POV-Ray : Newsgroups : povray.newusers : Cyrillic fonts in scene Server Time
18 Nov 2026 03:50:13 EST (-0500)
  Cyrillic fonts in scene (Message 1 to 4 of 4)
Subject: Cyrillic fonts in scene
Date: 12 Apr 2003 10:15:41
Message: <3e981f8d$1@news.povray.org>
A follow-up to the thread in General.
I am trying to get Cyrillic text to appear in a scene. After reading thru
the info at a Cyriillic font site, I installed Multilanguage support via the
Windows Setup in Add/Remove programs, then installed a Keyboard layout
utility that allows me to switch between English and Russian. Next, I
specified global_settings { charset utf8   } as specified in the manual and
Next, I entered the text while using the Russian keyboard layout and it
appears in Cyrillic on my screen in the "text" object in the scene (I tried
Courier and Times), but when I render the scene, the text itself appears in
the same block/rectangular font (i.e., the unrecognized font) as described
by Greg.
If I switch to Word and start to enter text, I see it in Cyrllic when I use
either Courier or Times.
Obviously there is one more step I am missing.
Any suggestions?
thanks,
Dennis
dhm### [at] attbicom
http://www.dennismiller.neu.edu
Subject: Re: Cyrillic fonts in scene
Date: 12 Apr 2003 14:02:41
Message: <3e9854c1@news.povray.org>
In article <3e981f8d$1@news.povray.org> , "Dennis Miller"
What you do won't get you anywhere because the text format also needs to be
UTF-8, and you cannot get that with the built-in POV-Ray editors.  On
Windows 2000 and XP the editor that comes with the system should support
saving files in UTF-8 format. Alternatively, you can enter the Unicode
character code directly using the \u option.
    Thorsten
e-mail: tho### [at] trfde
Date: 12 Apr 2003 14:36:54
Message: <MPG.190206b43c717e129897c4@news.povray.org>
In article <3e981f8d$1@news.povray.org>, dhm### [at] attbicom says...
> by Greg.
> Any suggestions?
> thanks,
> Dennis
The Cyrillic characters and other special stuff, unless specifically
gotten from a purely Cyrillic font, only appear if using unicode support.
Windows when you activate all that suppose stuff basically remapped keys
you type to the unicode characters imbedded in most of the standard
fonts. Not sure if POVRay supports the unicode sets though, since it
requires two bytes per letter and POVRay probably only supports single
byte letters. In other words, normal letters are 00-FF, while unicode is
0000 - FFFF. Sadly winbloze confuses the issue by 'remapping' the
keyboard, not supporting it in the Character Map utility and basically
hiding the bloody stuff so well that had I not recently downloaded a font
editor and gone, 'where the heck did all those extra letters come from?',
when I tried to look at the Lucida Console font, I wouldn't even know
that those characters where there. I suspect that Linux doesn't 100%
directly support the extended set either, except in programs specifically
designed to use unicode.
Basically.. If POVRay has some way to specify that you want to use the
unicode set in a font that has one, then you are in business. If it
doesn't, and I don't remember ever seeing anything about it, then you are
out of luck unless you get a font that was specifically designed to be
Cyrillic or download a good font manager and make a new copy of the one
you want to use, with all the characters rearranged so that the non-
unicode part contains what is normally in the unicode section, or in
other words, renumber most of the entire internal table for all the
letters and save it under a new font name. :P
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
Date: 17 Apr 2003 18:43:30
Message: <3e9f2e12$1@news.povray.org>
Thanks much for the help. I've pretty much given up on this and was able to
get what I needed in Photoshop, without all the processing I intended to do
however.
Best,
D.
"Patrick Elliott" <sha### [at] hotmailcom> wrote in message
news:MPG.190206b43c717e129897c4@news.povray.org...
thru
the
and
tried
in
described
> > by Greg.
use
> > Any suggestions?
> > thanks,
> > Dennis
> void main () {
>   else
