POV-Ray : Newsgroups : povray.newusers : hf_square Server Time
12 Aug 2025 11:11:10 EDT (-0400)
  hf_square (Message 1 to 3 of 3)
Subject: hf_square
Date: 6 Apr 2003 09:48:11
Message: <3E903019.9070001@chello.nl>
I have a question about the hf_square macro. Can anyone give an example
of the "function"-paramater? I don't know what sort of function I have
to give.
Thanks a lot!
J T
Subject: Re: hf_square
Date: 6 Apr 2003 13:59:57
Message: <3e906b1d@news.povray.org>
"J Tellings" <jte### [at] chellonl> wrote in message
news:3E9### [at] chellonl...
> to give.
Anything that can be a function elsewhere in POV-Ray, such as an equation
like (2+sin(x*3))*(1+cos(z*2))/5. Or a predeclared function, such as those
found in functions.inc.
object {
    HF_Square(
        function {f_noise3d(x,y,z)}, // example
        0,0,<100,100>,0,"",<-10,-1,-10>,<10,0,10>
pigment {rgb<1,0,0>}
Bob H.
Date: 6 Apr 2003 16:53:06
Message: <3e9093b1@news.povray.org>
> to give.
  Hughes answered the question, but I have the strong feeling that what
you are doing in your code is giving it a color function, although it
expects a float function.
  If you have a color function, you need to create a float function from
it, for example like this:
#declare MyFunctionGray = function { MyFunction(x,y,z).gray }
  Then you can give MyFunctionGray as parameter to the macro.
