Hi there,
I was wondering if I put a height field as my ground, can I randomize
the placement of objects such as plants with relative elevation to the
HF?
I'm using povray 3.1 for linux...
Thanks,
Simon
"Neuromancer," the boy said. "The lane to the land of the
dead. Where you are, my friend. I call up the dead. But no,
my friend, I am the dead, and their land." (William Gibson)
-- Simon Lemieux (Rei### [at] Sympatico ca)
"Simon Lemieux" <Rei### [at] sympatico ca> wrote in message
news:3CEB81F4.41BDB709@sympatico.ca...
AFAIK, not with 3.1. You need trace which requires either megapov or 3.5.
On the other hand, if you use leveller, you have the option to export a series
of points on the surface iirc.
Doesn't anyone feel it's time to port the latest povrays to linux? ;)
I'll work my way around manually... Thanks anyway!
Simon
news:3CEC5014.29F4E08E@sympatico.ca...
Why not give megapov a try?
I might be able to help via leveller - if you send me your scene file and the hf
image I could generate some points for you.
Try http://povray.org
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
"Warp" <war### [at] tag povray org> wrote in message news:3cecef6c@news.povray.org...
I assume Simon's after 3.5 (since he needs trace) - are 3.5 RC's avail. for
Linux? (I can't see 'em).
Yes. Look closer.
> Yes. Look closer.
Indeed! But I had a look in the download section before where it's
not. But I could find the link to linux povray version 3.5.
Thanks Warp!
PS: does the 3.5 has the isofunctions?
news:3CE### [at] sympatico ca...
> Thanks Warp!
Yes - although the syntax is slightly different than for megapov. It's still
RC (release candidate), so there is an expiry date (but you probably knew
that).
Have you tried Terraform?
It's a open source landscape/heightfield editor which runs under Linux. It
has the ability to place objects on landscapes and renders its output with
Pov-Ray 3.1
I managed to get it running under Mandrake 7.1 (after installing lots of
extra packages). Looking at the website I noticed that a new version has
appeared (version 0.9.0) which mentions "improved object placement".
See the following link for more details:
http://terraform.sourceforge.net
Reuben
doo### [at] breathemail net
What are isofunctions?
Frankly, I have no idea... yet...!
But I shall discover soon!
I know functions and isosurfaces, but I don't know what are isofunctions.
news:3cee93af@news.povray.org...
isofunctions.
Don't worry about it - they're for advanced users.
> isofunctions.
Could you explain it to a newuser like me?-)
> > isofunctions.
I doubt that's possible...
Ken Tyler
> > isofunctions.
They must be functions after standarization :-)
ABX
Hehe, pardon, my newbieness or shall I say my
too-long-since-my-last-ray-traceness... I did mix these two up, I was
talking about isosurfaces which seems to be the kind of abstract
mathematical objects made for me!
Thanks,
Simon
An isosurface is an equipotential surface, that is, it consists of all
the points in space where the value of the given function is a given constant
(usually, but not necessarily, 0).
A similar entity is an isobar. Isobars are 2D lines in a geographic map.
The line consists of all the points where air pressure is the same (a given
constant value).
Sure. They are functions that return the same value. It's just a geek
name for declaring a float constant, really.
Here's an example:
isofunction theAnswer(x,y,z) = 42;
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
