I'm interested start using POV-RAY to create photo-realistic perspective
views of architecture projects. I would receive the autocad files from the
clients and would give them the desired views. I've been studying the
Tutorial (wich is Great!) and I have some questions:
- Is Pov-Ray capable to REALLY predict (I'm not demanding 100% realism) the
illumination of a building (or one of its pieces) if I mix the raytracing
and radiosity methods? The textures and the materials work fine in this
approach?
- Suggestions of other softwres to support POV-RAY modeling of the scene?
- Any Methodology to the process? (maybe someone in the list works with
similar stuff)
Other comments are also very welcome.
Thanks,
Rodrigo
"Rodrigo Almeida" <rod### [at] hotmail com> wrote in message
news:40865001@news.povray.org...
> approach?
In the absence of any other reply, I'd offer a tentative yes to this. The
complication IMHO is that there is no obvious way to know what the realistic
finish would be to simulate the real-life radiosity of any particular material -
e.g. if you want to simulate concrete, what value of diffuse and amibient should
you use?
I believe you've already been pointed at some autocad->pov tools - you might
take a look at moray if you want to model other aspects of the scene, but the
pov sdl is really the way to go - it will give you far better access to macros
and utilities written by others, and far better control in the long run.
> similar stuff)
iirc there is a pov-user who does some very impressive architectural renderings
using pov - anyone have a name? a link?
No. Raytracing is only an approximation. A pretty good one, but only
an approximation. The stochastic illumination model used with 'radiosity'
is even a rougher approximation of illumination between surfaces. You can
get pretty images, but you can't expect them to be 100% accurate, even if
you have a 100% accurate model of your scene (which in itself is impossible
as well). You can approximate reality quite well, but 100% accuracy is just
not possible.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
the
raytracing
> an approximation.
SNIP
> not possible.
Well, didn't he say that he's not demanding 100% realism? ;-)
"Tim Nikias v2.0"
I somehow misread his statement inside the parentheses so that I
understood it to mean the complete opposite.
Perhaps I'm getting too old for this.
It depends on what you mean with "this". Reading? Then just get some glasses
and you're good to go. ;-)
"Tim Nikias v2.0"
Subject: Re: perspective views of arc projects
Date: 22 Apr 2004 12:14:55
Message: <4087ef7f@news.povray.org>
"pov sdl" is Pov sdk?
Thanks, I'll take a look at Moray, and for the lighting stuff I think with
the time ans the mistakes I will try to get more intuitive for the effects
and properties of each component...
"Tom Melly" <tom### [at] tomandlu co uk> a écrit dans le message de
news:40879311$1@news.povray.org...
the
raytracing
> > approach?
realistic
material -
should
> you use?
scene?
might
the
macros
> > similar stuff)
renderings
news:4087ef7f@news.povray.org...
"pov sdl" refers to the POV-Ray Scene Description Language.
-ross
In article <4087ef7f@news.povray.org>,
POV-Ray doesn't have a SDK (software development kit). Around here,
"SDL" usually refers to the Scene Description Language.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
