POV-Ray : Newsgroups : povray.newusers : looks_like? Server Time
18 Oct 2026 09:27:02 EDT (-0400)
  looks_like? (Message 1 to 13 of 13)
Subject: looks_like?
Date: 9 Oct 2003 17:52:12
Message: <3f85d88c@news.povray.org>
Hi, I hope someone can help me.
There's a couple of things I'm not sure about with respect to looks_like.
Firstly there are two locations: the location of the light source and the
location of the object. I'm not sure if the light source gets transposed,
or if it only appears to shine through the object.
Secondly, what's the difference between looks_like and just putting a
light source at the centre of an object and making the object no_shadow?
Many aTdHvAaNnKcSe :-)
Bill Hails
Subject: Re: looks_like?
Date: 9 Oct 2003 20:47:14
Message: <3f860192@news.povray.org>
"Bill Hails" <bil### [at] europeyahoo-inccom> wrote in message
news:3f85d88c@news.povray.org...
Ack! I sure can foul up when I jump to quickly to answer things like this.
Don't know why my memory fails so badly sometimes. Unless you can't guess, I
had already posted an incorrect reply here and then cancelled it.
Let me see if I can manage to do better this time. It does indeed move the
object to the light's position.
Other than that, no, it doesn't shine light through it as though it were a
hole in an otherwise solid universe. Only allows light to pass without any
shadowing attached. What I mean by this, there isn't any projected light
through the looks_like object in the sense that if it were offset from the
light source location light would not beam outward from the object.
projected_through could help to pipe the light through an object if you
wanted the light shining from elsewhere but through the object.  Either way
you lose any filtered or transmitted coloring due to lack of shadow.
It's essentially what no_shadow does, just tied to the light more directly
than if were by a union instead.
Sorry for the mistake before, if anyone saw that too.  :-X  Again, if I'm
wrong in any way about the above answer maybe the POV-gods will take pity on
me.  :-)
Bob H.
Date: 10 Oct 2003 04:09:07
Message: <3f866923@news.povray.org>
These two constructs are practically identical in functionality:
light_source
{ LIGHT_LOCATION, COLOR
  looks_like { OBJECT }
union
{ light_source { LIGHT_LOCATION, COLOR }
  object { OBJECT shadowless translate LIGHT_LOCATION }
  I hope this helps clearing out how looks_like works.
  (The bit that confuses most new (and even some old) users is the
implicit translation of the looks_like object.)
Date: 10 Oct 2003 10:41:32
Message: <cjameshuff-A4EBF6.10390910102003@netplex.aussie.org>
In article <3f85d88c@news.povray.org>,
The looks_like object is shadowless to its light, but can cast shadows
from other lights. Otherwise, it behaves like any other object.
http://tag.povray.org/
Date: 10 Oct 2003 15:41:54
Message: <3f870b82@news.povray.org>
Ah, that's the point I was missing, thanks.
Bill Hails
Date: 10 Oct 2003 15:45:04
Message: <3f870c40@news.povray.org>
> light_source
> union
Thanks, I'd kind of assumed it was the light source that got
translated to the object's position, but then in my current use of it
I have the two locations the same to start off with.
Bill Hails
Date: 10 Oct 2003 15:49:29
Message: <3f870d49@news.povray.org>
Thanks for your reply, things are a lot clearer (and brighter :-)
now
> I had already posted an incorrect reply here and then cancelled it.
> way you lose any filtered or transmitted coloring due to lack of shadow.
> on
> me.  :-)
> Bob H.
Bill Hails
Date: 10 Oct 2003 16:54:29
Message: <3f871c85@news.povray.org>
news:3f870b82@news.povray.org...
no_shadow?
Well, I was about to go ahead and take it for granted that this is true. I
just had to see it for myself. I didn't find any shadows from other light
sources, whether the looks_like object is semi-transparent or opaque. Also,
only has self-shadowing on a per primitive basis too. In a union of sphere
and cone, for example, each doesn't cast a shadow onto  the other.
Bob H.
Date: 11 Oct 2003 22:31:24
Message: <cjameshuff-8B157B.22290211102003@netplex.aussie.org>
In article <3f871c85@news.povray.org>,
Hmm, that makes it pretty useless...apparently no different than a union
of a light source and a shadowless object.
> Also, only has self-shadowing on a per primitive basis too. In a
> union of sphere and cone, for example, each doesn't cast a shadow
> onto  the other.
I'm not sure if you're describing what it does or what it should
do...are you saying look_like objects cast shadows on themselves but not
on other objects?
Unions are kind of tricky...they are internally split up into separate
objects to make bounding more efficient. Manually bounding the union
will disable this behavior unless the split unions option
(Split_Unions=on or +SU for non-Mac versions) is turned on, in which
case even bounded unions will be split. This burned me when I was
experimenting with the proximity and curvature patterns...I have no idea
how it interacts with looks_like, I'd need to take a close look at the
code.
Anyway, I'd suggest you just use a union of the light source with the
object representing the light. This gives you most control over what
actually happens...you can make specific parts shadowless, etc. If we're
going to talk about what looks_like *should* do, I think it should
behave in exactly the same way as a union with the light source, but
changing it at this point would probably cause more problems than it
solves.
Date: 12 Oct 2003 23:23:47
Message: <3f8a1ac3@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
> > onto  the other.
> on other objects?
Themselves, yes; on a per individual primitive basis, having only a shadowed
side versus lit side. So what I was saying is that if a sphere and cone are
next to each other, in a union, they don't cast a shadow onto each other. I
guess your explanation about bounding below is the reason why.
> code.
> solves.
I'll agree with that. Many times I've passed on using a looks_like and used
union with a light source instead, with the idea being to get more control
of the object appearance. I know people must've suggested a 'shadow on',  or
'no_shadow off', method before, for doing things like this, instead of being
stuck with the shadowless invocation caused by looks_like. Therefore being
able to force shadowing within an otherwise no_shadow CSG object. I can
imagine it being of some use. Due to the way all other light sources fail to
interact properly with the current way looks_like works.
Just to give it a try, I checked what you suggested about manual bounding
within the CSG union, except still for a looks_like object, and still aren't
any shadows. I think it's been said that looks_like is only a shortcut to
creating a light plus object, not the only way available and perhaps that's
why no one has deemed it necessary to change. Or, as you said, there might
be some difficulties is allowing shadowing via the internal bounding
hierarchy?
Bob H.
3digitaleyes.com
Date: 13 Oct 2003 00:19:43
Message: <cjameshuff-0A4E9B.00172513102003@netplex.aussie.org>
In article <3f8a1ac3@news.povray.org>,
But they do...I'm not sure what you are saying. Are you talking about a
bare union, a union with no_shadow, or a bare union as a looks_like
object? A shadowless object won't self-shadow, but even a shadowless
object has a lit side and a dark side.
> hierarchy?
The internal bounding heirarchy does not cause any problems with
bounding. I was talking about the possibility of the union splitting
behaving unexpectedly when combined with the looks_like feature. I think
you're seeing a problem where there isn't one, or just not clearly
explaining what the problem is...
Date: 13 Oct 2003 09:35:20
Message: <3f8aaa18@news.povray.org>
> I think you're seeing a problem where there isn't one, or just not clearly
Thought I was being clear in that I was checking this out by using a simple
CSG union of only a cone and sphere where it should cast a shadow from one
to the other's surface in a shadowable light. That CSG being used then as a
looks_like object, of course, doesn't have shadow but then neither does any
shadowing show from lights elsewhere.
I now know what you are saying about the self-shadowing though. I usually
take it to be that a dark side is a "self" shadow. What you meant is that a
torus, for example, with no_shadow applied does not cast a shadow across
itself from one edge to the other. I don't always get these characteristics
right but I do remember that being a classic example before.
This whole thing is really about whether or not shadowing caused by light
sources, other than the one containing it in a looks_like statement, would
exist. It doesn't seem correct to remove the shadow which could be produced
by all other light sources just because it's a looks_like object. For
instance, a light bulb casts a shadow from sunlight. This has been discussed
a lot before, I know.
Hopefully I'm getting somewhere with this.  :-)
Bob H.
http://www.3digitaleyes.com
Date: 13 Oct 2003 10:46:42
Message: <cjameshuff-7AC19C.10442413102003@netplex.aussie.org>
In article <3f8aaa18@news.povray.org>,
What you are thinking of is double-illumination, or rather the lack of
it. You could consider it a kind of shadowing, but the light isn't being
blocked from reaching the surface, it's just on the other side of it.
I agree.
