I have managed to insert a hightfield, but it comes out black, if I try and
add a texture pigment or color to it I get "object or directive expected"
errors. What am I not understanding here?
It sounds like a very simple syntax error but I can't give you a
detailed analysis without seeing the code you are using. Try
posting just the HF portion of your code so we can take a closer
look at it.
ok, I've tried the following:
background { color SkyBlue }
Height_Field {gif "d:\fract001.gif"}
also tried putting it in as an object, adding trans forms etc
"Ken" <tyl### [at] pacbell net> wrote in message
news:3A5BF81E.C91FCA71@pacbell.net...
and
expected"
> look at it.
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
"RWard" <rmw### [at] swbell net> wrote in message
news:3a5dab0e$1@news.povray.org...
Your height field has no pigment. Try:
Height_Field {gif "d:\fract001.gif" pigment{rgb<1/2,1/1/2>}}
(the background is irrelevant - that is a seperate object).
In article <3a5dab0e$1@news.povray.org>, "RWard"
You have an extra "}" bracket...you should always make sure your
brackets match up, a "}" for every "{".
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
Oops, that should have been:
Height_Field {gif "d:\fract001.gif" pigment{rgb<1/2, 1, 1/2>}}
your are correct!
Tom, tried it and get parsing error message "object or directive expected
but undeclared identifier height_field found instead"
"Chris Huff" <chr### [at] mac com> wrote in message
news:chrishuff-8682E8.07543311012001@news.povray.org...
HA! case sensitivity!
news:3a5ddab7@news.povray.org...
> your are correct!
> your are correct!
... but presumably it's still black (or have you added a pigment statement
as well as removing the }?)
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3a5ddddb@news.povray.org...
ack, scrap that last message. I hadn't taken in that you'd still got a
problem. Yep, case is wrong. And none of us spotted it. The shame. The
ignomy.
> ignomy.
I noticed it right away but RWard caught it before I could correct your
major blunder. After that it wasn't worth it...
thanks all,
BTW RWard=zither
news:3A5### [at] pacbell net...
> > ignomy.
Who is this? What have you done with Ken? Ken wouldn't have taken 4 hours to
have read a post....
Oh, yeah, 2001 - I'd forgotten about the delay between here and Jupiter
(plus, of course, your radar dish is behaving funny). Hi Ken. Big kiss to
David and the gang.
