POV-Ray : Newsgroups : povray.newusers : Adding more lights and lightening up the pigment Server Time
6 May 2026 16:04:09 EDT (-0400)
  Adding more lights and lightening up the pigment (Message 1 to 3 of 3)
Subject: Adding more lights and lightening up the pigment
Date: 5 Sep 2001 12:14:31
Message: <3b964f67$1@news.povray.org>
How do I add more lights to brighten up the left wall?  And how do I get a
lighter shade of the khaki that I'm using.  Here's my code:
background {color White}
light_source{
 0*x
 color White
 area_light
 <8,0,0> <0,0,8>
 4, 4
 adaptive 0
 jitter
 translate <40,80,40>
 location <0, 0, 11>
 look_at 0
 angle 40
// Right Wall
box{
 <1,1,1>,<-1,-1,-1>
 texture{
  pigment{
   color Khaki
  normal{
   wrinkles 0.25
   scale 0.005
  finish{
   ambient 0.266167
   diffuse 0.884867
 scale <0.1, 1.5, 3.5>
 translate <-2.938508, 0, .140896>
// Left Wall
box{
 <1,1,1>,<-1,-1,-1>
 texture{
  pigment{
   color Khaki
  normal{
   wrinkles 0.25
   scale 0.005
  finish{
   ambient 0.266167
   diffuse 0.884867
 translate <2.938508, 0, .140896>
Subject: Re: Adding more lights and lightening up the pigment
Date: 5 Sep 2001 12:29:46
Message: <3b9652fa$1@news.povray.org>
> light_source{
>  0*x
>  color White
to brighten this light you can multiply the color by a number
i.e., White*1.5, White*5, etc...
-snip-
> // Right Wall
> box{
>  <1,1,1>,<-1,-1,-1>
>  texture{
>   pigment{
>    color Khaki
Again, use multiplier to change the intensity of the color ( <1=darker,
>1=lighter, i.e. try Khaki*1.1)  this is a quick change for opaque colors,
remember that the multiplier will affect the transmit and filter values as
well if they are greater than 0
Date: 5 Sep 2001 12:36:29
Message: <3b96548d$1@news.povray.org>
You can have more than one light source in a scene. Or you can specify
  color White*1.5
to make your exsiting one brighter.
> And how do I get a
Again, you can multiply the color by a constant, e.g.
  color Khaki*1.5
or also do calculations with it:
  color 1-(1-Kahki)*0.5
which will reduce the difference between Khaki and White. You could also
play with the ambient and diffuse values, which will actually not change
the color but the way how the surface reacts on the incoming light.
 - Micha
