POV-Ray : Newsgroups : povray.newusers : Placing objects on a height field Server Time
18 Nov 2026 05:22:30 EST (-0500)
  Placing objects on a height field (Message 1 to 20 of 20)
Subject: Placing objects on a height field
Date: 22 May 2002 07:23:45
Message: <3CEB81F4.41BDB709@sympatico.ca>
Hi there,
  I was wondering if I put a height field as my ground, can I randomize
the placement of objects such as plants with relative elevation to the
HF?
I'm using povray 3.1 for linux...
Thanks,
  Simon
    "Neuromancer," the boy said.  "The lane to the land of the
dead.  Where you are, my friend.  I call up the dead.  But no,
my friend, I am the dead, and their land."    (William Gibson)
--  Simon Lemieux  (Rei### [at] Sympaticoca)
Subject: Re: Placing objects on a height field
Date: 22 May 2002 10:03:14
Message: <3ceba522@news.povray.org>
"Simon Lemieux" <Rei### [at] sympaticoca> wrote in message
news:3CEB81F4.41BDB709@sympatico.ca...
AFAIK, not with 3.1. You need trace which requires either megapov or 3.5.
On the other hand, if you use leveller, you have the option to export a series
of points on the surface iirc.
Date: 22 May 2002 22:03:05
Message: <3CEC5014.29F4E08E@sympatico.ca>
Doesn't anyone feel it's time to port the latest povrays to linux? ;)
I'll work my way around manually...  Thanks anyway!
Simon
Date: 23 May 2002 07:19:26
Message: <3cecd03e$1@news.povray.org>
news:3CEC5014.29F4E08E@sympatico.ca...
Why not give megapov a try?
I might be able to help via leveller - if you send me your scene file and the hf
image I could generate some points for you.
Date: 23 May 2002 09:32:28
Message: <3cecef6c@news.povray.org>
  Try http://povray.org
Date: 23 May 2002 10:43:07
Message: <3cecfffb$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3cecef6c@news.povray.org...
I assume Simon's after 3.5 (since he needs trace) - are 3.5 RC's avail. for
Linux? (I can't see 'em).
Date: 23 May 2002 11:58:58
Message: <3ced11c2@news.povray.org>
  Yes. Look closer.
Date: 23 May 2002 14:35:47
Message: <3CED38C6.2A2E336@sympatico.ca>
>   Yes. Look closer.
Indeed!  But I had a look in the download section before where it's
not.  But I could find the link to linux povray version 3.5.
  Thanks Warp!
PS: does the 3.5 has the isofunctions?
Date: 23 May 2002 15:49:42
Message: <3ced47d6@news.povray.org>
news:3CE### [at] sympaticoca...
>   Thanks Warp!
Yes - although the syntax is slightly different than for megapov. It's still
RC (release candidate), so there is an expiry date (but you probably knew
that).
Date: 23 May 2002 18:05:06
Message: <3ced6792@news.povray.org>
Have you tried Terraform?
It's a open source landscape/heightfield editor which runs under Linux. It
has the ability to place objects on landscapes and renders its output with
Pov-Ray 3.1
I managed to get it running under Mandrake 7.1 (after installing lots of
extra packages). Looking at the website I noticed that a new version has
appeared (version 0.9.0) which mentions "improved object placement".
See the following link for more details:
http://terraform.sourceforge.net
Reuben
doo### [at] breathemailnet
Date: 23 May 2002 18:13:53
Message: <3ced69a1@news.povray.org>
  What are isofunctions?
Date: 24 May 2002 15:15:16
Message: <3CEE9394.651C0654@sympatico.ca>
Frankly, I have no idea... yet...!
But I shall discover soon!
Date: 24 May 2002 15:25:35
Message: <3cee93af@news.povray.org>
  I know functions and isosurfaces, but I don't know what are isofunctions.
Date: 25 May 2002 15:33:59
Message: <3cefe727@news.povray.org>
news:3cee93af@news.povray.org...
isofunctions.
Don't worry about it - they're for advanced users.
Date: 25 May 2002 16:31:53
Message: <3ceff4b9@news.povray.org>
> isofunctions.
  Could you explain it to a newuser like me?-)
Date: 26 May 2002 08:47:42
Message: <3CF0DA25.13EC5823@pacbell.net>
> > isofunctions.
I doubt that's possible...
Ken Tyler
Date: 27 May 2002 04:21:00
Message: <p0r3fusrh78ms7i92b6b0abm2dfcv49vci@4ax.com>
> > isofunctions.
They must be functions after standarization :-)
ABX
Date: 28 May 2002 23:24:08
Message: <3CF44C5F.CB66EB5E@sympatico.ca>
Hehe, pardon, my newbieness or shall I say my
too-long-since-my-last-ray-traceness...  I did mix these two up, I was
talking about isosurfaces which seems to be the kind of abstract
mathematical objects made for me!
Thanks,
  Simon
Date: 29 May 2002 08:45:23
Message: <3cf4cd63@news.povray.org>
  An isosurface is an equipotential surface, that is, it consists of all
the points in space where the value of the given function is a given constant
(usually, but not necessarily, 0).
  A similar entity is an isobar. Isobars are 2D lines in a geographic map.
The line consists of all the points where air pressure is the same (a given
constant value).
Date: 3 Jun 2002 17:08:37
Message: <rcghfugmprb1vf3pvrh2sncidp7k0vtd14@4ax.com>
Sure. They are functions that return the same value. It's just a geek
name for declaring a float constant, really.
Here's an example:
isofunction theAnswer(x,y,z) = 42;
Peter Popov ICQ : 15002700
