POV-Ray : Newsgroups : povray.newusers : Terragen Files to TGA? Server Time
6 May 2026 07:42:14 EDT (-0400)
  Terragen Files to TGA? (Message 1 to 8 of 8)
Subject: Terragen Files to TGA?
Date: 1 Sep 2002 13:28:26
Message: <3d724e3a$1@news.povray.org>
How do i convert Terragen files into a format useable as a POV height field?
I guess this means .ter file to .tga?
Thanks,
Tim
Subject: Re: Terragen Files to TGA?
Date: 1 Sep 2002 15:23:36
Message: <3D726A06.223FB291@pacbell.net>
Unfortunately I don't know of a direct conversion route. The program
Leveller - http://www.daylongraphics.com/ - can import .ter files and
export to POV-Ray but it is a roundabout method of getting there.
Ken Tyler
Date: 1 Sep 2002 17:47:35
Message: <3d728af7@news.povray.org>
3d724e3a$1@news.povray.org...
field?
You can try HCREdit by fellow Pover Christof Hormann.
http://www.tu-bs.de/~y0013390/
Export the terrain file as RAW 16 bits, Intel byte-order, write down the
size (default is 257 x 257)
Import it in HCREdit as RAW, same size, skip header size 1 (otherwise it's
just snow), 16 bit grayscale
Save as PNG 16 bits for use in POV-Ray
You'll have to reverse it scale <1,1,-1> translate z
To get an exact result you'll have to note the exact size and height of the
terrain in TG and scale it accordingly in POV-Ray.
(disclaimer : this is fresh knowledge as I discovered all this a couple of
hours ago !)
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 1 Sep 2002 23:25:04
Message: <web.3d72d95a10ff7c72a183f11c0@news.povray.org>
>Thanks,
>Tim
You can try "wilbur", though I had some problems with it.
A perfect job does "forester" by Stephen Dartnall. It is not free, but it is
the only program capable of reproducing the exact camera settings as in
terragen.
Norbert
Date: 2 Sep 2002 07:59:46
Message: <kik6nu8eo3btolkotcmk2pk6p3hkb9d42f@4ax.com>
On Sun, 1 Sep 2002 13:28:17 -0400, "Tim McMurdo"
What do you use to generate the Terragen file? Terragen? WorldMachine?
Peter Popov ICQ : 15002700
Date: 3 Sep 2002 07:55:03
Message: <web.3d74a2a410ff7c72eeb14df0@news.povray.org>
I am using Terragen to generate the files.
Thanks,
Tim
Date: 5 Sep 2002 20:30:12
Message: <web.3d77f66b10ff7c725b832b940@news.povray.org>
>Thanks,
>Tim
I think that there are some Terragen plugins that export to POV-Ray's
special TGA format.
=RAY=
Date: 7 Sep 2002 13:55:18
Message: <web.3d7a3d4010ff7c72a4b0cf6c0@news.povray.org>
>special TGA format.
>=RAY=
Firmament v1.6 - http://www.mclusky.co.uk/firmament/ - will allow the user
to 'import' .tga files, but not export...
There are various RAW formats allowed for exporting to, as well as a windows
bmp format (with For Export Only,
http://homepages.ihug.co.nz/~jomeder/feo/index.html)...  Take a stab with
those perhaps...
~james
