POV-Ray : Newsgroups : povray.newusers : Can't get photons to show up in media... Server Time
4 May 2026 03:34:58 EDT (-0400)
  Can't get photons to show up in media... (Message 1 to 8 of 8)
Subject: Can't get photons to show up in media...
Date: 2 Mar 2003 11:06:33
Message: <3e622c09@news.povray.org>
I have been fighting with this simple scene for some time now. I made
the scene to demonstrate how photons can interact with media so that a
reflected light beam will show up.
  For some reason, no matter what I do, it doesn't work.
  Could someone lighten me up in this issue? How do I get the reflected
photons to show up in the media?
#global_settings { photons { spacing .01 media 100 } }
media { scattering { 1,.5 extinction .1 } }
camera { location <1.8,0,-3> look_at 0 angle 80 }
sphere { -x*1.01, 1 pigment { rgb 1 } }
light_source
{ 0, 1
  spotlight point_at x radius 15 falloff 18
cone
{ -x*.1,0, x*.5,.25 open
  pigment { rgb 1 }
  interior_texture { pigment { rgb 1 } finish { ambient 1 } }
box
{ <2,-5,-10>, <2.1,5,10>
  pigment { rgb 1 }
  finish { reflection 1 }
  photons { target reflection on }
box
{ <-2,-5,-10>, <-2.1,5,10>
  pigment { rgb 1 }
Subject: Re: Can't get photons to show up in media...
Date: 2 Mar 2003 12:00:14
Message: <web.3e62374e652088bff7cbce3c0@news.povray.org>
Photons only work with contained medias. This doesn't seem to be mentioned
in the docs though... Anyway, it is pretty obvious if you think about it a
bit, in an infinite media a potentially infinite amount of photons would
have to be sampled and stored.
Date: 2 Mar 2003 12:07:29
Message: <3e623a51@news.povray.org>
  I tried confining the media inside a box (box { -2.1, 2.1 }, with all
hollow etc stuff) without the image changing in any way. No reflected
photons in the media.
Date: 2 Mar 2003 12:09:45
Message: <cjameshuff-DC11D9.12051202032003@netplex.aussie.org>
In article <3e622c09@news.povray.org>, Warp <war### [at] tagpovrayorg>
Try bounded media instead of global media? Maybe the infinite rays are
screwing it up. I never use global media, it's too unreliable.
http://tag.povray.org/
Date: 2 Mar 2003 12:32:03
Message: <3e624013@news.povray.org>
  As I mentioned in the other article, I tried it and it didn't change
the image at all. I don't understand what's going on.
  Could someone modify my code to work and post it here and not just
post guesses about what *might* be the problem, thanks? ;)
Date: 2 Mar 2003 13:31:29
Message: <3e624e01@news.povray.org>
news:3e624013@news.povray.org...
It seems to be just because of the cone, it not being hollow. Although I
can't explain why it prevents only the reflection and not the first
lightbeam.
Farewell,
Date: 2 Mar 2003 13:46:01
Message: <3e625169@news.povray.org>
Scratch that. Not only because of the cone being nonhollow but it does need
a container for the media. I was too quick to reply. Here it is, working:
#global_settings {
 photons { spacing .01 media 50 } // low sampling, ugly but faster
sphere {0,5 // media container
pigment {rgb 0}
interior {
media { method 2 // hasten the render more
 scattering { 1,.5 extinction 0.25}
hollow
camera { location <1.8,.1,-3> look_at 0 angle 80 }
light_source
{ 0, 1
  photons {reflection on} // added
cone
  pigment { rgb 1 }
 hollow // wasn't hollow before
box
  pigment { rgb 1 }
  finish { reflection {1,1} }
  photons { target reflection on collect off}
box
  pigment { rgb 1 }
Date: 2 Mar 2003 19:20:29
Message: <3e629fcd@news.povray.org>
  Oh... Seems like an odd undocumented behaviour. I wouldn't have thought
about that (since the photons were otherwise working ok, ie. reflecting
from the wall an illuminating the objects on the left).
  Anyone has an idea why this occurs and whether it's a bug or not?
