POV-Ray : Newsgroups : povray.newusers : Anti-aliasing Server Time
12 Oct 2026 15:24:48 EDT (-0400)
  Anti-aliasing (Message 51 to 55 of 55)
<<< Previous 50 Messages Goto Initial 50 Messages
Subject: Re: Anti-aliasing
Date: 2 Apr 2002 14:06:33
Message: <3caa0139@news.povray.org>
Kari Kivisalo <pro### [at] luxlabcom> wrote:
> Will all IRTC images that have been resized with other than
> nearest neighbour method have to be disqualified now?
  IMO the rule allowing resizing should be removed (and the FAQ changed
to the opposite of what it's now).
Date: 2 Apr 2002 15:31:27
Message: <3CAA1594.90509@ignorancia.org>
Kari Kivisalo wrote:
> It's just another resampling filter. Look at the table.
> http://www.genaware.com/html/support/faqs/imagis/imagis10.htm
   Yes, technically speaking, it's a resizing (resampling).
   !? ...why? Resizing is allowed, at least for the moment.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 2 Apr 2002 15:43:19
Message: <oiqiau4c9m169usbtpqol03sieplqv9hru@4ax.com>
On Tue, 02 Apr 2002 08:55:00 +0200, Włodzimierz ABX Skiba
<abx### [at] babilonorg> wrote:
>What about writing the same as function in 3.5 ?
My thoughts exactly :) Neither Gaussian blur nor Mosaic should be very
hard to do in 3.5, esp. the latter. With the orthographic camera and
an image_map on a plane in front of the camera, one could almost as
much as make Warp happy :) <ducks>
I haven't really done much in POV recently... maybe I should play
around with image functions and try to recreate the post-processing
filters that were in MegaPOV. If RL permits, that is :(
Peter Popov ICQ : 15002700
Date: 4 Apr 2002 19:26:27
Message: <3CACEF39.31922A83@luxlab.com>
Jaime Vives wrote:
> (still, I can't get such good results even using the gaussian blur on
> "The Gimp"... he surely cheated even more! ;).
I tried both Gaussian filters in Gimp and can't get good results.
Use Photoshop :)
_____________
Kari Kivisalo
Date: 5 Apr 2002 02:46:39
Message: <3CAD56D9.8000301@ignorancia.org>
   Yes, results with the Gimp are only a bit better than +a0.0. Anyhow,
I will surely never use such technique, mostly because more detail on my
images usually helps to make my mistakes more visible... :(
> Use Photoshop :)
   Well, I don't have a valid plataform... ;) Also, it's perhaps
excessive for my little use of such programs... since I now use internal
height_fields and rarely use image_maps, I mostly use the Gimp to put my
sig and to convert to jpg.
