Can anyone give me pointers for lighting. If I want to light an object on a
tabletop, is there a quick way of getting a realistic sunlight on it. I've
tried making my light source yellowish ( the suns yellow/orange isnt it )
but I still end up with artificial looking lighting.
That's because sunlight is white.
What do you mean by "realistic sunlight" other than a white light source
far away (or using parallel light)?
The problem with my question is that I dont know what to ask for! My
tabletop scenes always seem rather flat and boring, I was wondering if
there is a quick piece of pov code for a decent light source. I've tried
area lights which give me a nice penumbra.
Is there a common light source object out there somewhere that many people
use in tabletop scenes that I dont know about?
"Warp" <war### [at] tag povray org> wrote in message
news:4020d37f@news.povray.org...
on a
I've
it )
x]
Warp -
Making your light source an area light certainly adds realism to the
scene when used well.
If you want more realistic lighting you are probably looking for
radiosity. Be warned, though, that depending on the scene you might
get a good-looking radiosity right away or (most often than not)
you'll be fine-tuning the radiosity settings for hours and days
before you get something decent.
Lighting is not, however, the only (nor even the most important) thing
that affects the realism of a scene. Textures (all its components,
pigment, finish and normal) are a very important part of making a
scene look realistic. Often a single texture alone can make an enormous
difference all the way from plastic CG-looking image to a photorealistic
one.
I recommend that you practice making good-looking textures.
(Focal blur is one feature which sometimes adds surprising amounts
of photorealism to a scene... Not always, though.)
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Also, I find that using multiple light sources can go along way. Throw a
bright, shadowless indigo light at a different location (color rgb <0.8,
0.9, 1> for example) and it will add a lot of depth. In reality, there is
rarely only one light source and you don't always need radiosity to get a
realistic effect. Look at a book cover once: often, you'll see that one side
of the face is lit with a yellowish light and the other side is light with
an indigo/cyan light. It makes a really neat effect.
If you're willing, we're interested in seeing your work if you post it on a
site and helping you out that way too. There are lots of tricks of light
(pun intended) that can turn a blah scene into something amazing.
I've already posted a couple of images in the binaries.images section namely
"Cactus halo" and "Rain Drops" but if you would like to help me out, look
there for one I've just posted called "Spilled Liquid" (Source included)
This is an example of an almost but never quite right table top image. If
you can give me some tips on how to improve it, adjusting the lighting etc I
would be very grateful.
Thanks.
"Dan P" <dan### [at] yahoo com> wrote in message
news:402117ff$1@news.povray.org...
side
a
"Felbrigg" <som### [at] microsoft com> wrote in message
news:40211dfa$1@news.povray.org...
namely
I
No problem! I'll download those tonight when I get home (I'm at work right
now). I look forward to seeing your efforts!!!
news:40214056@news.povray.org...
> namely
look
If
etc
> I
NICE JOB, Felbrigg! JC had a good point about the background too. When we
have things that are reflective, we need something to reflect to make it
more intresting and make it stand out a bit. Another, different colored
light source in front and to the right gives it that extra something that
brings it alive (modified example follows):
#include "textures.inc"
#include "shapes.inc"
#declare SnakeWood =
texture { /* Bottom wood-grain layer */
wood
turbulence 0.05
color_map {
[0.00 rgb <0.58, 0.45, 0.23>]
[0.34 rgb <0.65, 0.45, 0.25>]
[0.40 rgb <0.33, 0.23, 0.13>]
[0.47 rgb <0.60, 0.40, 0.20>]
[1.00 rgb <0.25, 0.15, 0.05>]
finish {
crand 0.02
//ambient 0.32
diffuse 0.63
phong 0.2
phong_size 10
normal { bumps 0.05 }
texture { /* top layer, adds small dark spots */
bozo
color_map {
[0.0 rgbt <1.00, 1.00, 1.00, 1.00>]
[0.8 rgbt <1.00, 0.90, 0.80, 0.80>]
[1.0 rgbt <0.30, 0.20, 0.10, 0.40>]
scale 0.25
// New stuff -- DAP
light_source
<60, 20, -50>
color rgb <0.2, 0.25, 0.3>
shadowless
sky_sphere
pigment
wrinkles
color_map
[0, rgb <0, 0, 0> ]
[1, rgb <0.7, 0.6, 0.5> ]
scale <0.1, 0.1, 0.1>
light_source {<-20, 20, 0> color White area_light <5, 0, 0>, <0, 0, 5>, 11,
11 adaptive 1 jitter photons { refraction on reflection on } }
location <0,10,-25> look_at <0,0,0>
//background { Black }//color <0.25,0.35,0.80> }
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-15,0>
translate <2,1,10>
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-16,0>
translate <2,1,-9>
cylinder{
<-1,-1,-1>,
<1,1,1>,
1
pigment { White*2 }
scale <1,5,1>
translate <-7,3,0>
plane { <0, 1, 0>, -0.001
texture { SnakeWood }//pigment { checker pigment{Red},
pigment{White} } scale <10,10,10> rotate <0,43,0>}
#declare Point1 = <-10,1,10>;
#declare Point2 = <-10,1,0>;
#declare Point3 = <-10,1,-10>;
#declare Point4 = <0,1,-10>;
#declare Point5 = <10,1,-10>;
#declare Point6 = <15,1,2>; //<10,1,0>;
#declare Point7 = <10,1,2>; //<10,1,10>;
#declare Point8 = <0,1,10>;
#declare Point9 = <-14,1,12>; //<-10,1,10>;
#declare Point10 = <-10,1,0>;
#declare Point11 = <-10,1,-10>;
merge {
// outside of the puddle
sphere_sweep {
cubic_spline
11,
Point1,1
Point2,1
Point3,1
Point4,1
Point5,1
Point6,1
Point7,1
Point8,1
Point9,1
Point10,1
Point11,1
// inside of the puddle
prism {
cubic_spline
0, // sweep the following shape from here ...
2, // ... up through here
11, // the number of points making up the shape ...
<Point1.x,Point1.z>,
<Point2.x,Point2.z>,
<Point3.x,Point3.z>,
<Point4.x,Point4.z>,
<Point5.x,Point5.z>,
<Point6.x,Point6.z>,
<Point7.x,Point7.z>,
<Point8.x,Point8.z>,
<Point9.x,Point9.z>,
<Point10.x,Point10.z>,
<Point11.x,Point11.z>
hollow
Clear // rgbt <0.858824,0.576471,0.439216>
finish {
reflection { 0.1,0.8 }
interior {
ior Water_Ior
translate <0,-1.5,0>
I just noticed on more thing that I think helps too: Adding a specular
highlight to the water. Sometimes, just using specular highlights instead of
reflections can make some interesting stuff. Here is the new code:
wood
turbulence 0.05
color_map {
finish {
crand 0.02
//ambient 0.32
diffuse 0.63
phong 0.2
phong_size 10
bozo
color_map {
scale 0.25
// New stuff -- DAP
light_source
<60, 20, -50>
shadowless
sky_sphere
pigment
wrinkles
color_map
[0, rgb <0, 0, 0> ]
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-15,0>
translate <2,1,10>
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-16,0>
translate <2,1,-9>
cylinder{
<-1,-1,-1>,
<1,1,1>,
1
pigment { White*2 }
scale <1,5,1>
translate <-7,3,0>
merge {
sphere_sweep {
cubic_spline
11,
Point1,1
Point2,1
Point3,1
Point4,1
Point5,1
Point6,1
Point7,1
Point8,1
Point9,1
Point10,1
Point11,1
prism {
cubic_spline
hollow
finish {
specular 0.5
interior {
ior Water_Ior
This kinda gives you the coffee look you were asking about. I dunno, I think
it still kinda looks like gravy though.
Mmmmmn, gravy.
wood
turbulence 0.05
color_map {
finish {
crand 0.02
//ambient 0.32
diffuse 0.63
phong 0.2
phong_size 10
bozo
color_map {
scale 0.25
// New stuff -- DAP
light_source
<60, 20, -50>
shadowless
sky_sphere
pigment
wrinkles
color_map
[0, rgb <0, 0, 0> ]
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-15,0>
translate <2,1,10>
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-16,0>
translate <2,1,-9>
cylinder{
<-1,-1,-1>,
<1,1,1>,
1
pigment { White*2 }
scale <1,5,1>
translate <-7,3,0>
merge {
sphere_sweep {
cubic_spline
11,
Point1,1
Point2,1
Point3,1
Point4,1
Point5,1
Point6,1
Point7,1
Point8,1
Point9,1
Point10,1
Point11,1
prism {
cubic_spline
hollow
rgbft <0.2, 0.16, 0, 0.8, 0.3>
//Clear // rgbt <0.858824,0.576471,0.439216>
finish {
reflection { 0.1,0.9 }
specular 0.5
interior {
ior Water_Ior
Oh, and I forgot about the table too! A little reflection there and a little
specular highlight and BAM (to steal from Emeril)!
wood
turbulence 0.05
color_map {
finish {
crand 0.02
//ambient 0.32
diffuse 0.63
phong 0.2
phong_size 10
bozo
color_map {
scale 0.25
// New stuff -- DAP
light_source
<60, 20, -50>
shadowless
sky_sphere
pigment
wrinkles
color_map
[0, rgb <0, 0, 0> ]
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-15,0>
translate <2,1,10>
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-16,0>
translate <2,1,-9>
cylinder{
<-1,-1,-1>,
<1,1,1>,
1
pigment { White*2 }
scale <1,5,1>
translate <-7,3,0>
finish { specular 0.3 reflection 0.15 }
merge {
sphere_sweep {
cubic_spline
11,
Point1,1
Point2,1
Point3,1
Point4,1
Point5,1
Point6,1
Point7,1
Point8,1
Point9,1
Point10,1
Point11,1
prism {
cubic_spline
hollow
finish {
specular 0.5
interior {
ior Water_Ior
On Wed, 4 Feb 2004 16:34:56 -0000, Felbrigg <som### [at] microsoft com> wrote:
> namely
> If
> etc I
> Thanks.
>> is
>> a
> side
>> with
>> on
> a
If you are still interested google "three point lighting"
http://www.3drender.com/light/3point.html
This link's quite basic but still worth a look at, more advanced stuff is
also available on google
Hope it's of use to you.
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
On Wed, 4 Feb 2004 16:34:56 -0000, "Felbrigg" <som### [at] microsoft com> wrote:
> If you can give me some tips on how to improve it, adjusting the lighting etc I
Interesting reading here. Again basic but that is what you need to start out
with.
http://www.cybercollege.com/indexall.htm
Lighting starts here
http://www.cybercollege.com/tvp027.htm
Regards
Where to begin?
The second coloured light, had me foxed at first, I couldn't see the
difference until I opened "before" and "after" side by side in paint shop.
It does improove the scene - Good Tip.
Specular highlighting, hmm, rendered it despite my misgivings and at first
I thought I was right and you were wrong, again, side by side in Paint shop
and WOW, it is better, you were right. It gives better definition to the
spill, allowing the liquids edge to look truely curved.
Coffee colouring, nice. I'd tried rgbf and rgbt but you hit me with a new
one there, rgbft, again WOW.
Reflection and specular on the table, didn't see that one coming. Took me a
while to see a difference, It seems to have made the light source have a
sharper definition on the table top. Is that it? Can you give me any
pointers as to why you suggested this, what am I missing?
I'm struggling with this lighting stuff, so much of it seems
counter-intuitive to me. Your pointers have been really eye - opening.
Thanks very much.
P.S. I see from your other posts your a 'C' man. Scary stuff, the nearest
I've got to that is C# what I call "the laymans C". Do you know if it
possible to use C# to fire off PovRay like (i think) Moray does. I've often
thought about writing a Win32 app to automate some animation experiments,
thus freeing me from the clock and frames constraints.
news:4021b140$1@news.povray.org...
little
> pigment {
> wood
> turbulence 0.05
> color_map {
> finish {
> crand 0.02
> //ambient 0.32
> diffuse 0.63
> phong 0.2
> phong_size 10
> pigment {
> bozo
> color_map {
> scale 0.25
> // New stuff -- DAP
> light_source
> <60, 20, -50>
> shadowless
> sky_sphere
> pigment
> wrinkles
> color_map
> [0, rgb <0, 0, 0> ]
11,
> camera {
> box {
> <-1,-1,-1>,
> <1,1,1>
> texture {
> pigment { Red }
> scale <2,2,2>
> rotate <0,-15,0>
> translate <2,1,10>
> box {
> <-1,-1,-1>,
> <1,1,1>
> texture {
> pigment { Red }
> scale <2,2,2>
> rotate <0,-16,0>
> translate <2,1,-9>
> cylinder{
> <-1,-1,-1>,
> <1,1,1>,
> 1
> texture {
> pigment { White*2 }
> scale <1,5,1>
> translate <-7,3,0>
> merge {
> sphere_sweep {
> cubic_spline
> 11,
> Point1,1
> Point2,1
> Point3,1
> Point4,1
> Point5,1
> Point6,1
> Point7,1
> Point8,1
> Point9,1
> Point10,1
> Point11,1
> prism {
> cubic_spline
> hollow
> texture {
> pigment {
> finish {
> specular 0.5
> interior {
> ior Water_Ior
In article <402233b2$1@news.povray.org>,
You'll learn to see this kind of thing more easily...just takes time and
practice. Before long you won't be able to stop. YKYBRTTLW...
Bad advice, IMO. The most realistic method that I've found is to use an
entirely transparent texture (a pigment with rgbf 1), and media or
interior attenuation for coloring. A colored transparent texture is like
a thin film covering the coffee, but this simulates color throughout the
body of the coffee.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: <chr### [at] tag povray org>
http://tag.povray.org/
news:402233b2$1@news.povray.org...
> Where to begin?
first
shop
The higher the specular value, the more defined the highlight becomes.
a
It added a highlight to the table. The trick is that it makes the surface
look less uniform.
> Thanks very much.
No problem! :-)
often
Sure, you can fire off POV-ray with pretty much any language -- it's just a
matter of running pvengine.exe. My job allows me to do a lot of different
programming languages so I get a really different perspective sometimes.
I'm glad I was able to help and I really liked that scene! It would be the
perfect scene for a tutorial too.
"Christopher James Huff" <cja### [at] earthlink net> wrote in message
news:cjameshuff-B435B0.09055805022004@news.povray.org...
> body of the coffee.
Thanks for the tip! It makes sense to make the actual liquid itself the
color and not just the skin around the outside. The reason I did it that way
was for speed, really; I find interior media to really slow down my
renderings and I like to do a lot of animation with motion blurs so I throw
out a lot of frames. However, for a still-shot, I think Chris is definitely
right here -- it'll make the light interact with the coffee better.
In article <402320ab$1@news.povray.org>,
Absorbing media will have a much lesser impact on speed than scattering
media, especially when there's no variation in density to sample. And
interior attenuation is very fast, because it never has to handle
variable density and can use a much simpler method to compute the
attenuation.
In article <40231f9d$1@news.povray.org>,
The higher the specular value, the brighter it becomes, specular 1
giving full brightness at the brightest points of the highlight. The
"roughness" parameter controls the "sharpness" of the highlight...small
values will give a more hard, highly polished look.
news:cjameshuff-5E6769.10274006022004@news.povray.org...
> attenuation.
Oh, I see what you mean. I was basing that perception on scattering media,
not absorbing media. I'm really glad I've been reading these newsgroups --
it's been having a very positive impact on my scenes. Thanks, Chris!!!
> phong 0.2
> phong_size 10
I've noticed some people use phong, while others use specular. I've always
been one to use specular, because it's more "accurate", but I've noticed
some of the best scenes tend to use phong.
What do people prefer and why?
I've hit the end on this scene now. Not the end of learning by a long way,
thanks to everyone, and for those who want it, heres the final cut of the
code.
wood
turbulence 0.05
color_map {
finish {
crand 0.02
//ambient 0.32
diffuse 0.63
phong 0.2
phong_size 10
bozo
color_map {
scale 0.25
//light_source {<-20, 20, 0> color White area_light <5, 0, 0>, <0, 0, 5>,
11, 11 adaptive 1 jitter photons { refraction on reflection on } }
light_source {<-20, 20, 0> color White photons { refraction on reflection
on } }
light_source { <60, 20, -50> color rgb <0.2, 0.25, 0.3> shadowless }
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-15,0>
translate <2,1,10>
box {
<-1,-1,-1>,
<1,1,1>
pigment { Red }
scale <2,2,2>
rotate <0,-16,0>
translate <2,1,-9>
cylinder{
<-1,-1,-1>,
<1,1,1>,
1
pigment { White*1.1 }
//finish { ambient 0.2}
scale <1,5,1>
translate <-7,3,0>
SnakeWood rotate <0,32,0>
//pigment { checker pigment{Red}, pigment{White} } scale
merge {
sphere_sweep {
cubic_spline
11,
Point1,1
Point2,1
Point3,1
Point4,1
Point5,1
Point6,1
Point7,1
Point8,1
Point9,1
Point10,1
Point11,1
prism {
cubic_spline
hollow
finish {
specular 0.5
interior {
ior Water_Ior
//ior 1.33
media {
absorption < 0.7, 0.8, 0.98>}
"Mike Raiford" <mra### [at] hotmail com> wrote in message
news:4023c0d4$1@news.povray.org...
> > phong 0.2
> > phong_size 10
That's interesting -- I never use phong, but I would think they are the same
thing, aren't they Chris? Maybe people who make the best scenes use phong
because they are long-time users of POV-ray and phong used to be specular
(or, was it, I'm not sure -- I don't have POV-ray at work).
This is a really good question. If anybody will know the answer, it will
definitely be Chris; he's got the internals down and then some :-)
"Dan P" <dan### [at] yahoo com> wrote in message news:4023cb35> That's
IIRC, in the tutorial that came with earlier versions of POV-Ray, they used
phong, but specular has been available since 0.9b (and probably earlier ...)
Comparing them, they seem to yeild identical results, though, the difference
seems to be a matter of syntax... I think
news:4023cc8f$1@news.povray.org...
phong
specular
used
difference
There are a lot of things in POV-Ray that are from the olden days. I wonder
when the point will come where we phase those out so that the language
doesn't become confusing? (I don't think it is there yet, although I still
struggle with the media statement a lot).
In article <4023cb35$1@news.povray.org>,
Despite my lack of post-college experience?
Okay, here it goes:
They are definitely not the same thing. Phong is the older shading
method, and is very simple mathematically, computationally cheap, but
not very accurate. In terms of POV code, the equation used is:
phongAmt*surfaceColor*pow(vdot(reflectionVector, lightVector), phongSize)
The reflection vector is the direction a reflected ray would go, the
light vector is a vector pointing towards the light source. When the two
line up, their dot product equals 1, and the highlight is the brightest
where you would see a reflection of the light. When the two are
perpendicular, the result is 0, and the highlight drops to nothing.
Specular uses a different and more physically accurate highlight
function:
specularAmt*surfaceColor*pow(vdot(halfPt, normal), 1/roughness)
where halfPt is halfway between the ray origin and the light source. It
is also brightest at the points where the reflection of the light source
would be visible, but the falloff is different.
If metallic is specified, a Fresnel reflection function is used. It
takes the intensity part of the above calculation and adds some
additional calculations based on the angle of the surface to the light:
specIntensity = specularAmt*pow(vdot(halfPt, normal), 1/roughness)
F = abs(acos(vdot(normal, lightVector))/(pi/2))
F = 0.014567225/sqr(F - 1.12) - 0.011612903
F is then clamped to the range 0-1, and the final highlight color is:
lightColor*specIntensity*(1 + metallicAmt*(1 - F)*(surfaceColor - 1))
This function is based on actual measurements of real-world surfaces,
and is the most realistic highlight for metallic objects.
news:cjameshuff-E67770.13341606022004@news.povray.org...
same
phong
specular
I'm not falling for any more flame-bait, Chris.
Great post, though.
news:4023c200$1@news.povray.org...
way,
> code.
Beeeeeeeooootiful!
