I would like to make with POV a non-traditional spherical chess board. I
already have the 1-parametric description of the lines that play the role of
sides of the squares. The intersections of such lines are the corners of the
squares, for which I would like to use two different patterns, of course.
I have some idea about how to do it, but does not seem very practical. Any
suggestions?
Thanks in advance.
Miguel García Díaz
Dpto. Sistemas Informáticos y Programación
Universidad Complutense de Madrid
Facultad de Matemáticas
Avda. Complutense s/n
28040 Madrid
Tlf. 91 394 44 11
The easiest way to do that depends a bit upon the exact geometry of your
squares. So you should precise a bit.
Until some specialist answers you, I can give some tracks:
- You can combine a radial and gradient textures.
- You can use UV mapping I think, but I don't know much on how to use it.
- You can generate your sphere as a mesh and assign the proper texture
to each triangle.
I would go with the first one, it is probably the easiest and more
efficient solution. Let me know if you need more clues,
JC
> suggestions?
> Thanks in advance.
> Miguel García Díaz
> 28040 Madrid
> Tlf. 91 394 44 11
Is that what you want ?
#declare T_G1=texture {
gradient y
color_map {
[0.0 rgb 1.0]
[0.5 rgb 1.0]
[0.5 rgb 0.0]
[1.0 rgb 0.0]
scale 1/4
#declare T_G2=texture {
T_G1
translate <0,1/8,0>
sphere {
<0,1,0>, 1
radial
frequency 4
texture_map {
[0.0 T_G1]
[0.5 T_G1]
[0.5 T_G2]
[1.0 T_G2]
> suggestions?
> Thanks in advance.
> Miguel García Díaz
> 28040 Madrid
> Tlf. 91 394 44 11
"JC (Exether)" <no### [at] spam fr> wrote in message
news:3f66c5f6@news.povray.org...
I never heard about it, so I will take a look at it.
> to each triangle.
You are right, I did not think about it. But this is the last thing that I
will try.
Thanks a lot for your ideas.
Miguel García Díaz
http://www.telefonica.net/web/miguelgdz/index.html
news:3f66c7ba@news.povray.org...
> pigment {
> gradient y
> color_map {
> [0.0 rgb 1.0]
> [0.5 rgb 1.0]
> [0.5 rgb 0.0]
> [1.0 rgb 0.0]
> scale 1/4
> T_G1
> translate <0,1/8,0>
> sphere {
> <0,1,0>, 1
> texture {
> radial
> frequency 4
> texture_map {
> [0.0 T_G1]
> [0.5 T_G1]
> [0.5 T_G2]
> [1.0 T_G2]
Well, no. This is a traditional spherical squared board. I have a different
geometry in mind, where the sides of the squares are not the classical
meridians and paralels. I have the equations of such lines, but nothing
else.
Thanks again.
Miguel García Díaz
