I just discovered I declared the same object twice, both in the actual
POV file and once in one of its INC files. Which version is taking
precedence? (I'm not getting any error messages about it).
Thanks!
Mark (aka LibraryMan)
The POV file should take precedence. However, try changing slightly one of
them and it'll be easy to discover the truth.
Red Golpe
_____________________________________________
"What doesn't kill you... makes you stronger"
Jean-Baptiste Emmanuel Zorg
http://redgolpe.com
(La capovolta ambiguità di Orione)
"LibraryMan" <mrm### [at] att net> ha scritto nel messaggio
news:3DFA51CE.574CF362@att.net...
> Thanks!
In article <3DFA51CE.574CF362@att.net>, LibraryMan <mrm### [at] att net>
Assuming you didn't use #local, whichever one is reached last. A
declaration replaces a previous declaration with the same name and scope.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
> Thanks!
Well, try making a subtle, yet noticable change in one, and see if it
changes.
"LibraryMan" <mrm### [at] att net> wrote in message
> Thanks!
Whichever came last.
If the object is declared in the scene after the .inc is #included, the .pov
object will be used, or if the #include is after the declared object, the
.inc one is used.
-tgq
