POV-Ray : Newsgroups : povray.newusers : Use of radiosity negates effect of normals.... Server Time
18 Oct 2026 06:24:18 EDT (-0400)
  Use of radiosity negates effect of normals.... (Message 1 to 10 of 10)
Subject: Use of radiosity negates effect of normals....
Date: 27 Mar 2004 22:03:17
Message: <40664075$1@news.povray.org>
...is this correct?   It's what I'm observing and goes along with what I
think I understand of the normal process-- just want to see if there's a
trick to get around it.
Subject: Re: Use of radiosity negates effect of normals....
Date: 28 Mar 2004 03:40:33
Message: <40668f81$1@news.povray.org>
hmmm... radiosity{normal on}? :)
Jaime
Date: 28 Mar 2004 11:56:11
Message: <cjameshuff-B028BD.11563428032004@news.povray.org>
In article <40664075$1@news.povray.org>,
It doesn't negate normals, it just doesn't take them into account for
radiosity lighting. Using "normal on" in the radiosity block will cause
it to take the normals into account, giving slower but more accurate
results.
http://tag.povray.org/
Date: 28 Mar 2004 12:56:29
Message: <406711cd$1@news.povray.org>
> results.
It is quite odd that they are turned off by default. I'd guess that
people using normals would also like to see them regardless of the
source of the light...
Severi S.
Date: 28 Mar 2004 22:50:04
Message: <40679cec$1@news.povray.org>
Okay but then does radiosity totally ignore both interior{fade_distance} and
media scattering?
I'm doing an architectural scene with a pool in it.  With radiosity on, the
pool bottom is completely white for a pigment {rgb 1} no matter how hight I
crank up the absorption, scattering, or fade distance negative exponent.
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-B028BD.11563428032004@news.povray.org...
> results.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
Date: 28 Mar 2004 22:55:41
Message: <40679e3d$1@news.povray.org>
Nevermind.  Media worked with hollow inserted in there.
Date: 28 Mar 2004 23:05:22
Message: <cjameshuff-96E5C3.23054728032004@news.povray.org>
In article <40679cec$1@news.povray.org>,
> media scattering?
Media will work if "media on" is included in the radiosity block. Again,
the default is off for speed. Interior attenuation should just work.
Date: 28 Mar 2004 23:08:01
Message: <cjameshuff-11183E.23082628032004@news.povray.org>
In article <40679e3d$1@news.povray.org>,
That must be the most common error with media. And it doesn't even need
to be that way...it would be better if the interior of an object were
always filled with the media specified for that object, and hollow only
controlled whether external media could permeate the object.
Date: 28 Mar 2004 23:10:14
Message: <cjameshuff-05157F.23103928032004@news.povray.org>
In article <406711cd$1@news.povray.org>,
Well, much of the time, the effects of normals + radiosity don't
contribute much to the scene, and taking them into account makes things
slower. As I recall, the earlier versions of radiosity never took
normals into account, it was an added feature, so backwards
compatibility may have been some part of the decision.
Date: 29 Mar 2004 22:04:12
Message: <4068e3ac$1@news.povray.org>
Golly, I wish all my questions based on failure to understand the docs
resulted in senior members saying that povray ought to work the way I think.
