POV-Ray : Newsgroups : povray.newusers : taking matrices to next frame Server Time
18 Oct 2026 07:28:10 EDT (-0400)
  taking matrices to next frame (Message 1 to 4 of 4)
Subject: taking matrices to next frame
Date: 27 Jan 2004 04:38:58
Message: <401631b2$1@news.povray.org>
Helllo,
I am trying to simulate the temperature flows in a plane, but to accieve
this i need to store all the local temperatures of the points in a array,
and use those values in the next frame to calculate the next step. Now is my
question: how do i store a matrix, to use it in the next frame?
I am familiar with writing and reading single values into .txt files with
the #write and #read statements. But it seams to be impossible to write a
full matrix (100x100) to a single file.
So if anyone can help me, it will be appreciated.
JWV
Subject: Re: taking matrices to next frame
Date: 27 Jan 2004 05:38:44
Message: <40163fb4@news.povray.org>
  Why would it be impossible? Just write each value in the array in a
loop and that's it.
  By the way, the easiest way of doing this is probably making your
code to write valid POV-Ray code to the file declaring the array
(ie. "#declare Matrix = array[100][100] { ...") and then #including
this file in the next frame.
Date: 27 Jan 2004 09:10:39
Message: <4016715f$1@news.povray.org>
IIRC Tim Nikias wrote some macros to do this sort of thing. Take a look at
http://www.nolights.de/download.html under the IO Macros link.
jim
Date: 27 Jan 2004 14:41:59
Message: <4016bf07$1@news.povray.org>
Hey, thanks for the plug! :-) Would've mentioned it just now, but you've
been here earlier.
As a note: as long as you don't try to save Strings in the array, the macros
work fine. They weren't coded to properly load Strings (as they require
quotation marks when rebuilding). I intend to write a macro for strings
someday as well, but now I'm too lazy for one, and too occupied for another.
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
