POV-Ray : Newsgroups : povray.newusers : Saving output as 16bit grayscale PNG Server Time
18 Oct 2026 19:44:38 EDT (-0400)
  Saving output as 16bit grayscale PNG (Message 1 to 3 of 3)
Subject: Saving output as 16bit grayscale PNG
Date: 18 Jul 2002 05:29:15
Message: <3d368a6b$1@news.povray.org>
Dear all,
 I'd like to save my raytraced image as 16bit/color PNG and eventually
convert the PNG into either 16bit grayscale PNG or 16bit grayscale TIF,
which would result in a range of zero to 65,535 steps in gray level.
When I write down the +FN16, would this be a compressed 16bit per color PNG?
Would there be any other options inside the POV-ray with which I could save
it as 16bit grayscale PNG or 16bit grayscale TIF?
Thanks,
Jong
Subject: Re: Saving output as 16bit grayscale PNG
Date: 18 Jul 2002 05:58:03
Message: <3D36912B.3CC46F12@gmx.de>
Jong wrote:
> Dear all,
When you use '+fn16' you will get a 3x16 bit rgb PNG file.  When
specifying 'hf_gray_16 on' in global_settings you will always get a 16 bit
grayscale PNG with '+fn'.  Same applies for PPM (+fp).
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
Date: 18 Jul 2002 08:13:10
Message: <3d36b0d6@news.povray.org>
Thank you, Chris.
Works perfect!
One more newbie question about the gray level or color calculation of the
POV for precision:
In order to get higher precision output such as 16 bit/color PNG, what
parameters should be adjusted?
For example, do I better change the adc_bailout value from 1/255 default to
1/65000?
Are there any to be changed accordingly?
Jong
news:3D36912B.3CC46F12@gmx.de...
> Jong wrote:
> > Dear all,
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
