POV-Ray : Newsgroups : povray.newusers : Regarding help with my crystal ball Server Time
18 Oct 2026 09:27:05 EDT (-0400)
  Regarding help with my crystal ball (Message 1 to 12 of 12)
Subject: Regarding help with my crystal ball
Date: 12 Nov 2003 06:14:03
Message: <3fb215fb$1@news.povray.org>
I have the following in POV (trying to make transparent glass/crystal ball)
and the results is not what I expect/want.  What can I improve below or what
am I doing wrong?
include "finish.inc"
include "textures.inc"
include "colors.inc"
include "glass.inc"
include "stones.inc"
        location <0,0,-3>
        look_at <0,0,1>
light_source { <0,2,-2> color White}
  plane { <0, 1, 0>, -1
      color Red
  cylinder {
    <0, 0, -10>,     // Center of one end
    <0, 10, -10>,     // Center of other end
   2.0         // Radius
   open           // Remove end caps
    texture { T_Stone25 scale 4 }
object {
sphere {
  <0, 1, 2>, 2
photons{
  target
  reflection on
  refraction on
  //color  rgb <1,1,1> transmit 1
        Col_Glass_Clear
  finish{ reflection{0,1 fresnel on}}
    interior {ior 1.5}
Subject: Re: Regarding help with my crystal ball
Date: 12 Nov 2003 06:24:47
Message: <7364rvgkpkhbce0goco3creh8htdokihus@4ax.com>
On Wed, 12 Nov 2003 06:16:45 -0500, "George Yanez" <gya### [at] ncrrcom> wrote:
>am I doing wrong?
Your are doing nothing wrong. It's just that you expect a different result. Try
changing the plane to a checker
      checker
      color rgb 1
      color blue 1
      scale 0.5
    finish{
      diffuse 0.8
      ambient 0.1
and move the camera back to get a better view. Also note what Warp wrote.
Regards
Date: 12 Nov 2003 07:25:01
Message: <web.3fb225f823a641d5b71c2320@news.povray.org>
I also want to make the ball see-through...transparent...I was told to use
rgbft/transmit function...in my example I commented it out.  Is the
use/placement of it in my code provided correct or not?
Date: 12 Nov 2003 08:35:41
Message: <1pd4rvc19mqm9gr24ekkme65s5mft24418@4ax.com>
Yes that is correct. You can also use
color  rgbt <1,1,1,1> and color  rgbft <1,1,1,0,1>
Note that filter and transmit should add up to one (1) unless you want strange
results.
To see what is happening put something behind the ball and raise the light
source. For instance.
#include "finish.inc"
#include "textures.inc"
#include "glass.inc"
#include "stones.inc"
camera {   // Front
        location <0,2,-10>
        look_at <0,0,1>
camera {   // Side
        location <10,2,-10>
        look_at <0,0,1>
light_source { <0,5,-2> color White}
      checker
      color rgb 1
      color blue 1
      scale 0.5
    finish{
      diffuse 0.8
      ambient 0.1
object {
sphere {
  <0, 1, 2>, 2
//no_image         // Un comment to view without the sphere
photons{
  target
  reflection on
  refraction on
  color  rgbft <1,0,0,1,0>
//        Col_Glass_Clear
    interior {ior 1.5}
  cone { <0, 7, 0>, 0.0, <0, 0, 0>, 1.0
  translate <1,-1,10>
  pigment { colour rgb<1,1,1>
  finish {           // (---surface finish---)
    ambient 0.2
    specular 0.6     // shiny
Regards
Date: 12 Nov 2003 09:06:31
Message: <3fb23e67@news.povray.org>
  Mainly because you don't have details in the environment for the sphere
to reflect/refract.
  Try this:
-----------8<-----------8<-----------8<-----------8<-----------8<-----------
global_settings { photons { count 10000 } }
camera { location <2,5,-10>*.7 look_at 0 angle 35 }
light_source { <15,20,-4>, 1 fade_distance 20 fade_power 2 }
light_source { <-20,10,-5>, <.5,.25,.1> fade_distance 20 fade_power 2 }
// Glass sphere
sphere { 0,1
// You can also try this instead of the above for a hollow sphere:
//difference { sphere { 0,1 } sphere { 0, .9 }
  pigment { rgbf 1 }
  finish
  { specular 2 roughness .005
    reflection { .2, .4 }
  interior { ior 1.5 }
  photons { target reflection on refraction on }
// Floor. (Don't mind the complexity, it's just for getting details)
plane
{ y,-1
  pigment { checker rgb 1, rgb .5 }
  #declare TileNormal =
    normal
    { gradient x 1 slope_map
      { [0 <0,1>][.05 <1,0>][.95 <1,0>][1 <0,-1>] }
  normal
  { average normal_map
    { [1 TileNormal]
      [1 TileNormal rotate y*90]
  finish { specular .5 }
Date: 12 Nov 2003 12:05:11
Message: <opryja1daup4ukzs@news.povray.org>
>> ball)
> to reflect/refract.
>   Try this:
> // Glass sphere
> sphere { 0,1
>   pigment { rgbf 1 }
>   finish
> plane
> { y,-1
>     normal
>   normal
>     { [1 TileNormal]
It always amazes me how just a few lines of code can produce something
that looks so gorgeous, "Don't mind the complexity" that's like a
matador's cape to me:) Slope-map's? Haven't really looked at normals yet,
those look -interesting- ah well, there goes the evening:)
Phil
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 12 Nov 2003 12:18:54
Message: <3fb26b7e$1@news.povray.org>
"Phil Cook" <phi### [at] nospamdeckingdealscouk> wrote in message
news:opryja1daup4ukzs@news.povray.org...
Gah - now I've got to render the damn thing...
Date: 12 Nov 2003 12:25:37
Message: <3fb26d11$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3fb23e67@news.povray.org...
Just out of curiousity, why:
rather than
reflection{fresnel}
(or, more accurately, why doesn't fresnel produce such nice results as .2, .4 ?)
Date: 12 Nov 2003 15:05:11
Message: <cjameshuff-88C41B.15022412112003@netplex.aussie.org>
In article <3fb26d11$1@news.povray.org>,
Because you're using it wrong. First, fresnel reflection varies from 0
to 1 by default, so "reflection {fresnel}" isn't even remotely
equivalent to "reflection {0.2, 0.4}". And second...glass reflection
isn't really very variable. Get a piece of glass and look at it from
various angles...the reflection stays pretty much the same (there is a
sharp increase where total internal reflection starts, but that is a
separate effect that POV also simulates). Water and many ceramic glazes
and plastics do have highly variable reflection.
http://tag.povray.org/
Date: 12 Nov 2003 17:07:12
Message: <3fb2af10@news.povray.org>
Christopher James Huff <cja### [at] earthlinknet> wrote:
> glass reflection isn't really very variable.
  That depends a lot in the type of glass and its coating layer.
  There are certain types of glass surface finishes which exhibit a very
pronounced variable reflection. When you look at the glass right from
the front, it reflects some, but you can mostly see through it. However,
when you look at it at a sharp angle, it's almost like a mirror.
  Next time you walk on a street, try looking at the store windows from
different angles... :)
Date: 12 Nov 2003 18:19:43
Message: <cjameshuff-478DD3.18165712112003@netplex.aussie.org>
In article <3fb2af10@news.povray.org>, Warp <war### [at] tagpovrayorg>
True, but the surface coating that shows these effects usually isn't
glass, but polymers to reinforce the glass, protect it from weathering,
and block glare and UV. I haven't seen any glass that shows strong
variable reflection...but I haven't looked at many types. There may be
types that show this effect more strongly...
Surface coatings like this are something to keep in mind when making
textures, though...as another example, a colored, dull object may have a
colorless reflective glaze. Since the reflection comes from a colorless
material, it is not tinted with the color of the surface. A chrome ball
with a transparent red coating will have very different reflections from
a red ceramic ball with clear glaze.
Date: 13 Nov 2003 04:28:33
Message: <3fb34ec1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
But I thought fresnel used the interior ior to calc. reflections? Isn't the
implication that if you get the ior right, then fresnel should produce the most
realistic result?
As Warp says, glass does seem to have very variable reflection depending on the
angle at which it's viewed. I make no claim to understanding the issues - just a
claim that I'm confused....
