POV-Ray : Newsgroups : povray.newusers : getting the table's shadows on the wall Server Time
19 Oct 2026 00:27:16 EDT (-0400)
  getting the table's shadows on the wall (Message 1 to 10 of 10)
Subject: getting the table's shadows on the wall
Date: 10 Sep 2001 19:11:29
Message: <3b9d48a1$1@news.povray.org>
How do I get the table's shadows on the back wall?  here's my code:
#include "woods.inc"
background {color White}
light_source{
 0*x
 color 1
 area_light
 <8,0,0> <0,0,8>
 8, 8
 adaptive 0
 jitter
 translate <40,180,40>
 location <0, 0, 11>
 look_at 0
 angle 40
// Right Wall
box{
 <-1.5,-2.1,-1.5>,<1.5,2,6>
 inverse
 texture{
  pigment{
   color 1-(1-Khaki)*.490
  normal{
   wrinkles 0.2
 scale <0.1, 1.5, 3.5>
 translate <-2.938508, 0, .140896>
// Left Wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
 translate <2.938508, 0, .140896>
// back wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
  scale <3.5, 1.86, 0.1>
 translate <0,0,-6.838508>
// The floor
#declare light_wood= pigment {P_WoodGrain7A  color_map {M_Wood7A} }
#declare  dark_wood= pigment {P_WoodGrain14A color_map {M_Wood14A} }
#declare board_length= 1.5;
#declare board_width= 0.25;
box{
 <2.938508,0,6.838508>,<-2.938508,0,-6.838508>
 pigment{
  gradient y triangle_wave
  pigment_map {
   [0.0 light_wood ]
   [1.0 dark_wood ]
  warp{
   repeat board_length*z offset 0.37*y
  warp{
   repeat board_width*x offset board_length*5/2*z
 normal {
  boxed
  slope_map {
   [0.5 <1,0>]
   [1.0 <0,0>]
  bump_size 0.1
  scale <board_width,1,board_length>
  warp{
  warp{
   repeat board_width*x offset board_length/2*z
translate y*-2.0185
scale <1.3,0,1.22>
// The ceiling
box{
 texture{
  pigment{
   color 1-(1-Khaki)*.49000245
 translate y*2.0185
 scale <1.3,0,1.22>
// a round table
union{
 cylinder{
  0*y .100*y 1.5
 cylinder{
  0*y 1.4*y .300
  translate y*.100
 cylinder{
  0*y .001*y 3
  translate 1.5*y
 texture{
  T_Wood1
 translate y*-5.5
 translate z*-20.5
 scale <.350,.350,.350>
Subject: Re: getting the table's shadows on the wall
Date: 10 Sep 2001 22:45:39
Message: <3b9d7ad3@news.povray.org>
"Wade" <Zav### [at] aolcom> wrote in message
news:3b9d48a1$1@news.povray.org...
I think you should have listened before when Warp was telling you about the
walls and ceiling pigments filtered transparency and needing a rgb <1,1,1>
instead of just color 1.
And that I had said your light source is way outside the room too, as well
as changing the zeroes in your scales to either 1 or some small non-zero
number.
I hadn't followed what you're doing but it sure looks like the script has
touches of Moray in there judging by those decimal numbers and I'm not sure
if you realize how you've cobbled it all together or not.  Maybe you do, but
since you seem new to it I have to think maybe you don't know what you're
doing.  :-)
Anyhow, I took that script and changed it to get the shadow of the table on
that back wall Seriously though, I can't tell what you're trying to do in
making the room the way you did.  I'd have simply differenced out a slightly
smaller box from a larger one.
//background {color White}
light_source{
 0*x
 color 1
 area_light
 <0.8,0,0> <0,0,0.8> // narrower area
 4, 4
 adaptive 1
 jitter
 translate <1,-2,-5> // inside room, near table and below left of it
 location <0, 0, 11>
 look_at 0
 angle 40
// Right Wall
box{
 inverse
 texture{
  pigment{
   color rgb <1,1,1>// -(1-Khaki)*.490 // just to make things regular
  normal{
   wrinkles 0.2
// Left Wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
// back wall
box{
 inverse
 texture{
  pigment{
  normal{
   wrinkles 0.2
// The floor
box{
 pigment{
  pigment_map {
   [0.0 light_wood ]
   [1.0 dark_wood ]
  warp{
  warp{
 normal {
  boxed
  slope_map {
   [0.5 <1,0>]
   [1.0 <0,0>]
  bump_size 0.1
  warp{
  warp{
translate y*-2.0185
scale <1.3,1,1.22>
// The ceiling
box{
 texture{
  pigment{
   color rgb <1,1,1>// -(1-Khaki)*.49000245
 translate y*2.0185
 scale <1.3,1,1.22>
// a round table
union{
 cylinder{
  0*y .100*y 1.5
 cylinder{
  0*y 1.4*y .300
  translate y*.100
 cylinder{
  0*y .001*y 3
  translate 1.5*y
 texture{
  T_Wood1
 translate y*-5.5
 translate z*-20.5
Date: 10 Sep 2001 22:56:52
Message: <3b9d7d74@news.povray.org>
Maybe you do, but
> doing.  :-)
it's my very 1st scene ever.  plus I didn't understand Warp or you were
saying.  Sorry I will ask more questions.
Wade
Date: 11 Sep 2001 00:10:05
Message: <3B9D8E47.628EE140@videotron.ca>
Here's why:
> light_source{
[snip]
> // a round table
> union{
>  translate y*-5.5
>  translate z*-20.5
Since your table's final position is < 0, -3.25, -7.15 > (scale works
about the origin, so your translates  get scaled as well), your light
shines down on it with an angle of ~12 degrees.  Not enough to move the
shadow to the wall.
Here are a few tips.
1 - Place the objects in your scene before starting to work on textures.
2 - Learn the basics before playing with area_lights, warps and
color_maps
3 - Learn how vectors work and their syntax in POV.
4 - Learn how POV handles colors, filter and transmit
THEN: play with a modeller.
I don't want to sound too harsh, but knowing what your modeller does
"under the hood" will not only help you a lot with your scenes, but
you'll also be able to realise that the basic laws still hold:  Walls
aren't transparent.  Walls and ceilings meet.  Floors don't hover.
Lights are inside rooms.  Etc...  Right now, it sure looks like you're
pointing and clicking your way around without knowing what you're doing.
In the off chance that you aren't using a modeller, I'd strongly suggest
you make your room dimensions easier; say 10x10x8.
Francois Labreque | Unfortunately, there's no such thing as a snooze
    flabreque     | button on a cat who wants breakfast.
        @         |      - Unattributed quote from rec.humor.funny
   videotron.ca
Date: 11 Sep 2001 01:51:17
Message: <3B9DA5FF.617458ED@videotron.ca>
I modified your code to fix a few of the problems it had, and made the
dimensions a bit easier to work with.  I hope you'll find that it looks
nicer (I'm not talking about the indentation, but the clarity).
You have some fine textures, here.  Keep it up!
#declare Wall_Texture = texture{
    pigment{ color White-(White-Khaki)*0.495 }
    normal{ wrinkles 0.2 }
#declare Floor_Texture = texture{
    pigment{
        pigment_map {
            [ 0.0 light_wood ]
            [ 1.0 dark_wood ]
        warp{ repeat board_length*z offset 0.37*y }
        warp{ repeat board_width*x offset board_length*5/2*z }
    normal {
        boxed
        slope_map {
            [ 0.5 < 1, 0 > ]
            [ 1.0 < 0, 0 > ]
        bump_size 0.1
        scale < board_width, 1, board_length >
        warp{ repeat board_length*z }
        warp{ repeat board_width*x offset board_length/2*z }
light_source{
    < 9, 9, 9 >
    color White
    area_light
    < 2, 0, 0 > < 0, 0, 2 >
    8, 8
    adaptive 0
    jitter
    location <0, 5, 11>
    look_at < 0, 5, -10 >
// Right Wall
box{
    <10, 0, -12 > <11, 10, 12 >
    texture{ Wall_Texture }
// Left Wall
box{
    < -11, 0, -12> <-10, 10, 12>
// back wall
box{
    < -10, 0, -12 > < 10, 10, -13 >
// The floor
box{
    < -10, -1, -12> < 10, 0, 12 >
    texture{ Floor_Texture }
// The ceiling
box{
    < -10, 10, -12> < 10, 11, 12 >
// a round table
union{
    cylinder{ < 0, 0, 0 > < 0, 0.1, 0 > 1.5 }
    cylinder{ < 0, 0, 0 > < 0, 1.4, 0 > 0.3 translate 0.1*y }
    cylinder{ < 0, 0, 0 > < 0, 0.1, 0 > 3 translate 1.5*y }
    texture{ T_Wood1 }
    translate z*-7.25
   videotron.ca
Date: 11 Sep 2001 20:22:39
Message: <3b9eaacf@news.povray.org>
"Wade" <Zav### [at] aolcom> wrote in message news:3b9d7d74@news.povray.org...
>   Maybe you do, but
you're
> > doing.  :-)
Nah, don't be sorry.  I should be for maybe sounding like you weren't
listening to us instead of having trouble understanding things.
It's been so long ago since I began using POV (8 years!) I hardly know
anymore what it's like to start out in it.  But I think Ron is very right in
that I too will never really master POV-Ray.
Besides, answers need questions (?) :-)
Bob H.
Date: 12 Sep 2001 18:59:46
Message: <3b9fe8e2$1@news.povray.org>
Thanks for understanding, Bob.  How do I create a doorway with a
partly-closed door allowing some light in?
Date: 12 Sep 2001 20:03:44
Message: <3b9ff7e0$1@news.povray.org>
Thank you Francois for cleaning my code up.  I've a question though: why did
you remove the inverse?
Wade
Subject: Re: and a door to open
Date: 12 Sep 2001 21:01:33
Message: <3ba0056d@news.povray.org>
news:3b9fe8e2$1@news.povray.org...
Ahhh, the wonders of CSG...
With the room script I last saw you'd need to put difference {} around the
wall the door is to be.  Also place the texture into the end of that
'difference' so that the door frame shows as a color.  But you can also put
a new texture into the box used for the doorway cutout too.
Basically:
// left wall
difference {
  box { // wall
         <-2,-1,-6>,<2,1,6>
         scale <0.1,1,1>
  box { // doorway cutout
         <-0.21,-1,-3>,<0.21,0.7,-2>
 texture {pigment {rgb <1,1,1>}}
  translate <2,0,0>
I'm just guessing at dimensions and placement here, you'll want to change
those.
I must point out something about the way you are going about your scene.
There doesn't seem to be any real world units used, i.e. meters, feet,
yards, etc.  That makes it difficult to accumulate the scene because you
always have to reference at least some part of it to know where and what
size things will be.
Anyway, notice that the scaled wall box is at 0.2 POV units along +/- x,
making it 0.4 total thickness, then the doorway box is a couple hundredths
thicker so it will complete the CSG correctly.  As well as being postioned
from floor (-1*y) to near ceiling but not quite (+0.7*y) and a width of 1
unit along z.
Apologies if I'm explaining what you already knew or even if you can't
follow me easily.
This should be the idea you asked about as far as creating the doorway.  To
make the door and it be ajar (opened a little) there is a little more to it.
Really actually simple though.  You make the box (with texture added) so one
side where the hinges would be is along 0*y.  Something like: box
{<0,-1,0>,<0.1,0.7,1>} where the 0*x and 0*z axes are the pivot plane
(corner edge of door).  Add rotate -15*y to the box statement for the amount
of open/close.  Finally translate into place where the doorway is, in this
example it would be at <1.8,0,-3>, since the cutaway was put at <1.8,-1,-2>
to <2.2,0.7,-3> (so -2 to -3 * z is door width and position) and the door
itself goes from zero to one z.
Hinges would be inside room in this case, toward +z, and door opens on
the -z side into room.  Adding clock to the rotation for animation, or just
a predeclared variable, makes it easy to change the door movement.
Since you used a +z placed camera last I saw this opens the door so light
outside wouldn't go toward the table and back wall though so you'll need to
turn that all around.  Sorry.  I'm getting confused.  I'm not trying this as
I go, just writing it here so be aware this could be faulty.
Basically you can see how it matters a whole lot how you go about setting it
all up from the beginning.  The door could be placed into a union of the
difference so that when translating it to the right or left it all goes
together rather than piecing it in later.  Obviously it's all something
individual people must learn to do in their own way.
Bob H.
Date: 13 Sep 2001 01:07:36
Message: <3BA03EAB.94426DDB@videotron.ca>
> Wade
It really doesn't matter as you're not doing CSG or media, but a shape
without the inverse has the interior inside the limits of the shape.  By
putting "inverse", you fill your universe with the shape EXCEPT inside
Render the following example to see the difference:
//---8<---8<---8<---8<---
intersection{
    box{ < -5, 0, -2 > < -1, 4, 2 > }
    sphere{ < -3, 2, 0 > 2.5 }
    texture{ pigment{ color Blue } }
intersection{
    box{ < 1, 0, -2 > < 5, 4, 2 > }
    sphere{ < 3, 2, 0 > 2.5 inverse }
    texture{ pigment{ color Red } }
light_source{ < 10, 10, -10 > color White }
camera{ location < 0, 2, -10 > look_at < 0, 2, 0 > }
As you can see, the shape that is defined by the blue sphere is inside
the surface, whereas the shape defined by the red one is the outside.
   videotron.ca
