POV-Ray : Newsgroups : povray.newusers : Scaling question... Server Time
18 Oct 2026 08:16:16 EDT (-0400)
  Scaling question... (Message 1 to 22 of 22)
Subject: Scaling question...
Date: 25 Nov 2003 20:24:54
Message: <3fc400e6@news.povray.org>
Can anyone help me out here?
I'm trying to scale a shape in the z-direction but I want the scaling factor
to be a function of x.
Say for example I have the following cone:
cone {<0,0,0>, 5 <10,0,0>, 20}
And I want to take this shape and scale the such that the left (looking in
from -z) of the cone is scaled by 2*z and the right by 0.5*z so that when
viewed from above (the +y direction) the crosssection is a rectangle with
sides at + and - 10*z.
So far I haven't been able to insert a function into a scale command or a
matrix command.  This may be just a syntax question but I've been unable to
find my answer in the documentation.  I'd like to be able to do something
like:
 scale <1,1, -0.15*x+2>
Thanks if you can point me in the correct direction,
Carl
Subject: Re: Scaling question...
Date: 25 Nov 2003 21:03:06
Message: <3fc409da@news.povray.org>
Only linear transformations are possible with transformation matrices
(scales, rotates and translates are just shortcuts to equivalent
transformation matrices).
  What you are trying to achieve is a non-linear transformation which
is not possible with matrices.
  The way to go is most probably to create the cone as an isosurface
and then modify the input variables of the isosurface function
appropriately.
Date: 25 Nov 2003 21:40:24
Message: <cjameshuff-57BCFF.21392025112003@netplex.aussie.org>
In article <3fc409da@news.povray.org>, Warp <war### [at] tagpovrayorg>
A small terminology correction: the transformations POV-Ray can handle
are affine transforms. Rotate, scale, and shear are linear transforms,
translation is an affine transform. All linear transforms are affine
transforms. You're right in that what he's trying to accomplish is a
non-linear transform.
To go into more detail, linear transforms have the property that
transforming two points and adding them together gives the same result
as adding them together and then transforming that point. Affine
transforms such as those used by POV do not necessarily have this
property, though they must preserve collinearity (all points on a
straight line must transform to points on a straight line). In the case
of POV, they must also be invertible, you will get an error about a
"singular matrix" otherwise.
> appropriately.
Or just create the transformed version directly. Don't try to transform
a cylinder into a cone, just create a cone. To bend a tube, use a little
CSG. Or make a mesh and deform it, which is likely to be faster than an
isosurface, but will have problems with typical mesh artifacts like
faceting and polygonal edges.
http://tag.povray.org/
Date: 25 Nov 2003 23:27:39
Message: <FsgJnBAGpCx$EwP7@econym.demon.co.uk>
>appropriately.
There's an example of a non-linearly scaled sphere in my isosurface
tutorial:
<http://www.econym.demon.co.uk/isotut/substitute.htm#nls>
Mike Williams
Gentleman of Leisure
Date: 26 Nov 2003 12:12:31
Message: <3fc4deff@news.povray.org>
Thanks.  I'm glad it wasn't just me fighting a syntax problem though if it
had I guess that would have been the easiest to fix.
I've only been playing with POV-Ray now for about 2 months and as
yet haven't got to the point of playing with isosurfaces.  I guess its time
to learn.
If someone beats me to the bunch... what I'm trying now to find is the
equation I need to use for an isosurface that looks like:
(y/a1)^2+(z/b1)^2=1   in the x=0 plane
and
(y/a2)^2+(z/b2)^2=1   in the x=x0 plane
For my cases b1=b2 but I guess I should write this as general as possible.
I think the "contained_by" should be:
box {<0,+(max(a1,a2)),+(max(b1,b2))>,
        <x0,-(max(a1,a2)),-(max(b1,b2))>}
I'm not so sure about the threshold, accuracy, or max_gradient but I
think I'll get an idea once I start playing.
Thanks...
Carl
news:3fc409da@news.povray.org...
> appropriately.
M()}}
Warp -
Date: 26 Nov 2003 12:30:20
Message: <3fc4e32c@news.povray.org>
I think what I'm trying to do would keep all strait lines as strait lines
after the transformation.  Although lines that were parallel before the
transformation might not be after.  I also think it should be invertible
as long as the point where the z scaling factor becomes zero is
outside the object.
Well what I'm after isn't a cylinder or a cone, though it might be easier
to transform a cylinder into the shape I'm after then a cone come to
think of it.
> To bend a tube, use a little CSG.
I'm not trying to bend a tube either.  You know how a cone can be
used to connect two spheres to make a shape like you'd get with a
linear sphere_sweep.  I'm trying to connect these two spheres with a
similar shape.
sphere {<0,0,0>,a1 scale <1,1,b1/a1>}
sphere {<x0,0,0>a2 scale <1,1,b2/a2>}
Does that make it any clearer what I'm trying to do?
I haven't got around to playing with meshs either and as I don't want
to deal with the artifacts you mention I think I'll continue to work on
the isosurface approach.
Thanks...
Carl
Date: 26 Nov 2003 12:51:27
Message: <3fc4e81f@news.povray.org>
Thanks... I need all the tutorials I can find.  However yours
leaves me a little confused...
In your example you have:
#declare  P = function {x*x + y + z*z - 1}
isosurface {
  function { P(x,y*(1.05-y/5),z) }
Should P be the formula of a sphere?  In which case shouldn't
the function be x*x+y*y+z*z-1?  If that's not a typo I'm really
confused.  Hmmm... ok after looking closer I see you are substituting
in a y*y term for y when you call the function.  But that leaves me
wondering why you only scaled one of the y's?  I'm now curious how
that differes from:
#declare  P = function {x*x + y*y + z*z - 1}
isosurface {
  function { P(x,(1.05-y/5),z) }
I'll try it and find out.
Also... a more general question...
Is there a difference between these two as used in an isosurface?
isosurface {
  function { P(x,y,z) }
  threshold 0
and
#declare  P = function {x*x + y*y + z*z}
isosurface {
  threshold 1
Thanks,
Carl
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:FsgJnBAGpCx$EwP7@econym.demon.co.uk...
> >appropriately.
> tutorial:
> Mike Williams
Date: 26 Nov 2003 13:31:18
Message: <tRhT4BABBPx$EwZT@econym.demon.co.uk>
>isosurface {
>confused.
Yes it's a typo. it should be y*y
>isosurface {
>  threshold 0
>and
>isosurface {
>  threshold 1
There's no difference. Since I have a mathematical background I'm more
used to dealing with thinking about the first form.
Mike Williams
Date: 26 Nov 2003 14:29:02
Message: <XBNd8GAw6Px$Ew+j@econym.demon.co.uk>
>to learn.
>and
#declare aa=max(a1,a2);
#declare bb=max(b1,b2);
isosurface {
  function {
      pow((y/(a1+(a2-a1)*x/x0)),2)
     +pow((z/(b1+(b2-b1)*x/x0)),2)
     -1
  max_gradient 2.8
  contained_by{box{<0,-aa,-bb><x0,aa,bb>}}
Mike Williams
Date: 26 Nov 2003 15:17:32
Message: <3fc50a5c@news.povray.org>
  Nope. If parallel lines do not keep parallel after the transformation,
then there exist lines which do not keep straight after the transformation.
Date: 26 Nov 2003 19:39:27
Message: <cjameshuff-BB22F4.19373026112003@netplex.aussie.org>
In article <3fc50a5c@news.povray.org>, Warp <war### [at] tagpovrayorg>
Actually, they can remain straight with a transformation that makes
parallel lines non-parallel...scale two axii by the value of the third,
flipping everything around at the origin. It wouldn't be an affine
transform though, it would not be invertible (a singularity at a plane
going through the origin where all points transform to < 0, 0, 0>), and
it can not be expressed as a matrix.
Date: 26 Nov 2003 19:52:37
Message: <cjameshuff-E25C5A.19504126112003@netplex.aussie.org>
In article <3fc4e32c@news.povray.org>, "Carl Hoff" <hof### [at] wtnet> wrote:
That isn't the only constraint...
That is another constraint. Parallel lines must transform to parallel
lines.
> outside the object.
It doesn't work that way...the transform has a singularity, which makes
it non-invertible.
Well, those were just examples of commonly desired transformations that
are not possible.
> similar shape.
It sounds like you are looking for a supercone shape. Look in shapes.inc
for a macro for creating these..though you may have a hard time fitting
it to the capping ellipsoids. This transformation can not be done
directly in POV, you have to use either an isosurface, process a mesh,
or do it with CSG and existing primitives. The transformations possible
in POV are scaling (including reflection), rotation, translation,
shearing, and combinations of these.
http://mathworld.wolfram.com/AffineTransformation.html
Date: 26 Nov 2003 19:57:30
Message: <cjameshuff-72DA28.19553526112003@netplex.aussie.org>
In article <3fc4e81f@news.povray.org>, "Carl Hoff" <hof### [at] wtnet> wrote:
> isosurface {
That would expand to:
x*x + y*1.05 + y*y/5 + z*z - 1
Change the order to make what happens a little clearer:
x*x + y*y/5 + z*z - 1 + y*1.05
This is scaling the sphere along the y axis, and adjusting the radius
according to distance along the y axis.
No difference. However, I find it easier to adjust things when the
threshold is 0.
Date: 26 Nov 2003 20:54:07
Message: <3fc5593f@news.povray.org>
  Actually any shearing can be nade as a combination of rotations and
(uneven) scales, so technically it's not an independent transformation
in itself... :)
Date: 26 Nov 2003 22:08:03
Message: <cjameshuff-5438E0.22060826112003@netplex.aussie.org>
In article <3fc5593f@news.povray.org>, Warp <war### [at] tagpovrayorg>
> in itself... :)
True, but is is rather different conceptually, which is why I usually
mention it as a "fourth" transformation. These are just conventions, a
human categorization. You could say a rotation is just a reorientation,
or that they are all just matrix multiplications...
BTW, in linear algebra, the transformations are often broken down as:
contract (scale by a value < 1), dilate or expand (scale by value > 1),
reflect (scale by -1 on an axis), rotate and translate.
Date: 27 Nov 2003 10:14:16
Message: <3fc614c8@news.povray.org>
> > similar shape.
Thanks everyone.  After spending most of a day with this.  Thanks to
the help from Mike, I was able to create the isosurface I asked for,
which as Christopher points out above is (I believe) the same shape
you can get using a supercone.  Where most of the time was spent
however was tring to make the shape join smoothly with the capping
ellipsoids.  In the end I gave up and opted to move away from using
ellipsoids to using a torus filled in with a cylinder.  Two of these shapes
I could easily join smoothly with two cylinders and a prism.
By the way... thanks to pointing me to the shapes.inc file.  I see its
got this:
 Connect_Spheres(PtA, RadiusA, PtB, RadiusB).
It makes the work I spent to write this macro now look a little
silly:
  #macro sphere2fill(V1,R1,V2,R2)
    #local V2a = V2-V1;
    #local angle_z1 = VRotationD(<V2a.x, V2a.y, 0>, x, z);
    #local V2b = vaxis_rotate(V2a, z, angle_z1);
    #local angle_y2 = VRotationD(<V2b.x, 0, V2b.z>, x, y);
    #local V2c = vaxis_rotate(V2b, y, angle_y2);
    #local theta = asin((R1-R2)/V2c.x);
    cone {
      <R1*sin(theta), 0, 0>, R1*cos(theta)
      <V2c.x+R2*sin(theta), 0, 0>, R2*cos(theta)
      rotate -y*angle_y2
      rotate -z*angle_z1
      translate V1
As a way to say thank you here is another macro that I wrote that
smoothy fills in the space between 3 spheres when used with 3
sphere and 3 sphere2fill calls.  In other words it doesn't draw the
cones or the spheres.
  #macro sphere3fill(V1,R1,V2,R2,V3,R3)
    #local V2a = V2-V1;
    #local V3a = V3-V1;
    #local V3b = vaxis_rotate(V3a, z, angle_z1);
    #local V3c = vaxis_rotate(V3b, y, angle_y2);
    #local angle_x3 = VRotationD(<0, V3c.y, V3c.z>, -z, x);
    #local angle_x3p = VRotationD(<0, V3c.y, V3c.z>, z, x);
    #local V2d = vaxis_rotate(V2c, x, angle_x3);
    #local V3d = vaxis_rotate(V3c, x, angle_x3);
    #local V2dp = vaxis_rotate(V2c, x, angle_x3p);
    #local V3dp = vaxis_rotate(V3c, x, angle_x3p);
    #local angle_z5 = degrees(asin((R1-R2)/V2c.x));
    #local angle_x4 = degrees(asin(((((R2-R1)/(V2d.x))*V3d.x+R1)
        -(R3))/(V3d.z*cos(radians(angle_z5)))));
    #local V2e = vaxis_rotate(V2d, x, angle_x4);
    #local V3e = vaxis_rotate(V3d, x, angle_x4);
    #local V2ep = vaxis_rotate(V2dp, -x, angle_x4);
    #local V3ep = vaxis_rotate(V3dp, -x, angle_x4);
    #local V2f = vaxis_rotate(V2e, -z, angle_z5);
    #local V3f = vaxis_rotate(V3e, -z, angle_z5);
    #local V2fp = vaxis_rotate(V2ep, -z, angle_z5);
    #local V3fp = vaxis_rotate(V3ep, -z, angle_z5);
    #local minD = 2*min(R1,R2,R3);
    #local fill1 = prism {
      linear_spline linear_sweep -R1,-R1+minD,4
      <0,0>, <V2f.x,V2f.z>, <V3f.x,V3f.z>, <0,0>
    #local fill2 = prism {
      <0,0>, <V2fp.x,V2fp.z>, <V3fp.x,V3fp.z>, <0,0>
    merge {
      object {fill1
        rotate z*angle_z5
        rotate -x*angle_x4
        rotate -x*angle_x3
      object {fill2
        rotate z*angle_z5
        rotate x*angle_x4
        rotate -x*angle_x3p
      rotate -y*angle_y2
      rotate -z*angle_z1
      translate V1
Note the walls are as only as thick as the diameter of the
smallest sphere so this shape might be hollow.  Does anyone
know how to do the above without the hollow space?
And one last question about the ellipsoids problem.  I'm
convinced that the shape that smoothly joins two ellipsoids
is NOT a supercone as the shape doesn't intersect the
ellipsoids in a plane.  And even if I cut the super cone so
that it touches the ellipsoid at <0,0,0> in the x-y plane at
some non-zero x value smoothly and it also touches the
ellipsoid in the x-z plane smoothly at x=0 if both ellipsoids
have the same z extent, then those turned out to be the
only points of contact between the two surfaces.  So...
knowing that I have no idea how to find the isosurface that
would meet my needs.  Does anyone know how the
sphere_sweep call works?  Would it be possible to write
something like an ellipsoid_sweep?  If so I'm sure its way
over my head but maybe its something someone here will
want to play with.
Thanks again everyone,
Carl
Date: 27 Nov 2003 13:13:27
Message: <btPeXCA43jx$Ewde@econym.demon.co.uk>
>> > similar shape.
>ellipsoids.
That's odd. The isosurface I posted does join smoothly with the two
capping ellipsoids shown above. All you have to do is use the same
values for a1, a2, b1, b2 and x0.
Mike Williams
Date: 28 Nov 2003 12:56:44
Message: <3fc78c5c@news.povray.org>
Well I said I gave up.  I must not have as I woke up this morning with
another idea stuck in my head.  Seems I do my best problem solving
while I'm not trying to problem solve.  Anyways... I'm now half way
there.  Try out this code.  It joins two ellipsoids with TWO Supercones
and it joins up with the larger ellipsoid perfectly.  However at the
end of the smaller ellipsoid the shape still ends up inside the ellipsoid
at all but 4 points.  I have one other idea that I want to try but without
doing it I'm not sure if its not mathmatically equivalent to what I just did
here.
Enjoy,
Carl
  #include "math.inc"
  #include "transforms.inc"
  #include "shapes.inc"
  #macro zellipsoid2fill(V1,R1,V2,R2,R3)
    // V1 = center of sphere1
    // R1 = radius of sphere1
    // V2 = center of sphere2 NOTE: must be in the same z plane as sphere1
    // R2 = radius of sphere2
    // R3 = the new radius of both ellipsoids in the z direction
    #local V2a = V2-V1;
    #local theta = degrees(asin((R1-R2)/V2b.x));
    #local V2c = vaxis_rotate(V2b, z, theta);
    #local maxyR = max(R1,R2);
    #local maxx = max(V2b.x+R2*sin(radians(theta)),V2b.x);
    #local minx = min(R1*sin(radians(theta)),0);
    #local shearx1 = <V2c.x, V2c.y, 0>/V2b.x;
    #local shearx2 = <V2c.x, -V2c.y, 0>/V2b.x;
    #local shape1 = object{Supercone(<0,0,0>, R3, R1, <V2b.x, 0, 0>, R3,
R2)}
    #local shape2 = intersection {
      object { shape1 Shear_Trans(shearx1,y,z) rotate -z*theta}
      box {<minx, 0, -R3>,<maxx,maxyR,R3>}
    #local shape3 = intersection {
      object { shape1 Shear_Trans(shearx2,y,z) rotate z*theta}
      box {<minx, 0, -R3>,<maxx,-maxyR,R3>}
    merge {
      object {shape2}
      object {shape3}
      rotate -z*angle_z1
      translate V1
  declare center1 = <0,0,0>;
  declare radius1 = 50;
  declare center2 = <70,30,0>;
  declare radius2 = 20;
  declare maxz = 10;
  sphere{center1,radius1 scale<1,1,maxz/radius1> pigment{Red}}
  sphere{center2,radius2 scale<1,1,maxz/radius2> pigment{Green}}
  declare center = (center1+center2)/2;
  light_source {center-900*x-100*z White}
  light_source {center-900*y-100*z White}
  light_source {center+900*x+900*y-100*z White}
  camera {location center-500*z look_at center angle 27}
  object {zellipsoid2fill(center1,radius1,center2,radius2,maxz)
pigment{Blue}}
Date: 28 Nov 2003 14:33:18
Message: <3fc7a2fe$1@news.povray.org>
> to what I just did
> here.
The other idea WAS mathematically equivalent.  :...(
Anyways... I posted a picture over in the images area.  I 'think'
I'm going to try and give up on this idea again but we'll see if
my mind will let it go.  If anyone wants to try and solve this
particular problem please let me know if you have any success.
Thanks again for all the help guys,
Carl
Date: 28 Nov 2003 21:57:26
Message: <cjameshuff-8D9ADB.21572928112003@netplex.aussie.org>
In article <3fc7a2fe$1@news.povray.org>, "Carl Hoff" <hof### [at] wtnet>
Well, one easy way to do what you want is to make several hundred
ellipsoids spread along the axis of your shape, linearly changing from
one shape to the next. This takes quite a few spheres to make a smooth
shape, and has some obvious inefficiencies, but is quite feasible...in
fact, it was a common way of creating swept shapes before the
sphere_sweep primitive. You can optimize it further by clipping of the
inner spheres and heiarchial bounding. (Split the object in half, put
each half in a nested union. Split each half in half, again putting the
two halves in unions. Repeat...you end up with a heirarchial structure
which removes most of the shapes from consideration early on in
intersection testing.)
Date: 29 Nov 2003 10:46:00
Message: <3fc8bf38@news.povray.org>
I'd thought of that but was afraid it'd be too inefficient.
Ok... I'm very very new at RAY-Tracing and I'm not sure I
could follow that.  Are you saying built the object up my only
every taking the union of two shapes at a time.  Start by taking
the union of two ellipsoids.  Then taking the union of two of
those shapes and so on?  I don't know enough about how POV-Ray
works to see how that removes any of the shapes as each shape
will still form a part of the surface of the final shape.  Should merge
be used as I know it removes all the interior surfaces?  But I'm
still not sure why a merge of a merge would be faster then a
single merge.  I assume I'm missing something and my guess is
that its experience.  Would it be possible for you to post a
small piece of code that uses this "heiarchial bounding" so I
could study it and maybe get a better understanding of what
you are talking about?
Thanks,
Carl
Date: 29 Nov 2003 14:12:40
Message: <cjameshuff-710F40.14124629112003@netplex.aussie.org>
In article <3fc8bf38@news.povray.org>, "Carl Hoff" <hof### [at] wtnet> wrote:
Say you have 16 spheres in a line. o's are spheres, {} braces represent
unions:
{{{{o o} {o o}} {{o o} {o o}}} {{{o o} {o o}} {{o o} {o o}}}}
Now, say you have a ray that will eventually hit the fifth sphere. The
first bounding box test sees the bounds for the outermost union:
Which it hits. The contents of that union are tested, and the next hit
is this one:
This eliminates half the spheres from consideration with one step. To
continue:
{{              {{o  }      }}                              }
Each step halves the number of remaining spheres. Note that you need to
manually bound the unions used for this, or POV-Ray will just split it
up and use its own automatic bounding scheme.
> Should merge be used as I know it removes all the interior surfaces?
If the object is transparent, merge should be used, the overhead of
removing internal surfaces is compensated for by not having to do
texturing and lighting for those surfaces. If it is not transparent, the
merge will be slower.
