POV-Ray : Newsgroups : povray.newusers : Hullo - display_gamma Server Time
18 Oct 2026 16:22:45 EDT (-0400)
  Hullo - display_gamma (Message 1 to 3 of 3)
Subject: Hullo - display_gamma
Date: 30 Oct 2002 02:21:21
Message: <3dbf8871@news.povray.org>
Hullo. My name is Paul and I'm a new user.
I can't get my head around this display_gamma thing. Using the pic & stuff
in the Help, I keep getting a match on 2.8 to 3.0 - that can't be right, can
it?
Has anyone got any different way of finding display_gamma (or explaining
what I should be doing to find it), that's probably all I need.
Thanks
Paul
:o)
Subject: Re: Hullo - display_gamma
Date: 30 Oct 2002 04:34:39
Message: <3DBFA7D9.701@free.fr>
> it?
Depend on your monitor and video card (some have correction for gamma,
which may worsen thing if applied in the wrong direction!).
My office monitor is far more than gamma 3 ! (in fact the red, green and
blue gamma are not identical for it, but I use the correction from the
video card, which allow to split the gamma setting, to get a single
value for povray.)
Best check so far I have found is to render the povray portfolio, on the
  stone1.inc third html page (3 of 14), you should look at T_Grnt15 and
T_Grnt17. If povray & your computer gamma are not correctly set, you
will only see black images. Whereas, once correctly tunned, T_Grnt15 is
pattern of dark black and lighter purplish strock of grey, and T_Grnt17
is a mix of dark yellow, green and blue (both skyblue and navyblue).
> Thanks
> Paul
> :o)
Date: 1 Nov 2002 03:05:39
Message: <3dc235d3@news.povray.org>
Thanks for that, Le.
I'm still not 100% sure if I know what I'm doing here though. I've stuck a
couple of test images up on my (otherwise empty) home page -
http://homepages.ihug.co.nz/~paulmc/gamma.htm
if anyone feels keen about having a look and telling me what they think it
would be appreciated.
One (quite possibly) brilliant, or (most likely) silly, idea I have had is
rendering a file off the IRTC CDs with different display_gamma's till I get
it looking the same as the pic on the CD - would that work do you think?
Thanks for your time
Paul
:o)
"Le Forgeron" <jgr### [at] freefr> wrote in message
news:3DB### [at] freefr...
stuff
can
> > it?
> value for povray.)
> > Thanks
> > Paul
> > :o)
