POV-Ray : Newsgroups : povray.newusers : image map Server Time
12 Oct 2026 06:13:51 EDT (-0400)
  image map (Message 1 to 17 of 17)
Subject: image map
Date: 12 Jun 2002 20:13:02
Message: <3D07E392.6060702@gmx.de>
hi,
iv got another problem with my beer bottle. the labels are should only
be once on the bottle, but they are each twice (horizontal)
here´s the code:
       pigment {rgbf <0.3, 0.13, 0.075, 1.35>    }       }
      texture { pigment {
    image_map { png "beer2.png"
                        once
                        interpolate 2
             translate <-0.5+a,0.1+b,c>
             scale <4/10,6.2/10,4/10> }
      interior { ior 1.5 }
      texture {beero}
       translate < a, b , c >
       finish {
         ambient 0.5
         diffuse 0.35
         brilliance 0.5
         specular 0.1
         roughness 0.000009
         reflection { 0.48  fresnel}
         conserve_energy}
Subject: Re: image map
Date: 13 Jun 2002 00:23:58
Message: <3d081e5e@news.povray.org>
"ulli" <ull### [at] gmxde> wrote in message news:3D0### [at] gmxde...
Yes, because the default (planar type) mapping is infinitely thick. You
would need to either use map_type 2 (cylindrical) instead or slice the
bottle in half vertically then apply the image map texture to one half and
leave other half without it (for example, but whatever way you want to go
about that). Obviously cylindrical mapping is easiest, you just need to
compensate for it in the image used to wrap it, leaving plenty of blank
space.  pi * height, for the dimensions.
bob h
Date: 15 Jun 2002 07:25:37
Message: <3D0B2438.50104@gmx.de>
> bob h
pi*height for dimensions???
could you explain this? *g*
i know what pi is, but which height for which dimension?
i´ve tried a little bit but it always looked a bit strange
Date: 15 Jun 2002 07:32:56
Message: <3d0b25e8@news.povray.org>
Why should he compensate in the image and not scale it in POV?
Date: 15 Jun 2002 08:05:05
Message: <3D0B2D7B.1010402@gmx.de>
would i have to try it out, or can i calculate it??
Date: 15 Jun 2002 11:11:30
Message: <3D0B592D.4070107@gmx.de>
http://www.winter-privat.de/bottle.jpg
this is how it looks with cylindrical map type and wider label (the
bottom label)
"jagdherren pils" is written on the label
Date: 15 Jun 2002 14:11:25
Message: <3d0b834d$1@news.povray.org>
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3d0b25e8@news.povray.org...
Cylidrical image_maps take the entire image and fits the height to 1 POV
unit in the y axis and wraps the texture once around the y axis.  You can
then scale it in the y direction but (without using a different method) the
image can't be scaled around the y-axis.  In order to get the label to wrap
partially around the bottle (unless you want it fully wrapped) you have to
compensate in the image_map image itself.
-tgq
Date: 15 Jun 2002 16:24:24
Message: <3d0ba278@news.povray.org>
  This is quite an ugly method because you either need to make an extra-large
image, which will consume unneeded memory, or you'll have to use a lower
resolution. Not nice.
  Instead of this, make a pigment with your image_map (using the 'once'
option), scale it down to the desired size and then apply the cylindrical
warp to it.
Date: 15 Jun 2002 17:26:39
Message: <3D0BB11A.70100@gmx.de>
i really dont know what im doing wrong, but the labe always get
strectched on the left/rigth edge (http://www.winter-privat.de/bottle2.jpg)
this one is with pigment map for the lower label
Subject: Re: image map (cylindrical warping?)
Date: 15 Jun 2002 21:42:57
Message: <3d0bed21@news.povray.org>
Coming back late on this. I am not much on using 'warp', expecially the new
types, so all I could do is:
  location  <1,3,-5>
  look_at   <0,2,0>
light_source {
  <-30, 30, -30>,
  color rgb 1
plane {
  y, -0.001
    pigment { checker color rgb <1,1,0> color rgb <0,1,0> }
cylinder {
  0, 2*y, 1
      image_map {
        png "testlabel.png" // I used 300 by 300 res. for this
        interpolate 2
        once
        filter 255, 2/3 // set a pallete index to filtered value
      warp {
        cylindrical
        orientation z
        dist_exp 0
      rotate -90*y
      scale <1,2,1>
 scale <1,2,1>
This wraps around like map_type 2 in image_map but I couldn't get the effect
Warp mentioned. I scaled and changed dist_exp only to get a distorted label,
apparently similar to your outcome, ulli.
Either I misunderstood or I didn't hit upon the correct transformation.
bob h
Date: 15 Jun 2002 22:27:24
Message: <3d0bf78c@news.povray.org>
You know the idea then, I'm sure.
Say a 3.14*100 wide image (in pixels) is the pi, or cylinder circumference,
and the height is always 1 POV unit to start with; but you'd then want that
number to be a 3.14:0.5 (yeah, 0.5, not 1.0) ratio of width to height.
Voila! 314 wide by 50 height, or any rescale of that ratio, will fit
proportionally correct on a POV unit cylinder primitive because it is 2
units diameter, 1 unit tall, and pi*2 units in circumference.
I sort of misspoke before by not pointing out map_type 2 has such a "unit"
system to it. It's not 1 in diameter. I really shouldn't have ever said it
the way I did so haphazardly, pi * height is just plain wrong. It's actually
pi * (height/2). Sorry, I can confuse better than I can help  ;-)
Were the units done differently it would be simpler to think of it as 1 for
diameter, 1 for height, making it pi for circumference. So try to keep that
in mind, that it is 2 across instead yet only 1 unit tall.
Okay, I'm probably digging myself into a hole so I'll shut up now.
bob h
Date: 16 Jun 2002 00:26:05
Message: <3d0c135d@news.povray.org>
effect
label,
You need to scale before you apply the warp.
Date: 16 Jun 2002 10:26:13
Message: <3D0CA011.20907@gmx.de>
ive tried it, but the label only doesnt get distorted if i use the
initial translate and scale settings. but then its size isnt correct.
these are the settings:
             translate <-0.5,0.1,0>
http://www.winter-privat.de/bottle3.jpg
and that is the bottle
Date: 16 Jun 2002 10:49:57
Message: <3d0ca595$1@news.povray.org>
Hmmm, remember this mantra 'scale, then translate, scale, then translate'
First of all, cylindrical image_maps are defined around the 'y' axis and
extends from y=0 to y=1 so your object needs to be centered on the y axis
before applying the image_map if you don't want weird results.
Likewise, scaling (also rotation) occurs around the origin. You should
always create your object at the origin and apply any scaling before
translating.
-tgq
Subject: Re: image map (cylindrical warping)
Date: 16 Jun 2002 12:07:20
Message: <3d0cb7b8@news.povray.org>
news:3d0c135d@news.povray.org...
Thanks Simon, that sure seems to be the answer all right.
  location  <1,2,-4>
  look_at   <0,0,0>
  angle 50
light_source {
        <-30,30,-30>,
        1
plane {
  y, -0.001
cylinder {
  0, y, 1
      image_map {
        png "testlabel2.png" // a 314 wide by 50 high image
        interpolate 2
        once
        filter 215, 2/3
        scale <.25,.25,1>
        translate y/2
      warp {
        cylindrical
        orientation z
        dist_exp 0
      rotate 120*y
Something strange happens with the cylinder here. Looks like coincident
surfaces to me except it also reverses the checker pattern of the floor
plane, as seen through that otherwise invisible cylinder. Only the label has
texture, no 'ior' in that.
bob h
Date: 16 Jun 2002 15:52:00
Message: <3d0cec60@news.povray.org>
  It doesn't seem to be related to the texture (if you apply any trasnparent
texture to the cylinder, the same artifact happens).
  I don't know why it happens, but if you make the plane y, -0.01 then
it fixes it.
Subject: Re: this plane under cylinder oddity
Date: 16 Jun 2002 22:02:29
Message: <3d0d4335$1@news.povray.org>
news:3d0cec60@news.povray.org...
has
trasnparent
> it fixes it.
Interesting. I checked that as you said and found now that if it's
at -0.00101 or -0.00099 there's no artifacting. Strange, huh...? I can't
figure any reasoning for this.
bob h
