POV-Ray : Newsgroups : povray.newusers : Plastic Server Time
12 Nov 2026 23:43:39 EST (-0500)
  Plastic (Message 1 to 10 of 10)
Subject: Plastic
Date: 8 Nov 2002 11:44:19
Message: <3dcbe9e3$1@news.povray.org>
Does anyone know how I can create a nice transparant plastic?
Thanks!
Subject: Re: Plastic
Date: 8 Nov 2002 11:56:51
Message: <21rnsus9m1cn8l6h54hmpjobkr1psioe9q@4ax.com>
On Fri, 8 Nov 2002 17:44:22 +0100, "J Tellings" <j_t### [at] hotmailcom>
wrote:
> Hi,
Hi
http://news.povray.org/povray.binaries.images/13881/
ABX
Date: 8 Nov 2002 12:06:35
Message: <chrishuff-616E07.12062608112002@netplex.aussie.org>
In article <3dcbe9e3$1@news.povray.org>,
You need to be a little more specific...do you want Plexiglass or Lexan?
Saran wrap? Cellophane? The injection molded brittle stuff
(polystyrene?) that they use for CD jewel cases? What kind of object are
you trying to do?
If you look in the include files, there are several transparent plastic
textures. You could start with a glass texture and use soft highlights,
angle dependant reflection might also help.
http://tag.povray.org/
Date: 8 Nov 2002 12:14:40
Message: <3dcbf100@news.povray.org>
"J Tellings" <j_t### [at] hotmailcom> wrote in message
news:3dcbe9e3$1@news.povray.org...
> Hi,
It's a fairly complex industrial process, but most good modelling shops will
sell resin kits (you just mix two liquids iirc). Don't try and make ashtrays out
of it though....
The stuff looks a bit like this:
  texture{
    pigment{rgbf 1}
    finish{
      reflection{fresnel on}
  interior{
    ior 1.5
Date: 8 Nov 2002 15:43:17
Message: <3dcc21e4@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
>     ior 1.5
  That looks like glass, not plastic.
Date: 10 Nov 2002 11:07:05
Message: <3DCE8422.CBACE77B@pacbell.net>
> >     ior 1.5
Plastic has no refraction index?
Ken Tyler
Date: 10 Nov 2002 12:00:07
Message: <3dce9096@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
>> >     ior 1.5
  Of course it has, but I would be really surprised if it would be the
same as glass has.
Date: 10 Nov 2002 12:08:01
Message: <3DCE9270.1C488F4C@gmx.de>
Warp wrote:
> >> >     ior 1.5
> same as glass has.
consts.inc:
#declare Plexiglas_Ior = 1.5;
Other polymers of course can have different iors but in the same range.
Last updated 02 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Nov 2002 12:33:13
Message: <chrishuff-F62EE5.12325610112002@netplex.aussie.org>
In article <3dce9096@news.povray.org>, Warp <war### [at] tagpovrayorg>
> same as glass has.
Depends on the plastic. "Plastic" and "glass" are far too imprecise, but
the range of iors in plastics is probably wider than that of glasses. I
know polycarbonate plastics can have an ior of up to 1.6. I've seen
plastic lenses for eyeglasses with an ior of 1.66 (maybe a kind of
polycarbonate). Plastics do usually have a lower ior though.
Don't confuse optical density with real density.
Date: 11 Nov 2002 05:07:48
Message: <3dcf8174$1@news.povray.org>
news:3DCE9270.1C488F4C@gmx.de...
> Warp wrote:
> > >> >     ior 1.5
> > same as glass has.
> consts.inc:
Nyah, nyah, n-nyah nyah.
