![](/i/fill.gif) |
Trevor Quayle <Tin### [at] hotmail com> wrote:
:> : i just want to wrap a
:> : wordmap arround a cube.
: I don't see what you mean in the docs. Unless something is missing from
: them, there is no option to use box mapping with image map
From what I understood, he wanted to wrap a rectangular image map to
a box. The only way of doing this (so that everything is mapped onto the
box) is to use spherical mapping.
If you use box-mapping, you'll lose parts of the original image map
(unless the image map is designed specifically for box mapping, ie. with
those missing parts being just black or whatever).
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
![](/i/fill.gif) |
