POV-Ray : Newsgroups : povray.newusers : clock vs spline Server Time
4 May 2026 02:09:53 EDT (-0400)
  clock vs spline (Message 1 to 4 of 4)
Subject: clock vs spline
Date: 5 Mar 2003 08:29:02
Message: <3e65fb9e$1@news.povray.org>
I'm trying to correlate the position of the camera relative to the clock
when I use a spline to translate the camera. The code is as follows:
 #declare MySpline =
  spline {
    cubic_spline
    -.25, <0,0,-1>
    0.00, <3,.1,-5>
    0.25, <0,.2,-15>
    0.50, <-2,.3,-5>
    0.75, <0,.1,1>
   1.00, <.5,1,-1>
   1.25, <0,0,-8> }
  location 0
  direction <0, 0, 3.5>
  right <(3/2), 0, 0>
  up <0, 1, 0>
translate MySpline(clock) }
If I were to set the Initial_Clock to say, .50 and the Final_Clock to .75,
can I assume that the camera would be translated to those specific points in
the spline declaration (<-2,.3,-5> and <0,.1,1>)? In other words, will the
camera move along the spline path in synchrony with the value of the clock?
Thanks much,
Dennis
dhm### [at] attbicom
http://www.dennismiller.neu.edu
Subject: Re: clock vs spline
Date: 5 Mar 2003 08:39:29
Message: <r9vb6vclqi6ltkodipgpevssi3ugvfbl70@4ax.com>
On Tue, 4 Mar 2003 08:31:40 -0500, "Dennis Miller" <dhm### [at] attbicom> wrote:
Afaik yes. Anything makes you think it isn't ?
Instead of translate you can put Spline Vector directly into location.
ABX
Date: 5 Mar 2003 14:21:05
Message: <cjameshuff-BD38B5.14210205032003@netplex.aussie.org>
In article <3e65fb9e$1@news.povray.org>,
Didn't you try it?
Yes, that should work fine...though it should work just as well with the
spline controlling the camera location directly instead of putting the
camera at < 0, 0, 0> and then translating it. There is no real
difference, just a little simpler. You could even do something like this:
    location MySpline(clock)
    look_at MySpline(clock + 0.1)
to get the camera to look along the spline.
http://tag.povray.org/
Date: 5 Mar 2003 21:10:40
Message: <3e66ae20$1@news.povray.org>
Thanks to both. Well I am using this code but it is a very abstract scene
and I can't really tell where the camera "should"be. I think I was trying to
confirm that the value in parenths correlated to the time points along the
spline. Normally I wouldn't think of them as time points per se - more as
just locations or coordinates  (not sure of the proper term) for the spline.
But you have confirmed my understanding.
Thanks again,
D.
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
.75,
points in
the
clock?
> Didn't you try it?
> camera {
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
