Hello, (hope I do this right, first time try to write to a newsgroup)
I try to make a text in a povray picture, putting together characters in
different textures.( with the text object and a truetype fond)
I have problems setting the distance between the characters right, because I
do not know the exact width of the characters.
Have I to do this by try and error, translate the characters until it looks
right or can somebody think of another method to do this ?
Especially: Is there a method to get the exact width of a given character?
Jessica Bushnaq
Welcome to these groups, the posting looks ok to me, some general
information about things here can be found in:
povray.announce.frequently-asked-questions
> Jessica Bushnaq
IIRC there is no method in Povray to find out the width of the single
characters. Some things you could do anyway:
- The character width is stored somewhere in the TTF file, you could try
to read it with an external program and put a table with the data of all
character in a pov-file
- You could use a non proportial font (like Courier), where all the
characters have the same width.
- you could try to find the gaps between the characters with megapov's
trace function and use a gradient pattern to give the different characters
different textures. This probably sounds quite complicated and it
requires some (pov-)programming knowledge, but IMO this is the most
elegant way :-)
Christoph Hormann <chr### [at] gmx de>
In article <3A17B933.82F38498@schunter.etc.tu-bs.de>,
> megapov's trace function and use a gradient pattern to give the
> different characters different textures. This probably sounds quite
> complicated and it requires some (pov-)programming knowledge, but IMO
> this is the most elegant way :-)
A more flexible(and far simpler) solution would be to use a separate
text object for every character and use the min_extent() and
max_extent() functions to get the bounding box for each individual
character, and use these values to position the characters correctly.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
Ron Parker made a macro for that:
Newsgroups: povray.programming
Subject: Re: Font metrics function
Message-ID: <slr### [at] parkerr fwi com>
Date: 27 Feb 2000 13:13:40 -0500
Ingo
Pov-Ray : http://members.home.nl/seed7/
I think that's only partly true, because the nominal width of the
characters (used for positioning them) and the de facto with do not need
to be the same. I don't know which width is used for the bounding box
(whether all characters in a non proportional font have the same for
example), there can be even overlapping characters (they would not work
with the trace method either) so things are more complicated in fact...
The difference is advance width and kerning. Those are taken into account
in the macro Ingo made note of.
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
> character?
I have only the official version, and here's the code I use to get the
width of text:
// START OF SOMETHING OF POSSIBLE USE
#local W=1; // you'll be tweaking this value
text { ttf "cyrvetic.ttf", // or whatever font you're using
"My text.", // change to whatever you're using
0,
0
pigment { rgb <1,0,0> } // to make things obvious
finish { ambient 1 diffuse 0 }
translate -z*.001
plane { -z,0
pigment { gradient x color_map { [0 rgb 0][1 rgb 1] } scale W }
orthographic
location <W,.375,-1>
look_at <W,.375,0>
// END OF SOMETHING OF POSSIBLE USE
You should see an image that is white on the left side and black on
the right, with red text. Adjust W until the right edge of the text
lies exactly on the border between the black and white areas. When
this happens, W is either the exact width of the text, or is a simple
fraction (1/2, 1/3, 1/4) of that width; starting with a higher value
and working your way down will give better results.
Hope this helps,
John
This makes me think, if your intention is to put the letters on the same
positions as they are in the "full text", you could as well use a
pigment_map or texture_map with a gradient to give each letter a different
texture.
text {
ttf
"crystal.ttf",
"POV",
0.1,
0
gradient x
scale 2
pigment_map{
[0.2, wood]
[0.2, granite]
[0.5, granite]
[0.5, wood]
translate <-0.75,0,0>
Ingo
I'm trying to get a text string centered, and I remembered this thread.
Chris, can I use min_extent() and max_extent() on a string, or is it
only applicable to single characters? Where can I find documentation on
these functions; it doesn't seem to be with the other text primitive
documentation in the official docs.
For that matter, if the function is not part of POV natively, where can
I find the function?
Thanks in advance.
Dawn McKnight | "Who cares what the hipbone's connected to? I'm in Neurology!"
McK### [at] mac com | -- Justine Devlin, M.D.
It will work with almost any finite primitive, which includes a multicharacter
text object. It fails on some CSGs, though; most notably on intersections and
differences.
It's part of MegaPOV and other patches like it.
Text centring is directly available in MegaPOV. Just add the
"align_center" modifier to the text object.
You only need to use MegaPOV's "min_extent()" and "max_extent()" if
you're doing more complicated positioning tasks.
The *_extent functions are described in section 9.1 (Bounds Patch) of
the MegaPOV 0.6 docs, and align_* are in section 6.6 (Text Object
Enhancements).
Mike Williams
Gentleman of Leisure
Why yes, it was... thank you for noticing! P)
Sadly, that requires me to download MegaPOV, install it, figure out
where it's different from standard POV, so that I don't get
unpredictable results in my scene files, read the docs on text, etc., etc.
Of course, I probably will do this, eventually, but it's really rather
more involved than I wanted to get for what is basically a throw-away
test on a concept.
Thank you for letting me know this, and for your citation on where the
documentation is... I'll be very grateful when I get around to doing all
that stuff. 8)
> test on a concept.
For all intents and purposes you should be able to use Megapov
with little or no extra knowlege other than learning it's extra
feature sets. It is basically the same as the official version
with enhancements.
Ken Tyler
Note that this won't be directly supported in POV 3.5.
Will there be any text handling improvements in 3.5?
The min_extent and max_extent functions will make it in, and we'll likely
provide macros to give the same functionality as the MegaPOV text alignment
keywords provide.
