person is trying to do without
drawing a sketch when only said in a few words. Here's my idea of what you
asked about and it might be wrong:
/* default camera used (none stated) */
box {
  0, <1,1,0.001> // very thin box to hold picture
    image_map { jpeg "picture.jpg" transmit all 0.5 }
  } // the image will be 50% transparent
  translate <-0.5,-0.5,0> // first center it
  scale <X,Y,1>*Size // use resolution of original picture...
// Size is for scale factor that will fit into your scene and
// 0.01 would squeeze a 320x240 res. image into this example scene
  translate <0,-1,3> // still centered horizontally, down some, back
/* cloudy part of scene beyond +3 z to be in back of image */
Note that the transformation keywords (scale, rotate, translate) are out of
order from what I described in a previous message reply, this is so you can
center onto <0,0,0> first and change from then on with better control. How
you or others might go about doing this is of personal preference though,
since you could also try and position the image based on its lower-left
corner being at <0,0,0>. Depends on how you like to think of screen
coordinates and resolutions.
Anyway... you could also take a look at a great example scene file, already
inlcuded with POV-Ray, called screen.pov. It can be found in the
POV-Ray\scenes\incdemo folder. That allows you to place things within the
camera view while other things are placed in the scene. It isn't simple for
the "newbie" to figure out how to change, if you aren't adept at this sort
of stuff, but you could be okay with it so I mention that as another
possibility.
Let me point out that when you ask different questions please ask everyone
(not just me, I'm not always here even if it looks like it now. ha ha) with
a new message post or else these tend to get lost in the old message
threads. Especially since the more people that see the questions the better
your answers can be.
If you manage to get any renderings or drawings done you would benefit
greatly by posting them to the povray.binaries.images group. That way
everyone can see what is really being attempted. Hopefully I've helped a
little.
Bob H.
