POV-Ray : Newsgroups : povray.newusers : --- Server Time
6 May 2026 10:20:07 EDT (-0400)
  --- (Message 1 to 3 of 3)
Subject: ---
Date: 4 Jun 2002 05:33:35
Message: <3cfc896f@news.povray.org>
I want to learn how to create a space scene in pov-ray. I've got the galaxy
patch from one of the sites. How would i render it, any tips ideas.
Thanks in advance
Subject: Re: (where is subject ?)
Date: 4 Jun 2002 05:46:56
Message: <mm2pfu0pv1k6ta393285d6t428eco9rn6o@4ax.com>
On Tue, 4 Jun 2002 10:33:58 +0100, "maheshtd" <mah### [at] onetelnetuk> wrote:
"space scane" is very complex topic. What you mean as space ? Far look at
galaxy ? Spaceship in close zoom ? In general best tutorial is studying other
scenes. Take a look at http://www.irtc.org/stills/index.html for various
topics of irtc competition. Some of them contains space scenes with sources.
For example look in http://www.irtc.org/search/ for 'galaxy' keyword.
> I've got the galaxy
What exact problem you have ? Have you tried sample scenes ? Have you read
documentation how to render with POV-Ray ? What error message ? What operating
system ?
ABX
Subject: Re:
Date: 4 Jun 2002 08:22:59
Message: <3cfcb123@news.povray.org>
maheshtd <mah### [at] onetelnetuk> wrote:
> I've got the galaxy patch from one of the sites.
  You should learn the correct terminology to avoid misunderstandings.
  "Patch" is known as a different version of POV-Ray, where someone has
added (or modified existing) code (C, or C++ in the case of 3.5) which does
something POV-Ray does not normally support by itself.
  What you downloaded is an include file. (Some people would call it "plugin"
but I personally am against that term.)
  How about reading the help files which came with it?
