POV-Ray : Newsgroups : povray.newusers : Draw Vistas Option Server Time
18 Nov 2026 02:37:58 EST (-0500)
  Draw Vistas Option (Message 1 to 19 of 19)
Subject: Draw Vistas Option
Date: 31 Jan 2004 20:13:49
Message: <401c52cd$1@news.povray.org>
I've got a couple quick questions.  I'm using the Draw_Vistas option or +UD
flag to test a CSG to see if I should be using some manual bounding boxes.
(1)  What is the significance of the color of the box this options draws on
the render window?  I've seen red boxes and blue boxes and I can't see any
reason behind what gets a blue box and what gets a red box.
(2)  I learned rather fast that when testing my CSG that if I just had a
very simple piece I was testing that I also needed the +MB0 flag turned on.
However I could have as few as 3 frame level objects and I no longer needed
the +MB0 flag.  The documentaion says the default setting is +MB25.  What is
the relationship between the number of "objects" used in this flag and what
the message window refers to as "frame level objects"?
Thanks,
Carl
Subject: Re: Draw Vistas Option
Date: 31 Jan 2004 21:04:56
Message: <cjameshuff-88205F.21045931012004@news.povray.org>
In article <401c52cd$1@news.povray.org>, "Carl Hoff" <hof### [at] wtnet>
From the code, it looks like blue boxes are compound objects, red boxes
are lone objects.
You have 3 frame level objects and the default +MB setting, and still
get bounding slabs?
The default is 25, and the number considered is the number of frame
level objects. In fact, whether or not to build the slabs is decided
right after printing that information, in Build_Bounding_Slabs() in
bbox.cpp. The code's a little odd, but should work as expected. Maybe
there's an .ini file setting or something overriding the default...
http://tag.povray.org/
Date: 31 Jan 2004 21:05:24
Message: <yCUPfAAwzFHAFw0g@econym.demon.co.uk>
I guess that what got documented is the default default. What the POVRay
executable would do if nothing else changed the setting.
The supplied version of the master POVRAY.INI contains this code, which
countermands that default.
; Sets minimum number of objects before auto bounding kicks in.
Bounding_Threshold = 3
Which is the verbose way of saying +MB3.
If you remove that setting from POVRAY.INI then you'll find that scenes
with less than 25 frame level objects have no bounding boxes.
Mike Williams
Gentleman of Leisure
Date: 31 Jan 2004 23:54:11
Message: <401c8673@news.povray.org>
> boxes are lone objects.
Thanks, that fits with what I've seen I believe.
> still get bounding slabs?
Yes.
> frame level objects. In fact, whether or not to build the slabs is
> decided right after printing that information, in
> Build_Bounding_Slabs() in bbox.cpp. The code's a little odd,
> but should work as expected. Maybe there's an .ini file setting
According to Mikes post the master POVRAY.INI file sets
it to 3.  I haven't checked but that fits with what I'm seeing.
Thanks for the help guys,
Carl
Date: 1 Feb 2004 00:32:10
Message: <401c8f5a@news.povray.org>
Other couple questions that are related to this topic.  Here is a piece of
code from the CSG that I'm trying to optimize.
  #declare rear_tire = difference {
    sphere {<0, 85, 0>, 85 scale <1,1,.2>}
    union {
      cone {<0, 85, 20>, 50 <0, 85, -20>, 60}
      cone {<0, 85, -20>, 50 <0, 85, 20>, 60}
    bounded_by { box {<-85,0, -13>, <85,170, 13>} }
I can tell by viewing the bounding slabs with the +UD option that this has a
tighter bounding slab then it would if I didn't specify a bounded_by box.
First question: Why?  I did not use the -UR option and the documentation
says "To turn off the automatic removal of manual bounds you should specify
Remove_Bounds=off or use -UR. The default is Remove_Bounds=on."  Isn't the
above a manual bound?
Second question:  In terms of optimization does it make any difference if
the above union is replaced with a merge?  I also just now spotted this line
in the documentation "The CSG difference operation takes the intersection
between the first object and the inverse of all subsequent objects."  I just
verified that the above union statement isn't even needed. Would removing it
cause it to render faster?  Its a little easier for me to follow the code if
I leave it in there.
Thanks,
Carl
Date: 1 Feb 2004 03:44:04
Message: <sM0ocAAwtLHAFwWE@econym.demon.co.uk>
>    union {
The automatic bounding slab is big enough to contain the sphere. POV
isn't smart enough to work out beforehand how the difference reduces the
size of the bounding slab, so it has to use the size of the object
you're differencing from.
If you print out the size of the automatic bounding slab by using
#include "strings.inc"
#debug concat( VStr(min_extent(rear_tire)), "  ",
               VStr(max_extent(rear_tire)), "\n")
you'll get <-85,0,-17>, <85,170,17>. Observe that 17 is 85 scaled by .2.
It's easy to run the comparison and observe the statistics in the
message pane. The stats are identical for union and merge, so that makes
no difference. Removing the union entirely reduces the number of "CSG
Intersection" tests and leaves all the other stats the same, so it would
render fractionally faster.
Other things that you might have considered are adding a bounding box
for the union:
    union {
      bounded_by {box {<-60,35,-13><60,145,13>}}
which goes slightly faster than your original code, but not as fast as
omitting "union".
You could also have considered using a non-box bounding object, like
    bounded_by { sphere {<0, 85, 0>, 85 scale <1,1,.2>} }
which sometimes gives an improvement when the bounding shape fits more
tightly than a box and is quick to test. In this case it runs very
slightly slower than using a bounding box.
Overall, you're probably not going to find a great deal of improvement
when trying to optimise a simple object like this. POV is quite fast at
performing sphere and cone tests, so replacing a few of those tests by
bounding tests is only going to produce minor improvements.
Mike Williams
Date: 1 Feb 2004 10:04:59
Message: <401d159b@news.povray.org>
> POV isn't smart enough to work out beforehand how the
> difference reduces the size of the bounding slab, so it has to use
> the size of the object you're differencing from.
Thanks, but that much I expected and understand.  What I didn't
understand is why POV-Ray would use my manual bounding
without the -UR option?  The documentation says the default is
to remove all manual bounds.  So I only expected to see a
difference when I used -UR.  That wasn't the case.
Thanks for this code.  I'm sure I'll find this useful.
> scaled by .2.
Yes, that is what I expected the default would be.
> that makes no difference. Removing the union entirely reduces
> the number of "CSG Intersection" tests and leaves all the other
> stats the same, so it would render fractionally faster.
Thanks.  Yes, I need to pay more attention to the message pane.
I presently don't understand all the info printed there but I'll learn
> box for the union:
>     union {
I got the impression from the documentation that its a bad idea to
manually bound unions so you are correct I hadn't even
considered this.
> fast as omitting "union".
Thanks.   This tells me that sometimes I should bound unions.
Wow!!!  I knew you could use a sphere as a bounding object but
I wasn't aware that it could be a scaled sphere.
> fits more tightly than a box and is quick to test. In this case it runs
> very slightly slower than using a bounding box.
I find that a little surprising as the scaled sphere is a much better fit.
If the sphere test is slower then a box test then I'm curious when
using a sphere as a bounding object would actually give an
improvement.  Could it be the scaling that's slowing it down?
I'll see if I can tell if there is a difference between these two:
bounded_by { box {<-85,0, -17>, <85,170, 17>} }
bounded_by { box {<-85,0, -85>, <85,170, 85>scale <1,1,.2>}  }
> improvement when trying to optimise a simple object like this.
> POV is quite fast at performing sphere and cone tests, so
> replacing a few of those tests by bounding tests is only going
Well the final CSG I'm playing with is far more complicated.
I'm starting with the simple stuff so that I have an idea what
I'm doing before I jump into the trickier stuff.
Thanks for all the help,
Carl
Date: 1 Feb 2004 12:41:27
Message: <401d3a47$1@news.povray.org>
This is cut from a post of mine over in the images area that I think might
serve me better here.
I'm still playing with the Draw_Vistas option and I'm still not
sure if I need the -UR flag to be able to use my manual bounding
or not.
With these options (+UD +MB0) try the following:
  camera {location <-500, 0, 0> look_at <0, 85, 0> angle 36}
  light_source { <110, 5, -500> White}
    bounded_by { box {<-85, 0, -13>, <85, 170, 13>} }
  object {rear_tire pigment {Blue}}
Now comment out the bounded_by line. You'll be able to
see the difference even without the -UR flag.
However while playing with this code using the same options:
  camera {location <0, 0, -500> look_at <0, 85, 0> angle 36}
  #declare rear_axle = sphere {<0, 85, 0>, 17}
  #declare rear_hub = difference {
    cylinder {<0, 85, 1>, <0, 85, -1>, 60}
    object {rear_tire}
    object {rear_axle}
    bounded_by { box {<-56, 29, -2>, <56, 141, 2>} }
  object {rear_hub pigment {Blue}}
I note that even with the -UR flag on, the bounding slab
size doesn't visual change from the default.
Even replace the bounded_by line with this:
    bounded_by { box {<-50, 29, -2>, <56, 141, 2>} }
    clipped_by {bounded_by}
And you will see the shape is clipped but the bounding box
hasn't moved.  I'm using [800x600,AA 0.3] if that makes
a difference.
But if I replace it with:
    bounded_by { box {<0, 29, -2>, <56, 141, 2>} }
Now the bounding slap IS where it should be even without
the -UR flag.
I even tried this:
    bounded_by { box {<0, 29, -2>, <56, 1000, 2>} }
The shape is clipped BUT the bounding slap grew back in
the x-direction and NOT in the y-direction.  Why?
I get the smallest bounding slab and the shape I want if I
take the bounded_by statement off altogether and replace
the cylinder with:
cylinder {<0, 85, 1>, <0, 85, -1>, 56}
So this Draw_Vistas option isn't behaving in what I'd consider
a predictable manner.  Is what I've seen called the bounding
slab a 2D projection of the bounding box?  It sure looks like
something else when I use:
And see the object clipped and I see a short fat box when
I'd expect to see a thin tall box that extends to the top of
the screen.  Can anyone tell me what is going on here?
Date: 1 Feb 2004 14:40:18
Message: <RijHnBAvQVHAFwTO@econym.demon.co.uk>
I don't think that scaling ever slows down any ray tests. What happens
is that all the scaling, rotations and translations for an object are
combined during parsing into a single transformation matrix. Applying
the resulting matrix goes at the same speed whatever type of
transformation is being applied.
Mike Williams
Date: 1 Feb 2004 15:06:33
Message: <vCFIPEA1vVHAFw3v@econym.demon.co.uk>
>or not.
One of the things that is going on is that POV-Ray is reasonably smart
about knowing when it is likely to be helpful to remove manual bounding.
+UR doesn't remove all manual bounds, only manual bounds where POV-Ray
thinks it can do better. In this case, it has trusted you to provide
better manual bounds than it would have applied automatically.
>    object {rear_tire}
>    object {rear_axle}
In this case, the automatic bounding box calculated by POV-Ray is
*considerably* better than the one you provided manually. I would have
though that -UR would force it to use the manual bounding. However, the
documented reason why you would want to keep inefficient manual bounds
doesn't apply in this case, and perhaps POV-Ray is smart enough to have
worked that out.
Your manual bounding box has a volume of 50,176 cubic units, whereas the
automatic bounds calculated by POV-Ray has a volume of 28800 cubic
units. A quick experiment shows that POV-Ray is choosing the bounds that
have the lower volume irrespective of the UR setting.
Try making the Z values of your manual bounding box a closer fit.
Mike Williams
Date: 1 Feb 2004 16:36:09
Message: <401d7149@news.povray.org>
> happens is that all the scaling, rotations and translations for an
> object are combined during parsing into a single transformation
> matrix. Applying the resulting matrix goes at the same speed
> whatever type of transformation is being applied.
Interesting... But is this case you are then fitting a scaled sphere
inside a scaled sphere bounding shape and telling me its faster
when its bound by a box.  What sort of shape would render
faster being bound by a sphere if its not a sphere?  It doesn't
sound like using a sphere as a bounding shape would be all that
useful.  I assume I'm missing something.
Carl
Date: 1 Feb 2004 17:03:25
Message: <401d77ad$1@news.povray.org>
> smart about knowing when it is likely to be helpful to remove
> manual bounding. +UR doesn't remove all manual bounds, only
> manual bounds where POV-Ray thinks it can do better. In this
> case, it has trusted you to provide better manual bounds than it
Bases on what you say below I assume "better" in this case means
lower volume.  I'd think cross-sectional area relative to the camera
would be a better judge of quality but I'm sure its much easier to
calculate volume.  I think I can follow.  +UR doesn't force the
manual bounds to be removed it just forces this quality check.
> POV-Ray is *considerably* better than the one you provided
> manually.
Volume wise yes but mine shound have had a smaller bounding
slab with the +UD option which I think means that particular
picture would have rendered faster as fewer pixels would have
been checked for ray intersection with that shape.
By the way the reason I didn't use:
    bounded_by { box {<-56, 29, -1>, <56, 141, 1>} }
is I was worred about Co-incident Surface problems.  Note
what happens if you use:
Should this not be an issue if just the bounded_by statement
is used?
> I would have though that -UR would force it to use the manual
> bounding. However, the documented reason why you would
> want to keep inefficient manual bounds doesn't apply in this
> case, and perhaps POV-Ray is smart enough to have worked
> that out.
So even with the -UR flag you are telling me it does the quality
check and uses what it thinks is better?  So just what is the
difference between -UR and +UR?  Is there one?
> units, whereas the automatic bounds calculated by POV-Ray
> has a volume of 28800 cubic units.
I'm guessing 120*120*2.
> bounds that have the lower volume irrespective of the UR
> setting.
Interesting... sounds like you are coming to the same
conclusion I am.  That being the the UR flag isn't doing
anything.
> closer fit.
Done... and yes it works.  I see the default bounding box has
Co-incident surfaces so I take that to mean I can use them
too.
Thanks,
Carl
Date: 2 Feb 2004 00:57:16
Message: <hQvAYCAgNeHAFwGJ@econym.demon.co.uk>
Such a cross section area might be better for the vista buffers,
but the bounds are often used when considering rays from other
directions, for example when tracing shadows and reflections.
My experiments show that, in this situation, the check happens with both
+UR and -UR. I'm beginning to wonder if they've sneakily removed the UR
functionality and forgotten to remove it from the documentation.
>> manually.
Tight bounds are generally more important than tight vista buffers. In
this case, if you force POV to use those manual bounds (not easy) then
it runs 40% slower than using the automatic bounds. POV was right to
overrule you. This remains true even if you move the light source to the
same location as the camera (causing the shadow rays to point in the
same direction as the viewing rays). POV's automatic bounds are still
faster if there are no light in the scene.
>is used?
It's not an issue for bounded_by, but clipped_by is a CSG operation and
therefore it is an issue for that.
Even with these slightly more complicated objects, you are spending
hours of effort to make optimisations that are saving about 0.05 seconds
of tracing time.
Mike Williams
Date: 2 Feb 2004 00:57:19
Message: <6QeGIGAkXeHAFwEQ@econym.demon.co.uk>
Here's a rather artificial case where a bounding sphere is faster
#include "functions.inc"
camera { location  <0, 0, -4> look_at <0, 0, 0> angle 50}
light_source {<-100,200,-100> colour rgb 1}
#declare Thing =
isosurface {
  function { x*x + y*y + z*z - 1 + f_noise3d(x*10, y*10, z*10)*0.3}
        max_gradient 5
        contained_by{sphere{0,2}}
        pigment {rgb 1}
  bounded_by {box {-1,1}}
  //bounded_by {sphere {0,1}}
object {Thing}
Mike Williams
Date: 2 Feb 2004 11:43:19
Message: <401e7e27@news.povray.org>
> #declare Thing =
> isosurface {
>         max_gradient 5
>         pigment {rgb 1}
> object {Thing}
Thanks... I see what I was missing now.
Carl
Date: 2 Feb 2004 12:05:54
Message: <401e8372$1@news.povray.org>
True.  I was over simplifying the problem.
> with both +UR and -UR. I'm beginning to wonder if they've
> sneakily removed the UR functionality and forgotten to remove
My thinking as well.
> In this case, if you force POV to use those manual bounds (not
> easy) then it runs 40% slower than using the automatic bounds.
Ok... may I asked how you forced it, since that is what I thought
the UR flag was for?  You've convined me that POV-Ray's
bounding was better then mine.  But I am curious how you tested
that.
> POV was right to overrule you. This remains true even if you
> move the light source to the same location as the camera
> (causing the shadow rays to point in the same direction as the
> viewing rays). POV's automatic bounds are still faster if there
I believe you.
> operation and therefore it is an issue for that.
Thanks.  That's one less thing I have to worry about.
> spending hours of effort to make optimisations that are saving
> about 0.05 seconds of tracing time.
True.  I'm doing this so I can learn what POV-Ray is doing.
I'll then try to optimize some of my much slower CSGs.  I'm
playing with the fast ones so I don't spend all my time waiting
whenever I make a tweak.  I know somewhere in my more
complicated CSGs there must be some big improvements to
be made.  I've got scenes that take weeks if not months to
render and they look simple compared to some of the stuff
I see posed here that takes hours.  Look at my post over in
the image area called "My second TRON subject".  I also
hope to play with animations so a 0.05 second improvement
per object per frame might pay off in the long run.  Even if
it doesn't I'm still learning alot.
Carl
Date: 2 Feb 2004 13:42:20
Message: <IH06tMAOnpHAFwyv@econym.demon.co.uk>
>> #declare Thing =
>> isosurface {
>>         max_gradient 5
>>         pigment {rgb 1}
>> object {Thing}
One interesting thing to note about this scene is that it behaves
differently with +UR and -UR.
With +UR, POV-Ray says "Warning: unnecessary bounding object removed"
and it renders *faster* without the bounds.
Mike Williams
Date: 2 Feb 2004 13:59:08
Message: <401e9dfc@news.povray.org>
> object removed" and it renders *faster* without the bounds.
That is interesting.  Any idea why?  Without any bounds doesn't
it check every ray for intersections with the object.  I would
have thought that would slow it down.
So the UR flag does do something... still not sure exactly what.
Carl
Date: 3 Feb 2004 13:54:49
Message: <5onv10p3tu1lqpe9sj7822rcjlp7p7il69@4ax.com>
On Sun, 1 Feb 2004 19:31:59 +0000, Mike Williams
You apply a 'bounded_by' object <B> to speed up the intersection tests
in those cases where <B> and the bounded object <O> are not
intersected (which requires that intersecting <B> is cheaper than
intersecting <O>).
You have to pay for it in those cases where <B> is intersected no
matter whether <O> is hit or missed by the ray.
Now assume two candidates <B1> and <B2> as 'bounded_by' object where
<B1> is cheaper to intersect than <B2> but <B2> better fits.
The latter means <B2> generates less 'false positive' intersections
where <O> is tested but missed by the ray.
Which of both candidates is the best one depends on the intersection
costs of <O>.
If <O> intersections are really expensive (as for a complicated
difference/intersection object) the lower number of 'false positive'
intersections of <B2> will outweigh the cheaper intersections of <B1>.
This may even change during scene development where you start with a
simple <O> object and end up with a complicated one.
But not each object needs to accumulate transformations.
For example a sphere doesn't create a TRANSFORM as long as it isn't
scaled unevenly such that it becomes a more general ellipsoid.
There are more objects (plane, triangle, ...) where only under certain
circumstances transformations are created/stored and from then on
accumulated.
Andreas
