How do i create a realistic looking moon in pov-ray. I've attempted to
re-create
the moon. But it dosen't look anything like it, it looks more like a
golfball stuck in the
middle of the canvas. I tried using image maps but these look dull and flat
and nothing
seemed to work out as i did. When i rendered the scene in pov-ray it looked
like a 2d
object just flat.
In the pov-ray help files, it illustrates how to create the sun, for the
image i wanted to create the sun
behind the moon sphere. When i render it the sun is nowhere to be seen .
Thanks in advance.
maheshtd <mah### [at] onetel net uk> wrote:
> When i rendered the scene in pov-ray it looked like a 2d
> object just flat.
Perhaps it's just me, but when I look at the Moon in the sky, it looks
2D and flat.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> 2D and flat.
no face ?
ABX
hi,
try the following for a 3d moon (code is adapted from Gilles Tran´s
hfsphere.pov : http://www.oyonale.com/ressources/english/sources09.htm)
// Wrapping a height field on a sphere
// (c) 2000-2001 Gilles Tran tra### [at] inapg inra fr
// adapted by Norbert Kern (nor### [at] t-online de) to create a
realistic 3d moon
// This demo file shows an example of wrapping a height field on a sphere
// Requires POV-RAy 3.5
#include "functions.inc"
#include "textures.inc"
#include "metals.inc"
global_settings {max_trace_level 3}
location <0,0.5,-4>
direction 1.5*z
right 4/3*x
look_at <0,0,0>
background{color rgb 0}
light_source{<1000,1000,-1000> color rgb 1}
// First we declare a function with the map_type 1 (spherical) mapping
#declare hfmoon = function {pigment {image_map {jpeg "Moonbump" map_type 1
interpolate 2}}}
#declare rs = 0.1; // try several rs values <0.1; the lower it is the more
realistic is the effect and the more "flat" is the moon
isosurface{
function {f_sphere(x,y,z, 1) + rs - hfmoon(x,y,z).hf*rs}
contained_by {sphere{0,1}}
max_gradient 20 // <--- important- adjust to your picture otherwise
strange things happen
texture {pigment {image_map {jpeg "moonmap" map_type 1 interpolate
2}}}
rotate y*-15
rotate x*-20
Pov-Ray 3.5 beta is essential.
The hereby needed files MoonMap.jpg and MoonBump.jpg are from
http://snorkel.rtfm.com.au/~om/graphics/Textures/Planets%20and%20Satellites/
planets_and_satellites.htm.
Good luck
Norbert
"maheshtd" <mah### [at] onetel net uk> schrieb im Newsbeitrag
news:3d0f2c90@news.povray.org...
> re-create
flat
> and nothing
looked
> like a 2d
> object just flat.
> Thanks in advance.
