POV-Ray : Newsgroups : povray.newusers : Anti-aliasing Server Time
12 Nov 2026 20:13:12 EST (-0500)
  Anti-aliasing (Message 6 to 55 of 55)
<<< Previous 5 Messages Goto Initial 50 Messages
Subject: Re: Anti-aliasing
Date: 31 Mar 2002 11:51:42
Message: <3CA73F75.D5CEDF48@hotmail.com>
Warp wrote:
> JRG <jrg### [at] hotmailcom> wrote:
> > If this doesn't work either, render at bigger resolution and re-size
> > your picture with your favourite paint program.
>   How is this different from using +a0.0?
+a0.0 forces all pixels to go to the full depth.
+a0.1 at a higher resolution simulates a minimum depth of anti-aliasing,
without forcing full depth for all pixels.
A minimum aa depth might be a useful feature.
Rusty is rendering!
Date: 31 Mar 2002 13:59:58
Message: <3ca75cae@news.povray.org>
> Anyway, IMHO, it's better to render at bigger resolution. This is a pretty common
> technique to avoid many AA pitfalls.
  I still don't understand how that's different from using +a0.0.
(What +a0.0 does in practice is exactly what you propose: It kind of renders
an image at higher resultion and "scales" it down to the desired resolution.
This happens because it sends the extra rays for *each* pixel regardless of
what there is in the image; that's exactly the same as rendering at higher
resolution. You can control the extra resolution with +r.)
Date: 31 Mar 2002 14:01:24
Message: <3ca75d03@news.povray.org>
  Ie. exactly what rendering at higher resolution does.
  Yes, but rendering at higher resolution forces povray to shoot more rays
even though it wouldn't be necessary.
Date: 31 Mar 2002 15:13:26
Message: <chrishuff-0E6284.15142531032002@netplex.aussie.org>
In article <3ca75d03@news.povray.org>, Warp <war### [at] tagpovrayorg>
+a0.0 forces it to shoot all the rays for every pixel. Rendering at a
higher resolution and resizing lets you control the minimum sampling
density (making your objects more likely to be visible) while still
taking advantage of adaptive sampling for faster rendering.
An additional "minimum samples" control would do the same thing, without
the additional external step of reducing the final image in size, which
will give different results with different programs.
Date: 31 Mar 2002 15:29:22
Message: <3ca771a2$1@news.povray.org>
+a0.0 worked perfectly. Plus it fixed some artifacts I had with image maps.
Thanks a bunch!!
news:3ca678ed@news.povray.org...
> Chris Becker <cmb### [at] ritedu> wrote:
> > I have a very thin object that is not showing up correctly because some
> > pixels pick it up and others don't hence creating jaggies, even with
> > anti-aliasing. My question is, what do I adjust in anti-aliasing to
improve
> > this? And does increasing or decreasing the threshold provide for a
better
> > sample?
>   Try +a0.0 if it helps. (Note that it will slow down the rendering a
lot.)
M()}}
Warp -
Date: 31 Mar 2002 22:21:49
Message: <3CA7D24E.49AECDA6@luxlab.com>
Currently this is the best povray can do (+a0.0 +r9). Notice
the aliasing artefacts on the horizontal lines.
http://luxlab.com/tmp/aa.png
Rendered at 500% resolution (+a0.3 +r3), low-pass filtered
(Gaussian 2.5 pixels) and resampled.
http://luxlab.com/tmp/aa_hq.png
I like the one with clean lines.
_____________
Kari Kivisalo
Date: 1 Apr 2002 02:33:32
Message: <3ca80d4c@news.povray.org>
> _____________
> Kari Kivisalo
Kari, what is the difference between your method and rendering at 500 %,
applying a mosaic filter (5 pixels) and resizing with method "nearest
neighbor"?
Norbert
Date: 1 Apr 2002 04:40:25
Message: <8hagau0e2k27vdonrgp55dd1u8r0lp6kll@4ax.com>
On Mon, 1 Apr 2002 09:33:30 +0200, "Norbert Kern"
>neighbor"?
Gaussian blur uses a Gaussian distribution of samples and is more
'natural' than a mere average. They are both low-pass filters, one
just happens to be closer to reality, IMHO.
Peter Popov ICQ : 15002700
Date: 1 Apr 2002 06:36:00
Message: <3ca84620$1@news.povray.org>
thanx
Norbert
Date: 1 Apr 2002 12:31:36
Message: <3CA89977.BA06A28B@luxlab.com>
> neighbor"?
http://luxlab.com/tmp/aa_mosaic.png
Scene (thin lines) from http://www.povworld.org/povray/aa.html
plane{z,0
  pigment{gradient y
    pigment_map{
      [0 rgb 1]
      [0.47 rgb 1]
      [0.47 rgb 0]
      [0.53 rgb 0]
      [0.53 rgb 1]
      [1 rgb 1]
  finish{ambient 1} scale .1 rotate y*-50
camera{location <0,0,-5> look_at 0}
The most important part is the Gaussian blur. I used 500% resolution
just to get those very thin lines. For normal a scene 200% to 300% and
1 to 1.5 pixel blur radius should be enough. The 50% blur radius seemed
to be the minimum required to prevent visible aliasing. The image will
look soft. Sharpening filter will just bring back the the jagged edges.
It's a delicate balance between artefect free and sharp image :)
_____________
Kari Kivisalo
Date: 1 Apr 2002 13:51:59
Message: <3ca8ac4f@news.povray.org>
Looks really smooth. But I think it makes the lines also appear thicker
than they are. You get a similar result when you just 'blur' the texture in
POV-Ray and then use the normal aa method without oversizing and scaling:
pigment{gradient y
        pigment_map{
        [0 rgb 1]
        [0.41 rgb 1]
        [0.5 rgb 0.3]
        [0.59 rgb 1]
However the bluring would have to be done dependend on the distance to
remove the artifacts in the mid-distance.
Maybe one could add a 'blur texture when far away'-feature to POV.
- Micha
objects.povworld.org - The POV-Ray Objects Collection
book.povworld.org    - The POV-Ray Book Project
Date: 1 Apr 2002 14:26:00
Message: <3ca8b448@news.povray.org>
> _____________
> Kari Kivisalo
I made some experiments with your method this afternoon.
It is much better than my method, which I used in my two last IRTC entries.
I will no more use normal POV-Ray antialiasing, as such methods show enhance
most pictures considerably.
As an added benefit you get an high res version for printing at the same
time.
Date: 1 Apr 2002 14:32:36
Message: <3ca8b5d4@news.povray.org>
Me too. And it seems to work well even with non antialiased pics.
Jonathan.
Home: http://digilander.iol.it/jrgpov
Date: 1 Apr 2002 14:50:49
Message: <3CA8BA16.BA81CE26@luxlab.com>
> than they are.
Which brings us to the question of optimal sampling filter
for 2D signal. My theory is that the artefacts in the default
povray aa and mosaic filtered image appear because the sampling
filter is a rigid box. This produces a ringing efect. This can
be avoided by sacrificing higher frequencies and using a smooth
edged filter.
This increases noise but reduces sampling artefacts:
+am1 +a0.0 +r9 +j13.5
It's always a trade-off :(
_____________
Kari Kivisalo
Date: 1 Apr 2002 15:08:40
Message: <3ca8be48@news.povray.org>
  I don't think you can do that with an IRTC entry. The rules prohibit
post-processing.
Date: 1 Apr 2002 15:16:16
Message: <3CA8C010.F45B7F42@luxlab.com>
> post-processing.
Do they prohibit anti-aliasing or resampling? This is just advanced aa.
Or if that doesn't fly, then it's per pixel weighted average contrast
adjustment :)
_____________
Kari Kivisalo
Date: 1 Apr 2002 15:30:09
Message: <3CA8C352.3A4124FC@luxlab.com>
http://luxlab.com/tmp/aa_noise.png
_____________
Kari Kivisalo
Date: 1 Apr 2002 17:52:37
Message: <3ca8e4b5@news.povray.org>
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3ca8be48@news.povray.org...
> post-processing.
I should quote the rules:
http://www.irtc.org/stills/faq.html#q1.1.11
[1.1.11] Exactly what do you mean by "post-processing"?
"One guideline that has been mentioned is that
any process which affects every pixel in the image is usually okay,
but that's not a hard and fast rule--it's just used to encompass gamma
correction, resizing, conversion to JPEG format, and so forth, all of
which are legal."
I see application of the method as a special form of image resizing, which
is certainly allowed.
But perhaps I´m not right here.
Norbert
Date: 1 Apr 2002 17:53:06
Message: <3ca8e4d2@news.povray.org>
> adjustment :)
  It is post-processing in an extent prohibited by the rules. I don't see
any rule allowing resizing the rendered image.
  If that would be allowed, what else? Some filtering? Blurring?
Stylisizing? Lens flares?
  No, the rules don't allow that kind of post-processing, period.
Date: 1 Apr 2002 17:59:29
Message: <3ca8e651$1@news.povray.org>
news:3ca8e4d2@news.povray.org...
resizing is allowed :
http://www.irtc.org/stills/faq.html#q1.1.14
[1.1.14] Is it legal to resize my image after it is rendered?
Yes, it is. Be careful doing it, though--unless done correctly, resizing can
often add unwanted visual artifacts to an image.
Norbert
Date: 1 Apr 2002 18:04:20
Message: <3ca8e774@news.povray.org>
  I think that's really bending the rules.
  The purpose of the contest is to see what a renderer can do. In order to
achieve this purpose, only the image output by the renderer is allowed.
  Adjusting brightness/contrast is in the limits of this, although still
allowed.
  However, improving the antialiasing of an image by post-processing it
with a paint program clearly breaks this purpose and the rules. The resulting
image is not what the renderer generated, but it has been improved with
a paint program.
  There's a simple way of seeing the difference between adjusting
brightness/contrast and smoothing an image by scaling it smaller (ie.
improving its antialiasing): If the image has some pixel-sized artifacts
(which usually appear due to bad antialiasing), brightness/contrast
adjustments will not do anything about it, but they will still be there.
However, scaling the image smaller can get rid of these artifacts. Thus
what it is doing here is to remove artifacts produced by the renderer with
a paint program. The resulting image is not the one produced by the
renderer, but an improved one.
  If that's not illegal post-processing, then what is?
  How is this different from, for example, applying a blur filter with the
paint program to remove pixelation? Why blurring should be any more illegal?
Date: 1 Apr 2002 18:05:30
Message: <3ca8e7ba@news.povray.org>
  See my other post.
Date: 1 Apr 2002 18:14:02
Message: <3CA8E9BC.DC65841@luxlab.com>
Resizing is allowed.
_____________
Kari Kivisalo
Date: 1 Apr 2002 18:29:12
Message: <3ca8ed48@news.povray.org>
  My statement still holds.
  I don't think that the people who decided about that rule thought that
it could be used to enhance the quality of the image.
  It's the spirit of the IRTC rules that the quality of the image produced
by the renderer should not be enhanced by post-processing. The image should
be the one produced by the renderer, with no modified quality. If the
image produced by the renderer had artifacts, it's against the rules to
remove these artifacts with a paint program. Using the resizing trick
is essentially doing this.
  We should think about the rules in their whole context and understand
the spirit of the rules, not just their letter.
Date: 1 Apr 2002 20:23:17
Message: <3ca749ea.8023841@localhost>
On Sat, 30 Mar 2002 17:56:47 -0500, "Chris Becker" <cmb### [at] ritedu>
>anti-aliasing. My question is, what do I adjust in anti-aliasing to improve
>this? And does increasing or decreasing the threshold provide for a better
>sample?
>Thanks in advance!
I had the same problem just a fw days ago: a rendering with very small
text objects.  The anti-aliasing was not really working because
parts of the letters were falling between adjacent pixels, so that
the anti-aliasing was not triggered.  I ended up rendering the image
at double size, with anti-aliasing ... and sizing it down in a paint
package.  That fixed it.
Date: 1 Apr 2002 20:48:16
Message: <3ca90de0$1@news.povray.org>
So what's the big deal of actually modifying POV-Ray with a new AA method?
AA shoots multiple rays for a single pixel which is then averaged. How is
that different than just taking a higher rendering of the image and
averaging the pixels? Why is it such a big deal to modify the renderer?
Megapov does post processing and I don't see such huge debates about that...
news:3ca8ed48@news.povray.org...
should
M()}}
Warp -
Date: 2 Apr 2002 01:55:39
Message: <qcliauofntasipgfkt4pthj3f0un428911@4ax.com>
> post-processing.
What about writing the same as function in 3.5 ?
ABX
Date: 2 Apr 2002 08:14:53
Message: <3ca9aecd@news.povray.org>
  Nothing.
  It's different because the latter method is post-processing. It's not
something the renderer itself supports, but has to be done with a paint
program.
  It isn't.
  Because it's the renderer itself which does it.
  The idea is to participate with the output image of a renderer, not a
rendered image which has been enhanced with another program afterwards.
The IRTC rules prohibit post-processing for this reason.
Date: 2 Apr 2002 08:15:25
Message: <3ca9aeed@news.povray.org>
  How?
Date: 2 Apr 2002 08:26:16
Message: <61cjau08140ufiukiigpsglkjl4k8d5tfb@4ax.com>
On 2 Apr 2002 08:15:25 -0500, Warp <war### [at] tagpovrayorg> wrote:
> How?
Knowing algorithm for particular effect in 2d manipulation software writing
macro/pattern applied to plane with ambient 1 and diffuse 0 under orthogonal
camera. Then it use all elements of typical still creation process but has the
same effect. OF course it is cheating but probably works.
ABX
Date: 2 Apr 2002 08:55:34
Message: <3ca9b855@news.povray.org>
  Well, I could just take a photograph, put it as pigment to a plane and
render that plane.
  Technically the resulting image has been produced by the renderer and is
perfectly legal according to the rules.
  However, somehow I doubt that I would win that way. ;)
Date: 2 Apr 2002 10:16:09
Message: <3CA9CBAC.8000600@ignorancia.org>
   Hmmm... I think the problem is not "resizing". Altough today paint
programs can resize much better, only resizing doesn't gives so good
results, at least not much better than +a0.0. The "artifact" or "moire"
removing step is done with the previous gaussian filter, and *this is*
postprocesing, not the resizing. IMHO, resizing only must be still
allowed, but perhaps has not much sense today, as there are no
resolution limits for the image (I think this rule was created to allow
people to fit the maximum resolution allowed at that time).
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 2 Apr 2002 10:23:19
Message: <3ca9cce6@news.povray.org>
  The problem with resizing an image smaller is that there are basically two
ways of doing it (from the point of view of the program):
  1. Make the image smaller by just dropping out pixel rows and columns
appropriately.
  2. Make the image smaller by calculating (weighted) averages of pixel
rows and columns.
  The problem with method 1 is aliasing.
  The problem with method 2 is that it's in practice filtering the image,
which can enhance its visual quality and is thus post-processing.
  There wouldn't be a problem with method 2 if post-processing was not against
the spirit of the competition. IMO it's such a big filtering process that it
does not fit inside the rules.
Date: 2 Apr 2002 10:25:35
Message: <3ca9cd6f@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3ca9aecd@news.povray.org...
<snip>
From what I understand of this debate, does this resize-for-better-aa really
break the rules, either in spirit or fact?
I take your point that to resize to get rid of artifacts is a definate no-no,
but the aa issue seems linked to the size of the image-output, rather than an
inherant problem with the scene.
In other words if the defect corrected by resizing is present in the high
resolution image, then you are breaking the rules. However, if the defect is not
present at high res., and you are merely trying to duplicate the "clean" image
at a lower-res. then I don't think any rules, spirit or fact, have been broken.
Date: 2 Apr 2002 10:31:51
Message: <3ca9cee7$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3ca9cd6f@news.povray.org...
<snip>
As a personal note, IMHO I've never really understood the IRTC leniency towards
post-process adjustment of brightness/contrast/etc.
I do it, but it seems a damn sight more dishonest than a resize for aa purposes
(never done that as I've never needed to).
Suggest this moves to irtc.general ?
Date: 2 Apr 2002 10:55:40
Message: <3CA9D4EF.6030407@ignorancia.org>
   Sure? I've tried it, and I can't get "much better" results *only*
resizing a 10 times bigger image (with The Gimp), than using +a0.0. The
only image where I've seen *really* better results was the one posted by
Kari, where he admits to have used "something more" than a pure resizing
(still, I can't get such good results even using the gaussian blur on
"The Gimp"... he surely cheated even more! ;).
   No, IMHO, this is not the spirit of the rule about postprocesing. I
think it tries to avoid mainly someone "adding" extra features to the
rendering, that is, adding "foregein pixels" (pasting figures or
objects, adding lens flares/sparkles/glow/etc..). And a "resize", even
with filters, only plays with rendered pixels.
   Anyhow, the line is very difficult to place... in this case, I think
it is a harmful postprocesing. A bad image is a bad image even with the
most fine definition of details (perhaps even worse!). A good image is
still good with the most poor antialiasing.
   For me, this is the typical "let the judges decide..." :)
Date: 2 Apr 2002 10:55:44
Message: <3ca9d480@news.povray.org>
  If we read the rules literally, resizing is allowed. There isn't anything
saying which resizing methods are allowed and which aren't; resizing is just
allowed, period. So resizing is not technically against the rules.
  However, IMHO using resizing as a method for improved post-process
antialiasing breaks the spirit of the IRTC rules. It's effectively a
post-process filter applied to the rendered image with a paint program.
  I am pretty sure that the people who allowed resizing when writing the
IRTC rules didn't think about this possibility and if they had known about
it, they would have thought more carefully.
  If you make, for example, the typical checkered-floor image (where you can
see the horizon), you will get aliasing artifacts no matter how big you render
the image. However, rendering at for example 8000x6000 and then resizing
it to 800x600 (by using some averaging algorithm) will get rid of most of
the artifacts (if not all of them). This is because most of the artifacts
are pixel-sized and what the resizing does is to calculate the average of
10x10 pixel squares, and these artifact pixels contribute little to the
average, thus practically disappearing. Thus resizing removes the artifacts
produced by the renderer.
Date: 2 Apr 2002 10:57:54
Message: <3ca9d501@news.povray.org>
  Usually tuning brightness/contrast does not modify the overall quality
of the image. If there are artifacts in the image, they will not go away
by this.
  (Of course even this has been proven to be false. As seen any some
radiosity experiments, adjusting brightness/contrast to a rather dark
radiosity scene can greatly enhance its visual appeal and quality...)
Date: 2 Apr 2002 11:07:48
Message: <3ca9d754@news.povray.org>
  By the same definition using filters like blur and motion blur is just ok.
Date: 2 Apr 2002 11:08:51
Message: <3ca9d793$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3ca9d501@news.povray.org...
> by this.
True, such tuning shouldn't affect technical scores (but I bet it does) -
however, it might have quite an impact on artistic. The adjustment shouldn't be
necessery if you set up your scene correctly in the first place....
On a related note, I've occasionally been quite pleased with some "improvements"
made to my images by conversion to .jpg.
Date: 2 Apr 2002 12:51:43
Message: <3ca9efaf@news.povray.org>
news:3ca9aeed@news.povray.org...
>   How?
Its easy for mosaic filtering and subsequent resizing.
I will write such a macro to avoid future discussions.
But in my eyes correction of gamma, brightness or contrast are much more
bending the rules than the antialiasing methods in discussion.
By the way using Pov-Ray for filter effects one can do some nice effects.
Does anybody know the exact algorithm for Gaussian Blur?
How the image edges are processed?
Norbert
Date: 2 Apr 2002 12:55:57
Message: <u2sjausb7r0g011em62gir4o87q3561mq0@4ax.com>
On Tue, 2 Apr 2002 19:51:42 +0200, "Norbert Kern"
not exactly blur but uses general method for such kind of effects:
http://news.povray.org/p8r76u08vo673fksp4jaks59h2au3bppkb%404ax.com
ABX
Date: 2 Apr 2002 13:14:36
Message: <3ca9f50c$1@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> schrieb im Newsbeitrag
news:u2sjausb7r0g011em62gir4o87q3561mq0@4ax.com...
> ABX
thanx, but I thought more in the direction of a seperate pass for
postprocessing with Pov-Ray.
It is because proximity pattern is extremely useful in some cases, but it is
slow.
Norbert
Date: 2 Apr 2002 13:19:27
Message: <8atjauoiokuh7am873r6bckplh6bs3go5v@4ax.com>
On Tue, 2 Apr 2002 20:14:35 +0200, "Norbert Kern"
> "W?odzimierz ABX Skiba" <abx### [at] babilonorg> schrieb im Newsbeitrag
> > ABX
> slow.
as I said I wasn't reffering to usefulnes of proximity in the subject of this
thread but reffered to general method of applying filters - sampling one pattern
(image_map, object pattern, whatever), then apply some weighting/equation,
subsample if necessary, output new rgb
ABX
Date: 2 Apr 2002 13:59:43
Message: <3CA9FFA1.E7550D43@luxlab.com>
It's just another resampling filter. Look at the table.
http://www.genaware.com/html/support/faqs/imagis/imagis10.htm
Will all IRTC images that have been resized with other than
nearest neighbour method have to be disqualified now?
_____________
Kari Kivisalo
Date: 2 Apr 2002 14:06:33
Message: <3caa0139@news.povray.org>
  IMO the rule allowing resizing should be removed (and the FAQ changed
to the opposite of what it's now).
Date: 2 Apr 2002 15:31:27
Message: <3CAA1594.90509@ignorancia.org>
   Yes, technically speaking, it's a resizing (resampling).
   !? ...why? Resizing is allowed, at least for the moment.
Date: 2 Apr 2002 15:43:19
Message: <oiqiau4c9m169usbtpqol03sieplqv9hru@4ax.com>
On Tue, 02 Apr 2002 08:55:00 +0200, Włodzimierz ABX Skiba
My thoughts exactly :) Neither Gaussian blur nor Mosaic should be very
hard to do in 3.5, esp. the latter. With the orthographic camera and
an image_map on a plane in front of the camera, one could almost as
much as make Warp happy :) <ducks>
I haven't really done much in POV recently... maybe I should play
around with image functions and try to recreate the post-processing
filters that were in MegaPOV. If RL permits, that is :(
Date: 4 Apr 2002 19:26:27
Message: <3CACEF39.31922A83@luxlab.com>
I tried both Gaussian filters in Gimp and can't get good results.
Use Photoshop :)
_____________
Kari Kivisalo
Date: 5 Apr 2002 02:46:39
Message: <3CAD56D9.8000301@ignorancia.org>
   Yes, results with the Gimp are only a bit better than +a0.0. Anyhow,
I will surely never use such technique, mostly because more detail on my
images usually helps to make my mistakes more visible... :(
> Use Photoshop :)
   Well, I don't have a valid plataform... ;) Also, it's perhaps
excessive for my little use of such programs... since I now use internal
height_fields and rarely use image_maps, I mostly use the Gimp to put my
sig and to convert to jpg.
