POV-Ray : Newsgroups : povray.newusers : strings in #if-directive Server Time
18 Nov 2026 05:36:35 EST (-0500)
  strings in #if-directive (Message 1 to 14 of 14)
Subject: strings in #if-directive
Date: 11 Dec 2001 14:18:25
Message: <3c165c01@news.povray.org>
hello,
how do i handle strings, if i want to create the following:
#macro mymacro(this)
        #if (this = "myvalue")
mymacro(myvalue)
any hints? thanks.
Subject: Re: strings in #if-directive
Date: 11 Dec 2001 14:34:53
Message: <3c165fdc@news.povray.org>
marabou wrote:
> hello,
>         #end
> #end
> mymacro(myvalue)
or is there anything like strcmp(A,B) in v3.1?
Date: 11 Dec 2001 14:37:26
Message: <hrnc1usqqc7sv5vo2b4l9h13e7a4kjpqol@4ax.com>
On Tue, 11 Dec 2001 20:20:05 +0100, marabou <not### [at] availableyet> wrote:
> #macro mymacro(this) #if (this = "myvalue") ... #end #end
iirc it is well documented in 3.1
and it works the same in 3.5
check strcmp function
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 11 Dec 2001 16:52:45
Message: <3c16802d@news.povray.org>
Włodzimierz ABX Skiba <abx### [at] babilonorg> wrote:
: check strcmp function
  I agree that it would be really nice if (string1 = string2) would work.
I don't see why we should go the C-way in this thing. Better the C++-way.
Date: 12 Dec 2001 13:58:48
Message: <3c17a8e8@news.povray.org>
strcmp(a,b) is the C-way. (string1 == string2) give problems.
in the manual these functions relatively are hidden, that you have to
install your own search-engine about it.
Date: 12 Dec 2001 14:20:57
Message: <3c17ae19@news.povray.org>
: strcmp(a,b) is the C-way. (string1 == string2) give problems.
  What problems? If I do it the C++-way, there are no problems:
string s1 = "abc";
string s2 = "def";
if(s1 == s2) { ... }
else { ... }
Date: 12 Dec 2001 14:27:01
Message: <3c17af7f@news.povray.org>
> string s1 = "abc";
> string s2 = "def";
> else { ... }
sorry, i missunderstood your post. i thought you meant strcmp(a,b) is
c++-way.
in my opinion the c-way is better, because coders then have less problems
with type-casts.
Date: 12 Dec 2001 15:47:00
Message: <3c17c243@news.povray.org>
: in my opinion the c-way is better, because coders then have less problems
: with type-casts.
  The c-way is awful.
Date: 12 Dec 2001 15:52:40
Message: <3c17c398@news.povray.org>
Warp wrote:
>   The c-way is awful.
...but logical. (i think)
Date: 12 Dec 2001 15:59:33
Message: <3c17c535@news.povray.org>
:>   The c-way is awful.
: ...but logical. (i think)
  So you would prefer it also this way:
int a=1, b=2;
if(intcmp(a, b) == 0) { ... }
Date: 12 Dec 2001 16:21:04
Message: <3c17ca40@news.povray.org>
It's a pain having to study C, when your teacher spends most time saying:
"next year, when you study C++, you will discover that this, this and this
has got a much more friendly syntax..."
Jonathan.
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3c17c535@news.povray.org...
> int a=1, b=2;
Date: 13 Dec 2001 06:15:55
Message: <3c188deb$1@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message
news:3c17af7f@news.povray.org...
> > string s1 = "abc";
> > string s2 = "def";
In this case, in C, you are comparing pointers.
whatever the content of S1 and S2 are, the result is false.
> > else { ... }
> c++-way.
> with type-casts.
Chaps.
Date: 13 Dec 2001 06:32:39
Message: <3c1891d6@news.povray.org>
Chaps <cha### [at] yahoocom> wrote:
:> > string s1 = "abc";
:> > string s2 = "def";
:> > if(s1 == s2) { ... }
: In this case, in C, you are comparing pointers.
: whatever the content of S1 and S2 are, the result is false.
  But C has no string class, so it can't be C. That's C++ code. And it works.
Date: 14 Dec 2001 04:00:24
Message: <3c19bfa8$1@news.povray.org>
works.
Dear Warp,
I know that.
I think that my english is too poor, so I misunderstand sometimes the
questions :o(, and I shorten always my answers :o).
Chaps
