Hi all...
Mark here. I am extremely new to POVray, and Ihave a couple quick questions.
I model an object in Moray, and render it in POVray, but a lot of my
objects(including some .udo files I import) have really bad aliasing on the
edges that I cannot seem to figure out. I have tried all the settings I can
to get these to work. Basic objects like Spheres and cones, etc. don't seem
to have this problem. If I make an object...say a column, that uses a few
merged shapes, the whole thing looks like crap. I had tried raising the
resolution levels, the antialiasing levels, and even the #x#
settings....HELP! I really think I could be good at this stuff if I could
get past these small problems I keep running into. Any help would be
appreciated.
Thanks,
Mark
Hi all,
Mark again. I re-read the original post I made, and after a quick crash
course in ray trace nomenclature, I found that I actually have a bad
"aliasing" problem. The edges of my renderings have a "stepped" or "jagged"
look to them, and I would like them to go away. I have rendered a few
spheres over planes (standard newbie fare I hear) and they turn out nice,
but I can't get a complex model(by my standards anyway) to render nicely. Is
there anyone who can tell me what settings to specify to get the nicest
renderings? If I knew the maximum setting, and the minimum as well as what
the setting is and where to place it, I think I can work out the rest.
Please, can someone help? I have some nice models I have made, and would
like to see them realized in a nice rendering.
Thanks and regards,
Mark
"Mark" <haz### [at] comcast net> wrote in message
news:3d462ee9$1@news.povray.org...
> Hi all...
Hi...
<snip>
Hmm, it sounds as though you just need to turn on anti-aliasing. Assuming that
you're using pov for windows, just select one of the AA formats for rendering in
the output dropdown, or specify +A 0.3 in the command line.
However, you say that when you render a sphere or other primitives, the "jaggys"
are not present, which is a bit confusing, since spheres are very subject to
jaggys.
> <snip>
that
rendering in
"jaggys"
to
> jaggys.
Since he raised the "antialiasing levels", that means he tried that...
I am not a PoV-Ray guru, so I can't really help :-(
Perhaps Mark could post a simple model showing this problem on p.b.s-f, so
experts can take a look.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
"Philippe Lhoste" <Phi### [at] GMX net> wrote in message
news:3d467bdc$1@news.povray.org...
Well, it means that it sounds like he tried that.... ;)
probably the best idea.
You should look at the final image, which is saved by POV-Ray to the
directory configured in Moray or POV-Ray itself (probably the same directory
where the scene file itself resides), with some image viewer.
Moray scales the image to the preview window, which can cause some
artifacts which aren't in the actual rendered image.
Subject: Re: Extreme Newbie, pixelization problem
Date: 30 Jul 2002 11:09:00
Message: <3d46ac0c@news.povray.org>
In article <3d4696be@news.povray.org> , Warp <war### [at] tag povray org> wrote:
I think none of you guys read his second post (maybe it wasn't there, the
date suggests it was however) and didn't carefully read his first one
either. he used some incorrect terminology in the first one but still
described his problem accurately....
If you carefully read the first post you find that he reports the problem
only with objects from udo files. AFAIK (I don't use Moray) those are
simply triangle data files. So the problem is not with POV-Ray but with the
input data triangles. I don't know what options Moray has to smooth
triangle meshes, but I guess there is some, so maybe someone could explain
him how to do that?
Thorsten
e-mail: tho### [at] trf de
"Thorsten Froehlich" <tho### [at] trf de> wrote in message
news:3d46ac0c@news.povray.org...
Well, no, he says that
> but a lot of my
> objects(including some .udo files I import) have really bad > aliasing
which rather implies that the problem is not limited to .udo's.
Hi all,
Mark again. Okay, I see you guys have replied to my original post, and
thanks. I have been wrecking my brain trying to find more info in the
tutorials/manuals out there, and I find that they all assume a little
understanding of raytracing. I have found out how to set the anti aliasing
in povray, and I assume that a threshold of 0.0 is the best one can get. I
rendered a couple scenes at this setting and it improved a lot, but I still
have problems with aliasing. I have also noticed that if I dolly the camera
away from the model it cleans up. I gather that the closer the zoom on the
object, the more it will alias. The scene I would like to render has
several close up views of objects (cone/torus merged, kind of like a dunce
cap with a moulding around the opening for the head) I also noticed that
when I have the threshold set to 0.0 the pixels that were aliased terribly
at no AA were now kind of "off the edge" or seperated from the model. It
looks as if particles of the model are coming off the edge slightly( I
don't think I am explaining this well) Sort of like the model was shedding
dust from itself. My question now is this: Is there a way to make a model
have sharp edges at a very close view, and if so how? If you need more
information from me to help, I will be watching this forum a few times a
day.
Thanks,
Mark
Perhaps if you post some sample images in p.b.i, we can better see the
problem you are having.
-tgq
On Tue, 30 Jul 2002 13:10:35 -0400, "TinCanMan" <Tin### [at] hotmail com>
Since he is posting in povray.newusers it can be worth to explain p.b.i means
povray.binaries.images group designed for posting images.
ABX
means
> ABX
Mark, what he said.
-tgq
Date: 30 Jul 2002 13:53:38
Message: <3d46d2a2@news.povray.org>
Hi Mark!
As you mention a torus, it's most likely, that you reached the boundaries of
floating-point-precision. There had been problems with tori reported before
and floating point precision was the answer even with quite reasonable
scales of the inner and outer radius. The closed form of the torus somewhat
"exploded" into a bunch of single points IIRC. As far as I know there is no
easy way to solve the problem (which has nothing to do with anti-aliasing).
Changing the scale of the object might help (make it bigger and move the
camera farther away).
As other mentioned, posting some sample-code and a picture of the problem
will help to look into your problem.
Marc-Hendrik
Okay, I am posting a small pic in the binaries section, it is .png format so
everyone should be able to view it. The image was rendered at 320x240 with
an AA threshold of 0.0 I hope it is enough for you to see my problem and
help out. By the way, don't judge me on the content...I modeled that in
like 5 minutes just so you guys could see the problem. Thanks, Mark
In article <web.3d4720047fe0707b634c49e20@news.povray.org>,
Looks like that "jagged edge" is just the cone poking through the side
of the torus. Just reduce the radius of that end of the cone or
otherwise adjust the cone so it doesn't go through like that.
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
Christopher James Huff wrote:
>In article <web.3d4720047fe0707b634c49e20[at]news.povray.org>,
The model shown is just an example, but that is the way it will be in the
real scene. I am talking about the jaggies that are on the edges of the
cone itself. Is this perhaps a problem with how an object protrudes through
another? Thanks for the reply, but I need the cone to poke through.
Thanks,
MArk
>ABX
heheh I figured that one out...Been a news user for quite a while :)
Date: 31 Jul 2002 02:38:49
Message: <3d4785f8@news.povray.org>
> so everyone should be able to view it. The image was rendered at 320x240
> with an AA threshold of 0.0 I hope it is enough for you to see my problem
> and help out. By the way, don't judge me on the content...I modeled that
> in
As others already have pointed out you can use AA method 2 with a high
recursion level and a threshold of 0.0. This should work but is really
slow. An alternative is to render the picture 4x bigger with normal AA
settings and scale it down in a graphic program.
You could also try my modified version of POV-Ray which brings some new
AA-methods: http://www.povworld.org/povray/aa.html
It is only POV 3.1 though and there is no windows binary.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Actually no, but that's another story in itself.
(Well, ok, strictrly speaking it's the best *threshold* one can get, but
it's not the best *antialiasing* one can get.)
> I rendered a couple scenes at this setting and it improved a lot, but I still
Could you please tell us whether you are looking at the actual rendered
image, which is saved on disk when you render it, or at the preview image
which Moray shows scaled inside itself (in the fourth subwindow, or however
you have configured it). It would help a lot to know this small detail.
If you are rendering at a resultion of, let's say, 320x240, and the
preview window of Moray is, let's say 400x300 pixels in size, the actual
image is scaled larger and pixelation happens. Do you understand this?
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
How that's different from using antialiasing method 1 with threshold 0
and four samples per pixel?
(Method 2 will give you a better result anyways.)
Okay,
Well I got it figured out. Thanks for the help...the recursive method works
great for this type of model. Now all I need is talent!
Thanks again,
Mark
With method 1 and threshold 0 you have a fixed number of samples per final
pixel. But when you scale it 4x bigger and use a threshold >0 you have a
dynamic number of samples per final pixel with a minimum of 4.
- Micha
