POV-Ray : Newsgroups : povray.newusers : loop in function Server Time
18 Oct 2026 18:46:37 EDT (-0400)
  loop in function (Message 1 to 6 of 6)
Subject: loop in function
Date: 25 Aug 2002 13:11:06
Message: <3d690faa$1@news.povray.org>
Hello,
I would like to define a function with a while loop inside, like this :
#declare my_array = array[Imax] {
	function ...
} // array of functions
#declare my_function = function {
	#local res = 0;
	#local I = 0;
	#while (I < Imax)
		#local res = res + my_array[I](x,y,z);
		#local I = I + 1;
	res
but povray complains about x, y and z being vectors, not floats.
I know there is a sum(...) pattern which could achieve the same thing, but
I put a sum for the example, it could be whatever loop in a function,
which tries to use the x, y, z coordinates that fails.
Adrien Rebollo
Subject: Re: loop in function
Date: 25 Aug 2002 13:50:00
Message: <3D6918C8.6CC91DDA@gmx.de>
Adrien Rebollo wrote:
> Hello,
You are mixing up the different levels in a POV-Script.  #declare/#local
work at parse time and not during rendering, therefore
tries to assign a value to res while parsing and expects x, y and z to be
symbols for 1 unit vectors like elsewhere in a POV-Script.
For how to use arrays of functions and loops in functions see the
'IC_Merge_Array()' macro in the IsoCSG include file.
Date: 25 Aug 2002 14:11:22
Message: <3d691dca@news.povray.org>
Thank you very much.
So, something like this would work :
        #local I = 0;
        #while (I < Imax)
                #if (I>0) + #end
                my_array[I](x,y,z)
Before you answered, I tried the sum pattern, and I have another error that
I do not understand :
        sum (I, 0, Imax, my_array[I](x,y,z))
gives me
Parse Error: Expected 'numeric expression', undeclared identifier 'I' found
instead
What is the trick ? (it is only curiosity, I will use your method anyway)
Adrien Rebollo
>> Hello,
>> but I put a sum for the example, it could be whatever loop in a function,
> Christoph
Date: 25 Aug 2002 18:27:26
Message: <3d6959cd@news.povray.org>
> gives me
> instead
  Well, it's exactly what the error message says: I has not been defined
anywhere, so POV-Ray can't know what do you mean by it.
  You have to #declare its value.
Date: 25 Aug 2002 18:44:14
Message: <3d695dbd@news.povray.org>
>> gives me
>> found instead
Then why does this work ?
        sum (I, 0, Imax, 2*I)
I have not #declared I either.
Date: 25 Aug 2002 19:07:07
Message: <3d69631b@news.povray.org>
  I get this:
File: ...  Line: 3
} <----ERROR
Parse Error: Expected 'parameter identifier or floating-point constant identifier', }
found instead
