POV-Ray : Newsgroups : povray.newusers : Coincident Surfaces? Maybe . . . Server Time
18 Nov 2026 03:05:59 EST (-0500)
  Coincident Surfaces? Maybe . . . (Message 1 to 11 of 11)
Subject: Coincident Surfaces? Maybe . . .
Date: 20 Oct 2003 18:20:26
Message: <3f945faa@news.povray.org>
See my pic in p.b.images. Here's the code I got:
difference {
         merge {
                 //Grass
                 plane{<0,1,0>, 0
                                         dents
                                         triangle_wave
                                         color_map {
                                                 [0.0 rgb <0.0, 0.4, 0.1>]
                                                 [1.0 rgb <0.1, 0.6, 0.2>]
                 //Big Box
                 box { <-10, -.7,-0.5> <10, .5, 200.5> texture{
T_Grnt18a normal {bumps 0.75 scale 0.015} finish {ambient 0.1 diffuse
0.8} }}
         //Center Cutout
         box { <-9, -.6, 0> <9,  .8, 200> texture{ T_Grnt18a normal
{bumps 0.75 scale 0.015} finish {ambient 0.1 diffuse 0.8} }}
//Water Area
intersection {
         box { <-9, -.6, 0> <9,  .8, 200> }
         plane{<0,1,0>, .4
                 material {
                                         color rgbf <.2, .7, .3, .5>
                                 finish {
                                         ambient 0.0
                                         diffuse 0.0
                                         reflection {
                                                 0.0, 1.0
                                                 fresnel on
                                         specular 0.8
                                         roughness 0.0003
                                 normal {
                                         bozo 0.7
                                         scale 0.15
                         interior {
                                 ior 1.3
                                 media {
                                         absorption <0.8, 0.6, 1.0, 0.5>
       }// end of plane
//End Of Water
Subject: Re: Coincident Surfaces? Maybe . . .
Date: 20 Oct 2003 18:25:35
Message: <3f9460df$1@news.povray.org>
One other thing I just noticed, the tree on the right doesn't cast a
shadow on the water, shouldn't it?
Date: 20 Oct 2003 19:11:54
Message: <Xns941BC2D8B45Atorolavkhotmailcom@204.213.191.226>
Brent G <pov### [at] bc-hqcom> wrote in news:3f945faa@news.povray.org:
Does it still look odd if you rewrite
the code for the water like this ?
//Water Area
box {
  <-9, -0.6, 0> <9,  0.4, 200>
  material {
      pigment { color rgbf <0.2, 0.7, 0.3, 0.5> }
      finish {
        ambient color rgb <0, 0, 0>
        diffuse 0.0
        reflection {
          0.0, 1.0
          fresnel on
        specular 0.8
        roughness 0.0003
      normal {
        bozo 0.7
        scale 0.15
    interior {
      ior 1.3
      media { absorption <0.8, 0.6, 1.0, 0.5> }
//End Of Water
If not then you need to provide a scene with the
camera and lights set up so that the error shows.
Use as simple textures as possble. And do not
include code for the trees   ;)
Tor Olav
Date: 20 Oct 2003 19:15:04
Message: <3f946c78$1@news.povray.org>
> Tor Olav
Yup that still shows up
Scene file posted in p.b.scene-files
Date: 20 Oct 2003 19:25:41
Message: <Xns941BE83BD1B0torolavkhotmailcom@204.213.191.226>
Brent G <pov### [at] bc-hqcom> wrote in news:3f946c78$1@news.povray.org:
>> Tor Olav
If you wish for people to spend time trying
to debug your code, you should try to provide
a minimal scene that still shows the problem.
I.e. remove advanced textures, multiple
cameras, the grass, the sky, fog etc.
(While doing all this, one often find the
problematic code.)
Tor Olav
Date: 20 Oct 2003 21:30:45
Message: <3f948c45@news.povray.org>
"Brent G" <pov### [at] bc-hqcom> wrote in message
news:3f945faa@news.povray.org...
The merge of the plane and box is causing the difference to be ignored for
the lower part of the "center" cut away box. Although I'm not certain why
the appearance manifests itself in the way it does.
Shadowing needs a light-diffusing surface or subsurface, so to get one for
the water you'll either need to raise diffuse or add scattering to the
media. BTW, you forgot 'hollow' for the water box.
Here's a working example.
difference {
           //Grass
           plane{<0,1,0>, 0
                                 dents
                                 triangle_wave
                                  color_map {
         //Big Box
          texture{ pigment {rgb <1,0,0>}
difference {
        //Big Box
         texture{ pigment {rgb <0,0,1>}
        //Center Cutout
         texture{ pigment {rgb <1,1,0>}
//Water Area
box {
  <-9, -0.6, 0.001> <9,  0.4, 199.9>
  material {
      finish {
        diffuse 0
        reflection {
          0.0, 1.0
          fresnel on
        specular 0.8
        roughness 0.0003
      normal {
        bozo 0.7
        scale 0.15
    interior {
      ior 1.3
      media { absorption <0.8, 0.6, 1.0> // filter value wasn't needed here
        scattering {2,10} density {rgb 10} // example for visible shadow
(extreme, yeah)
  hollow
sphere {<5,5,5>,3 pigment {rgb 1}} // shadow maker
// END
Hopefully there's still an explanation about the odd missing corners of a
merging plane and box but it eludes me at the moment. Too bad this other way
isn't as short.
Bob H.
http://www.3digitaleyes.com
Date: 20 Oct 2003 23:34:33
Message: <3f94a949@news.povray.org>
>>>Tor Olav
> problematic code.)
Well I apologize for the advanced textures, but I must digress about the
rest, IF I DONT KNOW WHAT THE PROBLEM IS, HOW CAN I KNOW IF I CAN TAKE
IT OUT OR NOT?
Date: 20 Oct 2003 23:37:19
Message: <3f94a9ef@news.povray.org>
>>>> Tor Olav
>> problematic code.)
> IT OUT OR NOT?
Err: s/advanced textures/multiple cameras/ig; it's late :-(
Date: 20 Oct 2003 23:43:34
Message: <cjameshuff-B0B1C6.23412520102003@netplex.aussie.org>
In article <3f94a949@news.povray.org>, Brent G <pov### [at] bc-hqcom>
> IT OUT OR NOT?
If it disappears, you took it out. If it doesn't, it's still there.
http://tag.povray.org/
Date: 21 Oct 2003 00:01:46
Message: <3f94afaa$1@news.povray.org>
>>IT OUT OR NOT?
I apologize for that last outburst :-( it's been a very stressfull day.
I'm looking the difference and merge parts :-/
Date: 21 Oct 2003 00:14:16
Message: <3f94b298@news.povray.org>
Actually It was none of the above . . the granite stone texture uses
rgbt :-( so I guess some of the light from the other objects was showing
through . . if I'm reading that right.
