POV-Ray : Newsgroups : povray.newusers : how to calculate.... Server Time
18 Nov 2026 04:00:09 EST (-0500)
  how to calculate.... (Message 1 to 5 of 5)
Subject: how to calculate....
Date: 6 Feb 2003 12:55:39
Message: <3e42a19b$1@news.povray.org>
the normal vector based on 3 vectors?
my skills are not very high at the moment but i think it is very simple....
I want to render a plane, that is clipped by a box.
The 3 vectors are:
v1=<12,15,73>
v2=<28,  4,68>
v3=<20,10,70>
if I can calculate the normal vector, I´m able to render the plane with:
#declare mui_plane=union{
                                         plane { < ?, ?, ?>, 0
                                         pigment { color rgb <0.7,0.0,0.0> }
 object {
    mui_plane
    clipped_by{box{<-1,-1,-1>,<1,1,1>}}
Is there an easier way or how can I do this?
Help is very apprechiated.
Thanks in advance,
Robert
Subject: Re: how to calculate....
Date: 6 Feb 2003 13:30:04
Message: <web.3e42a93cc6bd118bb417814a0@news.povray.org>
>The 3 vectors are:
>v1=<12,15,73>
>v2=<28,  4,68>
>v3=<20,10,70>
> object {
>    mui_plane
If those 3 vectors represents the positions
of 3 points on the surface of your plane,
then a normal vector for that plane can be
calculated like this:
#declare vN = vcross(v2 - v1, v3 - v1);
Now the expression for your plane can be
written like this:
plane { vN, 0 translate v1 }
or like this:
plane { vN, vdot(v1, vnormalize(vN)) }
But if v1, v2 and v3 are not positions of 3
points on the surface, then you must give
more information about the problem.
I.e. what these 3 vectors represents.
Tor Olav
Date: 6 Feb 2003 14:14:49
Message: <3e42b429@news.povray.org>
Many thank´s for the hint!
This works fine. Now i just have to (and want to) understand the
mathemathics behind this...
I found the following web page (in german):
http://wwwzb.zb.kfa-juelich.de/mathe/daten/kap_3/node281.htm
but was not able to translate to POVray.
kind regards,
Robert
"Tor Olav Kristensen" <tor### [at] hotmailcom> schrieb im Newsbeitrag
news:web.3e42a93cc6bd118bb417814a0@news.povray.org...
> written like this:
> or like this:
> Tor Olav
Date: 6 Feb 2003 16:54:12
Message: <3e42d983@news.povray.org>
http://mathworld.wolfram.com/CrossProduct.html
Date: 8 Feb 2003 04:58:29
Message: <3e44d4c5$1@news.povray.org>
Thanks!
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3e42d983@news.povray.org...
M()}}
Warp -
