My mesh2 file looks like this :
mesh2
vertex_vectors
n+1,
<x0, y0, z0>,
<xn, yn, zn>
normal_vectors
n+1,
<x0, y0, z0>,
<xn, yn, zn>
scale <1, 10, 1> <----- QUESTION
I wonder if scale affect only vertex_vectors or both : vertex_vectors and
normal_vectors.
Tahnks in advance
Gawel
Pierwszy ³yk z pucharu nauk przyrodniczych czyni ateist±, ale na dnie
pucharu czeka Bóg.
Werner Heisenberg
> normal_vectors.
It doesn't affect either. Transformations do not modify the mesh, they
just modify the incoming ray.
Hmmmm, it means that If I multiply by 10 in scale statement then during
rendering the postion of ray is divided by 10 ?
Gawel
Not the position, the ray vector itself, but basically yes.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
Ok, that was my way of thinking.
Gawel
