Subject: UV mapping with rhino exported scene - 3.5
Date: 10 Sep 2001 16:02:36
Message: <3b9d1c5c@news.povray.org>
I exported a scene with a very special shape and all the usual map_types
didn't apply the way I wanted. Also, I heard of the UV mapping with POV 3.5
and read the documentation for see what could I do, but all I get was a
black rendered image.
How the UV mapping has to be used on mesh files such as rhino exported ones?
The only thing tried so far is:
uv_mapping pigment { image_map { ... } }
and didn't worked.
Thanks in advance
Renato Oliveira
Renato Oliveira <war### [at] bol com br> wrote:
: How the UV mapping has to be used on mesh files such as rhino exported ones?
The program has to support writing the uv-coordinates from the original
model to the POV-Ray file. There's no way in earth that you could magically
make povray generate the uv-coordinates with a single keyword.
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Subject: Re: UV mapping with rhino exported scene - 3.5
Date: 11 Sep 2001 00:18:30
Message: <3b9d9096@news.povray.org>
Warp <war### [at] tag povray org> escreveu nas notícias de
mensagem:3b9d4b25@news.povray.org...
magically
And there is no way to use the mesh information that I already have to
specify the uv mapping?
: And there is no way to use the mesh information that I already have to
: specify the uv mapping?
How would you map triangle vertices to texture coordinates?
POV-Ray can't know this. It has to be told. For each vertex you have to say
which texture coordinates to use.
Date: 12 Sep 2001 06:09:40
Message: <3b9f3464@news.povray.org>
Warp wrote in message <3b9dbb77@news.povray.org>...
to
have to say
True, unfortunately. But (depending on what you want and whether
you're willing to go through extra programs) you can try this (should
work partially):
1. Re-export your mesh in one of the common formats (3ds/obj etc)
preferrably obj.
2. Use uvmapper (www.uvmapper .com - also has tutorial on how to
use it ) or lithiumunwrap (http://www.geocities.com/lithunwrap/) to
'paint' your required texture/image.
3. Convert to pov using objuvpov
Depending on what exactly it is you want to do, there may be other
'solutions'
Hope this helps (and isn't too tedious :))'
-Anoop
Date: 12 Sep 2001 23:12:14
Message: <3ba0240e@news.povray.org>
Anoop <ano### [at] flashmail com> escreveu nas notícias de
mensagem:3b9f3464@news.povray.org...
> work partially):
> preferrably obj.
> 'solutions'
> -Anoop
I think will work because the object isn't that detailed, it's just
different from the usual primitives : )
Thank you all, I'll try it.
Renato
Date: 12 Sep 2001 23:16:11
Message: <3ba024fb@news.povray.org>
Oh, and one more thing, I apologize for the crazy dates/times that my posts
show, I have to change the battery : )
Renato Oliveira
