POV-Ray : Newsgroups : povray.newusers : how to speed up rendering with my objects Server Time
18 Oct 2026 11:46:26 EDT (-0400)
  how to speed up rendering with my objects (Message 1 to 6 of 6)
Subject: how to speed up rendering with my objects
Date: 23 Jun 2003 10:04:31
Message: <3ef708ef@news.povray.org>
Hi.
I've just finished programming my macro for a SF container. I use it
within a story of mine and just wanted to see how it looks in 3D.
Now that I have it, I can place containers in different sizes very well
but I wonder WHY exactly a render in 512x384 is so slow. It takes my
900MHz Thunderbird about 6 Minutes to finish. Most of the provided
povray examples which look quite complex are rendering really much faster!
Perhaps someone can take a look at my code and tell my either where or
why it is slow and if it can be speed up?
You should be able to download the code from:
http://home.t-online.de/home/callan/container.zip (10kB)
Greetings and hoping for some tips,
Maik Schmidt
Subject: Re: how to speed up rendering with my objects
Date: 23 Jun 2003 10:32:30
Message: <3ef70f7e$1@news.povray.org>
Several things:
1. Arealights: They slow down the rendering
2. The difference in container.inc uses lots of objects. Thats
difficult CSG for POV-Ray to solve. Perhaps just difference
the stuff out of one side and place that. Right now, POV-Ray
checks all sides where to difference. If you use +UD on the
command-line, you'll see large blue boxes. Try to make them smaller
by using smaller chunks of objects with each other.
3. You could use boxes instead of polygons to map the image onto
it.
Tim
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Hi.
> Maik Schmidt
Date: 23 Jun 2003 13:48:56
Message: <RFZYPEAvsz9+Ewa5@econym.demon.co.uk>
Wasn't it Maik Schmidt who wrote:
>Hi.
My "Holes Tutorial" will explain why objects that contain lots of holes
can often be slow, and may suggest some techniques that you might try to
speed it up.
<http://www.econym.demon.co.uk/holetut/index.htm>
Mike Williams
Gentleman of Leisure
Date: 23 Jun 2003 15:01:22
Message: <3ef74e82@news.povray.org>
> speed it up.
I feat it does not work with my macro. I do not have so much holes as
you have; only 5 per container.
Thanks anyway,
Maik
Date: 23 Jun 2003 21:42:46
Message: <3ef7ac96$1@news.povray.org>
	Difference and merge and clipped_by slow things down when rendering
the objects involved in the those processes.
	Say you have ten small objects in a union to make one large object. If
you difference {object{large} object{very_very_small}} the entire large
object is slowed. If you difference {object {small}
object{very_very_small}} and then union that into the large object it only
slows down when rendering the small object.
	If you could redesign it so that only the parts of the base and (top?)
that need to be differenced into a separate part and union all three you
should get a speed increase.
Date: 24 Jun 2003 11:04:05
Message: <3ef86865$1@news.povray.org>
> ... you could redesign it so that only the parts of the base and (top?)
I don't think I will change my macro now, after it is working the way I
want. But I will write this and the other advices down to have them
ready when I want to do something again for my story.
Thanks anyway,
Maik
